Question about NCR Computers & Internet
Configuracion ncr 7875 - NCR Computers & Internet
ansari03
SOURCE: NCR 7875 SCANNER/SCALE
Hello
Well regarding this error sending you this display of the scanner in most cases is needed because if the scanner calibration, you have to do is:
Remove the dish from scanner (where you put the products to weigh), there you will see that has a plastic part on the right side, and take away that the bottom is a black button color you need to start to put pressure gauge.
Once you press this button, and is ready to start calibrating, then put him back to the plate and the scanner with a voice that sends you will be asking some weight, so this should have on hand your weights to calibrate the scale.
First the scanner asks 0 kg. in this step not going to put anything in weight, ahi press the button Scale Zero appearing in the panel's scanner,
After asks you to 2.5 kg, is there when you need to put the 2.5 kg asks you, when you have them placed on the plate press Scale Zero, the scanner then will ask now that you put 5kg, then you take away those who had 2.5kg and you put the 5kg, and when you have 5kg in the dish press the button Scale Zero, now the scanner will ask that you put 10k, then take away the 5kg and that he had put the 10k that asks you to press the button and Scale Zero, and finally asks you to the scanner in this 0Kg, then you take away the 10k and leave it with nothing, and press Scale Zero
If the calibration did well Scanner you send a voice message that says Calibration Complet or calbración completed, it is very important that when you calibrating the scanner is not moving or having obstacles that may make the calibration is not made well, good clean plate and that this part of the bottom, which revises the 4 Gomito that has to sustain the plate are complete, that are not broken up or are some more than others and that when you put the dish did not move. fijate also not hit the plate or the chassis of the scanner with something else, so there's no obstacles in the calibration,
If you salio calibration is not well in the display will show a 9Error, this means that there was interference during calibration, it is required to check well before the scanner or do a cleanup.
Posted on Jun 30, 2008
SOURCE: Enabling NCR 7875 flatbed scanner to read Code 128 barcodes
On a 7876, you need to scan the sequence “17130” is to add 128 tag readability. Not too sure if the 7875 is the same.
Posted on Feb 20, 2009
SOURCE: Reading Small barcodes using NCR 7875 Scanner
we've had the same problem and usually it is a programing issue,Go to the MFG website and get the barcode program and that should help
Posted on May 21, 2009
doomage
  • 37 Answers
SOURCE: I need the software to operate my NCR 7875-2000.
go to the makers website
Posted on Nov 03, 2009
SOURCE: MANUAL CALIBRATION SCALE SCANNER NCR 7875
codigos de barra para configurar scaner 7875-2000
Posted on Sep 05, 2010
Jul 22, 2010 | NCR 7875
I know there is a set of bar codes you can scan on the NCR 7875
Yes sir, I think NCR refers to them as "hex tags" but anyways one of the hex tags is labeled "Diagnostic" I think that is the one that will tell you the current settings. I found the tags on the manual for a different model (pages 282-296 on the pdf in the first link). After you get the tags printed from this link just use the manual for 7875 (second link) model to know what sequence to scan these tags good luck! http://ncrpr.ncr.com/web/rsdmkt/dealerReady/docs/User_Guides/HighPer_Scanner-User-Guide.pdf
https://docs.symbol.com/manuals/3765801a.pdf
Apr 03, 2010 | NCR 7875
I need to find the power requirement info for an NCR 7780. One of my cusotmers is relocating one and needs to find the power connector
The power supply for a 7875-2XXX series
PN: 497-0435538
input: 100V-250V
Output: +/- 5V -- 1.5A
-12 v --- 0.3 a
Capital Computer Group, LLC
651-405-8293
www.capcom-ncr.com
We specialize in the NCR arena, also have many other point of sale needs.
Free bench testing equipment failure on any p.o.s hardware item.
Mar 26, 2010 | NCR 7875
NCR scanner scale 7875 communicating with pc
You would need a PC to communicate it with. Either Via USB or the DataRX port.
651-405-8293
www.capcom-ncr.com
Mar 18, 2010 | NCR 7875
Apr 08, 2009 | NCR 7875
Feb 18, 2009 | NCR 7875
Need to add an NCR 7837 to an NCR 7875
i lost my scanner installation disk for model NCR-7837, how can i get it to install?
Jan 15, 2009 | NCR RealScan 7872 (787220509090) Fixed...
7875 read two times one tag
Hello
This problem can be solved with some configuration that there are tags for 7875-2000 NCR scanner, what is here is the set of EEPROM targeta NCR scanner that brings you to continue to double reading of products
Jun 11, 2008 | NCR 7875
Computers & Internet Logo
48 people viewed this question
Top NCR Computers & Internet Experts
John Hong
John Hong
Are you a NCR Computer and Internet Expert? Answer questions, earn points and help others
