Question about Refrigerators
How to remove back panel of bottom freezer in Kenmore model 795.75553401
I cannot figure out how to remove the back panel of the bottom freezer, I need to access the area that the drain tube is in. My drain hole is plugged as no water ends up in the defrost tray at the bottom of the fridge....it just somehow ends up in the bottom freezer cavity under the pull out drawer. Once there it freezes and when the frozen patch gets high enough, then the drainage just ends up on my kitchen floor.....This is a Kenmore Elite refrigerator model 795.75553401
3 Suggested Answers
  • 2692 Answers
SOURCE: layer of ice in freezer. How do I access drainage tube to clear i
It is in the freezer compartment but you can try accessing  it from the bottom where it goes into the drip pan. Try using a can of compressed air with a straw held tightly with your fingers and blow out the line backwards.
Not a lot of infor ar pictures in you manual . It does say to make sure it is level and shows hot to do so. See below:
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=AFD2535DE&siteCd=AMA
Posted on Jan 03, 2009
  • 385 Answers
SOURCE: kenmore elite model 52603100 freezer
You need to clean out the drain tube it's clogged that's why the water is freezing.Try using hot water and maybe something like pipe cleaners to get what's in there out.Hope this helps. On some models it may be easier to pull out the refrig from the wall and get to the drain from the back.
Posted on Jun 15, 2011
I have a kenmore fridge model number 64812 that is leaking water. The problem is I can't find any screws to remove the back freezer panel to clean the drain hole.
u more than likely have to remove the bottom plate first and the screws along the back wall are most likely covered with a plastic covering
Aug 02, 2014 | Kenmore Refrigerators
I have a kenmore elite 2 door, freezer on the bottom and I can't figure out how to remove the baskets from the freezer
hi! sometimes the door from the freezer has to be compleatly open in order for the
baskets to be removed and when pulled out they usually have to be lifted a bit to unlock from the grooves on the side
Nov 20, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore dryer,, looking for adiagram for the belt on a kenmore dryer
Below are the belt diagrams for Kenmore dryers.
Figure 1. Whirlpool-made Kenmore dryers with removable back panel, filter on top, and model numbers starting with 110 or C110.
Figure 2. Whirlpool-made Kenmore dryers with non-removable back panel, filter below the door, and model numbers starting with 110 or C110.
Figure 3. Frigidaire-made Kenmore dryers (model numbers starting with 417).
Mar 01, 2011 | Kenmore Dryers
Water freezing up in the bottom of the freezer
your defrost drain is stopped up then when it defrosts in steed og going down the drain its running in the freezer floor remove the back panel in the bottom of the freezer and clear the drain hole under the evaporator
Mar 12, 2009 | Kenmore 53642 / 53644 Side by Side...
Remove panel
the freezer panel has 2 fan motors, one for the i/m area and the other for cooling. there is 1 screw in the center of the panel, remove it and then the panel will have to be wedged out. it may seem like it is tight but go ahead and pull on the panel and it will come out.
before you can do this, you will need to remove the drawer and rails so you can get into the panel easily.
p.s. you didnt say why you want to remove this panel???
by the way, these units have problems with the fan motors causing poor cooling in the refr section.
Dec 27, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Elite trio
Hello bigmikeegator
Welcome!
You said, you have the Kenmore Elite Trio Bottom Freezer. You moved your refrigerator to a new home and removed the bottom freezer door, but can not seem to figure out exactly how to put it back on correctly.
It's too much for me to tell you myself.
This is easier!
Page 9 shows you how to remove and reinstall doors.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0523115.pdf
Thank you,
Huuum,
Please remember to leave a rating!
Oct 06, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice build-up in freezer - Kenmore Model C978-66795-2
don't know this appliance but for guidence:
some appliances have the evaporator in a compartment at the top of the freezer and the drain comes out of the back and runs externally to the drip tray. there should be a grill in the compartment so just peer into it and see if there is ice build up.
wherabouts is the freezer ice forming?
Sep 04, 2008 | Refrigerators
Bottom Freezer door handle
I had the same problem. It took me an hour to figure out that the bottom freezer handles clips onto the door using butterfly clips. To tighten the clips you have to remove the handle by sliding it to the right (or left??) It snaps right out with a quick **** exposing the clips underneath. A quick tightening of the clips and the handle snaps back in.
Nov 07, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
