Question about Canon ImageRUNNER 1670F Copier
Check toner/drum crg error, canon ir1210 printer
4 Suggested Answers
muleskinner2
  • 270 Answers
SOURCE: I have a canon imagerunner 1630 had a paper jam
Before reinstalling the drum make sure the Developer unit is correctly attached to the drum unit. The two clips ( Blue slides on top ) keep the two items together. Canon had two screws that were to added make sure the two stay together when removing the drum. Anyway make sure the drum is squarely installed with you insuring the rear is pushed all the way down. The sensor is located below drum near the entrance to the fuser. Good Luck
Posted on Apr 07, 2009
  • 114 Answers
SOURCE: 'check toner/drum crg' error, Cannon imagerunner 1370f
check the contacts inside of copier cavity where they line up with drum unit and make sure they are in correct position.
Posted on Mar 21, 2010
  • 254 Answers
SOURCE: my copier was working just
hello
remove the paper jam and close the front cover and unplug the power from the outlet and same at the back of the printer, wait for 5 minutes and plug it again. this will helps to clear the error code of the printer.
thank you
Posted on Mar 08, 2011
Where are the cartridges located to install new ones?
http://software.canon-europe.com/products/0010476.asp
try to download the manual from the above link and check there.
Howver you can also check it on the lid. instructions are given. This should be very easy as we need to pull out the tray and replace the cartridge. signs and signals are given on the printer itself.
Apr 29, 2011 | Canon iR 2022i Printer
Printing black
is the copy/print full black or have streaks or have dots, or ...
First, remove the toner crg., and check the drum surface if it has toner leftovers or spots or streaks, or... if so replace the toner crg.
btw. It also can be the fixing unit, but if these is the problem then the toner will not be "baked" on paper and it can be wide solid black stripe on corner.
Hope that helps!
Jan 10, 2011 | Canon imageCLASS MF4150 All-In-One Laser...
Dark copies
First remove toner crg and check the drum, if its covered with stripes or toner, replace toner crg.
It also could be fixing film fault.
Nov 16, 2010 | Canon imageCLASS D320 Digital Copier
Canon Super G3 Laser Classs310 all in one. Has lines in copies and when receiving faxes and sending faxes. How do I resolve this problem?
Check toner crg. if there are streakes on drum change toner crg.
If not there is problem with fixing system.
Jun 07, 2010 | Canon Office Equipment & Supplies
ERROR MESSAGE 810?
E810 and/or "CHECK TONER/DRUM CRG" message on control panel.
Something is not right in the drum unit. Make sure that the drum unit and developer units are attatched together at the front and rear.
Use caution when removing, the drum is light and scratch sensitive.
If all is well there, either call a service tech or replace the drum unit
Jun 07, 2010 | Canon imageRUNNER 1310 Printer
Why do I have a black line on my copies? I have the Canon imageClass D480 Multifunction copier
Pull out the toner crg., and if there are streaks on the drum, replace crg. If there is no streaks on the drum, clean the copy glasses.
May 22, 2010 | Canon imageCLASS D480 Black and White...
Mar 01, 2010 | Canon ImageRUNNER 1670F Copier
System Error E810 - how do I fix?
Something is amiss in the drum unit. Make sure that the drum unit and developer units are attatched together at the front and rear. Use cation when removing, as the drum is light and scratch sensitive.
If all is well there, either call a service tech or replace the drum unit(expensive) approx. $135 for GPR 10 Drum unit.
Jun 02, 2009 | Canon imageRUNNER 1370F All-In-One Laser...
I have a canon imagerunner 1630 had a paper jam and had to pull drum to get it out, now can not get it back in correctly, display reads check toner/drum crg
Apr 06, 2009 | Canon imageRUNNER 1630 Copier
Canon ImageRUNNER 1670F Copier Logo
246 people viewed this question
old marine
old marine
