Question about Husqvarna Huskylock Computerized 910
I need to know the correct 4 thread tention set numbers for standard serging.
    Novelist:
  • 192 Answers
You are posting in the 910 section. If you have a 910, put all of the tension dials on "N" for standard serging. That is the normal setting.
Posted on Aug 21, 2009
    Sniper:
  • 52 Answers
Needles are 4 or 5 and the loopers at 4 is a good starting setting
Posted on Jul 14, 2009
Stirch wont lock
Most often, serging issues are due to mis-threading. Because we don't know more about your stitching problem, that is the most logical cause.
ALWAYS have the presser foot RAISED when threading the machine. ALWAYS thread each thread in the order specified in the manual. Not following these two recommendations will cause most serger problems.
Usually, it is easiest to remove all the thread from the machine and start over from the beginning.
Mar 12, 2018 | Sewing Machines
I have multiple threads coming out the bobin space and making a mess of the back side.
called bird nesting and is a result of too loose a needle thread tension
if you use an automatic tensioner or using the numbers
and you still have a problem, the correct tension is a resistance to you pulling the thread prior to threading the needle
Feb 08, 2018 | Sewing Machines
How to setup tention
Set the tension dial to the midway point between high & low number. (This is the factory standard. )
Then test on pieces of scrap fabric from your project. The tension is correct when both upper and bobbin threads meet in the middle of the fabric. If the upper thread shows under the fabric, it is too loose. If the bobbin thread shows on the top of the fabric, the tension is too tight. You'll probably need to tweak the tension to get it where it should be. Tension is not static and depends greatly on the needle/thread/fabric you are using. User should get comfortable with adjusting it every time a new project is begun.
Apr 26, 2016 | Euro-Pro Sewing Machines
Does anyone have a suggestion? I have threaded the machine correctly but I cannot get the machine to sew.
You have a nice serger, so let's start with some basics:
Is your serger cleaned?
Go back to the instruction book and set the entire machine to the factory settings. For example, set all the dials to tension 4. Use quality thread which is made for your spool holder. Usually cones of thread work best. Use an appropriate fabric, not sheer, not very heavy drapery fabric. Make absolutely sure it's threaded properly. Finally, make sure all the threads are under the presser foot.....then start serging. If the serger still won't serge without tangling, it might be good to have it serviced. I find that buying a new serger is more useful than having a worn out one serviced. Good luck!
May 05, 2014 | Brother 925D Serger
The looper stitches are coming over the cut edge of the fabric. I have the cutting width set to WIDE.
you don't say what make and model serger this is.
However, as a rule of thumb, set the blade to widest setting, then test serge and tighten up the top and bottom looper threads to encase the cut edge neatly. So you would need to turn the dials on the two right hand knobs to a higher number, just move each dial one number at a time and test serge again.
The other possibility is that the thread is not between the tension discs properly, so check your thread paths, when you pull on the thread below the tension dial, it should feel firm to pull.
I always test serge scraps when sewing a new fabric and adjust the tensions to suit it before beginning a new project as a lightweight fabric will behave differently to a heavy fabric.
Apr 02, 2011 | Sewing Machines
Changed thread on serge pro SW 432. Now no chain or stitch.
Sergers can be tricky to thread.
Remove the thread.
Raise the antenna to it's highest position.
Open the tensions - setting zero.
Lift the presser foot.
Open the door on the serger and turn the handwheel until the upper looper is at it's highest point.
There should be a threading guide on the front of the machine or on the inside of the door.
Follow the threading sequence as this greatly affects the stitching.
Mar 13, 2010 | Simplicity Serge Pro SW432 Mechanical...
On what number should I put 7570 tention when
Refer to the manual. If you do not have a manual, start at 4 and work your way through the numbers, bit by bit until you get good results.
The bobbin thread should pull the top thread slightly under and to the back.
Machine embroidery bobbin thread is heavier than the standard size machine embroidery top thread and this also helps to pull the top thread to the back.
Mar 07, 2010 | PfaFF Creative 7570
I want to have my Juki MO-2516n do a mock safety stitch/4 thread
I have a Juki MO 2516N. It does not have the capability to serge 4 threads. The only options are 2, 3, and 5.
Apr 28, 2009 | Juki Sewing Machines
I need help with the tention settings on my simplicity serger pro please
All the problem that everyone had with the Simplicity Serge Pro are able to be fixed with the manual. I downloaded the manual from the Simplicity Home page: www.simplicityhomecare.com. That simple. Thank you for your assistance because you made me realize that I had to go get the answer myself if I wanted to get anything done yesterday. Waiting for 24 hours was just too long for me. There is also an 800-822-6691 hotline as well. I have already finished my project. Have a great day!
Nov 03, 2008 | Simplicity Serge Pro SW432 Mechanical...
Sewing Machines Logo
206 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
