Question about Samsung ML-2510 Laser Printer
Printing to output file instead of to printer
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Samsung Expert
  • 150 Answers
Hi, your printer fixing unit complaint ,check the paper out sncer or fuser pressure roller replace or printer fuser unit full set replace.
Posted on May 06, 2014
Tm u220 java
Are you printing from inside a java program (output) or from a java program editor.
Use the command to Open an output file, have all your output sent to the output file, close the output file properly before you exit the java program. After you finish send the output file to the matrix printer as you would with ASCII file. If the printer is installed properly, your OS should know where to send the output.
Dec 23, 2013 | Epson TM-U220 Matrix Printer
Can suretrak print directly to a pdf
If the program can print to a normal printer, then all you need is to download and install a 'pdf' printer such as PrimoPDF. Then when you print from within SureTrak, just choose the PrimoPDF printer instead of your normal printer and it will send the output to a PDF file. :-)
Mar 06, 2012 | Primavera SureTrak Project Manager 3.0 for...
I HAVE DONE MY INSTALLATION BUT MY PRINTER CANT PRINT WHAT SHOULD I DO
If you are using a new printer ,
  1. Check if you have installed the cartridges in the printer.
  2. Check if the cartridge has not dried up.
If you are using an old printer ,
  1. Check if the correct printer is selected during the print option dialog box , sometimes due to selecting a file printer like adobe pdf which prints a pdf file on a hard disk instead of an output via the printer you would feel that your physical printer is not working.
  2. Check if there are any errors or warning messages being displayed and make sure that you correct them.
May 10, 2011 | HP DeskJet F380 All-In-One Printer
Hi my printer will not print. it is saying printer spool error.
> spool error
S.P.O.O.L. == Simultaneous Peripheral Output On Line
The "spool" is a combination of disk-space on your 'C:' drive, and software to "accept" the print-image (as fast as MS Word can create the print-image), and save the print-image to disk-space,
so that MS Word can report "print completed", so that you can use MS Word, instead of waiting until the physical printing has completed.
Then, the printer-spooling software will read from the print-image file, and send it to the printer, only as fast as the printer will accept it.
Feb 05, 2011 | Xerox Office Equipment & Supplies
Since yesterday I am unable to print documents that open in Adobe format, although was able to do that before. Now when I click on "Print" button, the pop-up window tells me to Print to File and Output...
Instead of click the Print button go to File menu, then Print, and THEN select your printer.
It seems you don´t have your printer set as default.
Let me know if it worked before leaving negative feedback. So we can still try.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
Thank you
TechSaver
Feb 15, 2010 | Office Equipment & Supplies
What is print to file? What is output file name?
It is windows way of storing a document for printing later.
It will save the job you want to print at another time but ask you for a file name so that you can give it a name you will remember.
It will do this if it is set as the DEFAULT printer.
To change that and provided you have a printer installed then go to CONTROL PANEL / printers and faxes / then right click on the printer you want as the default and on the box that opens will be that exact option, click it and you are done. it wont ask you those questions again.
If this information was useful please click below
Aug 19, 2009 | Konica Minolta magicolor 2550 EN Laser...
Does not print. Asks for output file instead.
The default printer is set to be "file". Here's what you must do:
- Go to printers dialogue box and right click on your printer name and selectd "Set s default printer"
 - Right click on printers name and chose Properties. then look for a check box saing something like "print to file" and unchek it.
This sould resolve the problem.
Best regards
Nov 12, 2008 | HP DeskJet F380 All-In-One Printer
Won's print pdf files
Trouble with the HP Laserjet printed output may be solved by using the following settings (or similarly named ones): "Use raster Graphics" (instead of "Use vector graphics"). This may fix the problem of "reversed" text (white on black background) not printing, as well as other problems. "Download TrueType Fonts as bitmap soft fonts" (select "bitmap" instead of "outline" or "graphics"). This may remove the overlapping of text on the printed document. "Graphics dithering" select "coarse" or "fine" (instead of "none"). This selection may improve the quality of images contained in the document. You can find all these settings in your printer properties. Go to File, Print, click Preferences, in Printing Preferences, click one by one all the top options, and change one of the top solutions, one at the time, checking your printing output. Always check if you have the latest version of Adobe Reader Program. If not download the latest version from Adobe, it's free. Is this the first time that you have the problem? or with the same printer (HP 4si), did you were able to print PDF files in the past?
Sep 10, 2007 | HP LaserJet 4si Printer
Samsung ML-2510 Laser Printer Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
