Question about Fusion Car Audio & Video
Amp goes into protect mode when engine is running
Fusion 2000 watts amp works fine when on ignition but when engine is running it goes into protect mode
thesoundman
  • 41 Answers
SOURCE: prower acustic amp in protect mode
1) Make sure the amp is properly connected to +12V power source. 2) Make sure the amp is grounded well, directly to metal - if you have a voltmeter, an easy way to check the first two is to see if there are 12 volts across the power and ground wires. 3) Make sure the speaker output wires aren't touching each other. If none of these are the case, there is an internal problem with the amp and it should be serviced or replaced.
Posted on Sep 21, 2007
SOURCE: amp staying in protection mode
No, this amp is not a heavy power consumer- matter of fact it takes very little power to run.Maybe you should check the fuses on the amp to see if they are what is recommended.Also check your fuse kit to your amp- your fuse might not be big enough.If neither works take it back where u got it.
Posted on Jan 02, 2008
  • 631 Answers
SOURCE: 2000 watt legacy predator amp
Disconnect all speaker wires from the amplifier's speaker terminals and disconnect the RCA cables from the amp. If the amp still goes into protect, it probably has shorted output transistors.
Posted on Feb 17, 2008
  • 631 Answers
SOURCE: mmat amp 1200 watt
If the amp is in protect mode, it probably has shorted output transistors.
What model amp is it?
Posted on Aug 20, 2008
SOURCE: the amp turns on but goes to protection mode
Have you checked the REM wire, if it is the wiring may have gotten fried.
Or you may need to get new parts replaced within the amp.
Both issues happened to me.
Posted on Mar 27, 2009
Jbl am in protect mode
if it goes in protect mode means ur amp is turn up to high or it is over heating so it protectn it from fryn ur amp try to adjust it down
Jul 12, 2009 | JBL BP1200.1 Car Audio Amplifier
How do I fix the problem so they work again.?
A 1000 WATT AMP HAS PROBABLY GONE INTO PROTECTION MODE BECAUSE YOU ARE TRYING TO RUN 1600 WATT SUBS COMBINED
Jun 08, 2009 | Car Audio & Video
FE-300D a good amp ?
if its a 2 channel amp you can only run in stereo mode can not bridge amp will get hot
May 23, 2009 | Fusion FEW12PK Car Subwoofer
Fusion car amp turns on then gos in protect mode
look behind ur headunit could b a wire touching or a piece of metel
Apr 08, 2009 | Car Audio & Video
Kole amp in protect mode?
Are you setting the bridge switch for both left and right or are you trying to run both subs off of one set of terminals? If you running the subs off one set of terminals you are effectively running the amp below 2ohms and thus the amp is not 2ohm stable and you will destroy it.
Some amps actually all ready run a bridged output for left/right operation, this could also be the reason why the protection circuit is kicking on.
Either way it's a component mismatch and you either need a stronger amp or different subwoofer setup.
Mar 09, 2009 | Kole audio Nitric XP2-2000 Car Amp
Car audio amp in protection mode
If you power up the amp with the RCAs plugged in, does it go into protection mode.
If you power up the amp with the RCAs plugged in, does the woofer pop?
Oct 26, 2008 | Pyle PLAD413 Car Audio Amplifier
My Amp
sounds like the sub that throws it into protect mode is cross wired pull sub out and make sure they are wired right make sure ground from sub goes to ground on box and do same for power wire
Jun 11, 2008 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
Fusion Amp Starts In protected Mode
check remote wire coming from back of radio
Jan 08, 2008 | Fusion FEW12PK Car Subwoofer
Audio bahn 1205n
sounds like your over working your amp 800 watt on a 2000 watt sub. might wanna upgrade your amp
Nov 28, 2007 | Lanzar 2H 1000W MOSFET AMP Car Audio...
Amp not working correctly goes into protection
Disconnect the speaker wires from the amplifier and see if it still goes into protection mode. If it still goes into protect with the speakers disconnected, there's a problem with the amp; if not, you may have a blown speaker or a shorted speaker wire.
Feb 22, 2007 | Legacy LA2098 Car Audio Amplifier
Car Audio & Video Logo
Top Fusion Car Audio & Video Experts
Matthew Spark
Matthew Spark
Tygh Duval
Tygh Duval
Are you a Fusion Car Audio and Video Expert? Answer questions, earn points and help others
