Question about Sony Vaio Sve15128Cxs Laptop Computer - 3Rd Generation Intel Cor
Usb disconect error
When I touch any USB cable, the connected device is switched off and on again, and again. In summary, the USB connectiond is highly sensitive. My doubt: is there a hardware problem o software?
    Top Expert:
  • Sony Master
  • 22,152 Answers
Damaged USB socket. I would think.
Posted on Apr 19, 2014
Restore software for ipod 16GB touch
i would be checking the usb lead before doing anything or even replacing it with a new one make sure iis securely connected
the cable near the iTunes symbol represents a problem with the cable
and the cd will not not be able to activate without a connection
Connect one end of the USB sync cable to one of your computer's unused USB ports, and connect the other end to the bottom of the iPhone or iPod Touch.
If iTunes does not start on its own, run it using the desktop or Start menu shortcut.
When iTunes starts, you should see an icon for the iPhone or iPod Touch on the left side of the window.
Click "Summary" in the right pane of the window if it is not already active.
Click the "Restore" button to begin the device restoration process.
ITunes displays a message asking if you want to save the contents of the device to your computer before restoring it.
If you have not backed up the device already, click the "Back Up" button.
If you have already done this, click "Don't Back Up."
Click "Restore." ITunes clears the data from your iPhone or iPod Touch and reinstalls the device's original firmware.
The screen of your iPhone or iPod Touch may shut off while iTunes works.
Do not remove the USB sync cable.
When iTunes is done restoring the device, it displays a message letting you know that the device is about to restart.
Click "OK" to restart the device. If you are restoring an iPhone or iPod touch, wait for the "iPhone / iPod touch is activated" message to appear on the screen of the device before you disconnect it from the computer.
You may now restore your backup of the device or remove it from the computer.
hope this helps
Sep 15, 2012 | Apple iPod touch
Error flashing on screen
switch off your stuff and unplug all the power cord so that all setting go back to previous state.
after 10 or 15 minutes plug all the power supply and switch on.
If same happen, notify me again.
Dec 28, 2007 | Philips HTS3450 System
Error code cood124d
One of two solutions to try
First, hold back arrow button and up on the touch pad (non-touch screen version) until it resets, then try to sync again.
If no go...
Next, connect the device to a true 2.0 usb port, try not to use any usb ports on your monitor or keyboard, connect the Zune directly to your PC and then try.
Lastly, not a troubleshooting steps per se, but try a different Zune cable as the 1st generation cables are thin, slow, and are easily damaged.
Hope this helps!
Jul 09, 2010 | Microsoft Zune 2nd Generation Digital...
My 3gs iPhone is stuck in restore needed/emergency call mode. I've tried to sync to different computer...same problem. iTunes does not recognize and then when I try to restore it gives a 23 error or 2001...
Use the following steps to place your device into recovery mode. If the device is already in recovery mode, you can proceed immediately to step 6.
Disconnect the USB cable from the iPhone or iPod touch, but leave the other end of the cable connected to your computer's USB port.
Turn off the device: Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPhone or iPod touch to turn off.
If you cannot turn off the device using the slider, press and hold the Sleep/Wake and Home buttons at the same time. When the device turns off, release the Sleep/Wake and Home buttons.
While pressing and holding the Home button, reconnect the USB cable to iPhone. When you reconnect the USB cable to iPhone, the device should power on.
Note: If you see the screen pictured below, let the device charge for at least ten minutes to ensure the battery has some charge and then start with step 2 again.Continue holding the Home button until you see the "Connect to iTunes" screen. When this screen appears you can release the Home button:Use iTunes to restore the device.
If you don't see the "Connect to iTunes" screen, try these steps again. If you see the "Connect to iTunes" screen but the device does not appear in iTunes, see this article and its related links.
When using recovery mode, you can only restore the device. All user content on the device will be erased, but if you had previously synced with iTunes on this computer, you can restore from a previous backup. See this article for more information.
Jan 17, 2010 | Apple iPhone 3G Black Smartphone
Iphone will not restore error 13
You can resolve the restore issues using the troubleshooting steps found in this document:
1. Update to the latest version of iTunes
To see if you have the latest version of iTunes, open iTunes and check for updates.
  • Windows: Choose Help > Check for Updates
  • Mac: Choose iTunes > Check for Updates
If there is an update to iTunes available, install the update and try to restore again. If you do not have an active connection to the Internet, or your Internet security settings are configured to prevent iTunes from communicating with Apple, iTunes will alert you that the iTunes update server could not be contacted. Resolve your Internet issues and attempt to update again.
2. Restart your computer
Simply restarting the computer can clear up certain issues that could prevent you from restoring iPhone or iPod touch. After you restart, try restoring the device again in iTunes.
3. Open the proper ports and allow access to Apple servers
During the update and restore process, iTunes needs to contact Apple. Ensure that your computer has the following ports open and can access these servers:
Port 80
Port 443
phobos.apple.com, albert.apple.com, gs.apple.com
If you see "Error 9807", you must open access to the following VeriSign servers:
evintl-ocsp.verisign.com
evsecure-ocsp.verisign.com
If you are using a Windows operating system, you can follow this article to help resolve issues caused by third-party security software.
You may need to update, properly configure, disable, or uninstall built-in firewalls and other security software to prevent interference with iTunes. For assistance with this, contact the company that supports the firewall or security software you use. If you are using proxy settings, try to restore or update without using a proxy.
4. USB Troubleshooting
Connect iPhone or iPod touch to a different USB port on your Mac or Windows PC. USB 2.0 ports that are built in to the computer are preferred over a hub. If you tried connecting iPhone or iPod touch to USB ports on the front of the computer, try connecting them to rear USB ports. After doing this, try to restore the device in iTunes.
If the issue continues:
Remove all USB devices except the keyboard, mouse, and iPhone or iPod touch. Remove all USB hubs and connect directly to the computer.
Connect iPhone or iPod touch directly to the included USB cable, bypassing the dock.
Restart the computer.
Try to restore the device again in iTunes.
If available, test with alternative, known-good USB cables.
5. Restore on a different computer
If the issue is not resolved with the above steps, try to restore using a different computer. Ensure that the computer you use has USB 2.0 ports, the latest version of iTunes, and that you connect directly to the computer.
If another computer is not available, proceed to the Advanced Steps below.
Oct 17, 2009 | Apple iPhone 3G
When I try to sync my itouch I get an error
Try restoring it...here's how...
  1. Disconnect the USB cable from the iPhone or iPod touch, but leave the other end of the cable connected to your computer's USB port.
  2. Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPhone or iPod touch to turn off.
  3. Press and hold the Home button while reconnecting the USB cable to iPhone. When you reconnect the USB to iPhone, the device should then power on.
    Note: If you see the message "Charging... Please Wait" , let the device charge for at least 10 minutes to ensure the battery has some charge and then start with step 2 again.
  4. Continue holding the Home button while iPhone starts up. While starting up, you will see the Apple logo.
  5. When you see "Connect to iTunes" on the screen, you can release the Home button andiTuneswill display the recovery mode message:
    If you don't see the "Connect to iTunes" screen, then disconnect the USB cable from iPhone and repeat steps 3-6.
Sep 08, 2009 | Apple iPod touch
What do i do when i my ipod touch says ipod touch says ipod is disabled
Sep 07, 2009 | Apple iPod touch
Ipod touch will not charge r connect to computer
When i switch on my ipod touch, it's telling me to connect to my computer and when I do connect, it's still the same thing
you may have to restore it....but you'll lose all your data here's how...
  1. Verify you have iTunes 7.5 or later. Apple recommends using the latest version of iTunes.
  2. Disconnect the USB cable from the iPhone or iPod touch, but leave the other end of the cable connected to your computer's USB port.
  3. Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPhone or iPod touch to turn off.
  4. Press and hold the Home button while reconnecting the USB cable to iPhone. When you reconnect the USB to iPhone, the device should then power on.
    Note: If you see the message "Charging... Please Wait" or you see the screen pictured below, let the device charge for at least 10 minutes to ensure the battery has some charge and then start with step 2 again.
  5. Continue holding the Home button while iPhone starts up. While starting up, you will see the Apple logo.
  6. When you see "Connect to iTunes" on the screen, you can release the Home button and iTunes will display the recovery mode message:
Sep 06, 2009 | Apple iPod touch
How do i unlock ipod touch 8gb
Sony Vaio Sve15128Cxs Laptop Computer - 3Rd Generation Intel Cor Logo
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
