Question about Microwave Ovens
My frigidaire model # ffmv164lsa microwave oven keypad does not seem to work. Some times it goes on by itself. Or if you unplug it 05 will go on. Cant set the clock. or if touch anything nothing happe
Keypad does not work right. Sometimes you might be able to touch a quick start button to cook something or even turn light or exhaust fan on or off. Can not set clock. If you unplug and wait you might able to use it. I think usually after you plug it back in 05 is on the display. Then sometimes when you are not even touching anything the microwave is on. It came with the house brand new. We have been here since last June. The date on it says 2013
  • Mark Doyle
    Mark Doyle Apr 19, 2014
    Anybody no. Did not get answer?
  • Microwave Ovens Master
  • 842 Answers
The answer you seek is to replace the keypad. Your unit is Stainless for you would have to replace the console as one piece part number 5304477377 I this helps. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Posted on Apr 22, 2014
MicrowaveSvc
  • 9098 Answers
SOURCE: LG 1925 Microwave suddenly stopped cooking, other functions work fine!
What you said about the the clock leads me to suggest that you first unplug it for a few minutes then plug it back in. It may just need a good reset. If you don't have your owner's manual you can download one here: http://www.lge.com/support/manual.jsp The mention of odor concerns me. It may just be a bit of food or grease on the waveguide cover, which is a small sheet or panel on the wall or ceiling of the cooking cavity, but it may indicate the failure of a part in the high voltage section. You may have an intermittent door switch. You can see some of my other responses for info on how to get our important text file that helps you diagnose and repair door switches and gives important safety tips.
Posted on Dec 11, 2006
MicrowaveSvc
  • 9098 Answers
SOURCE: trouble shoot microwave
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
Also, are any other of your electrical items (light bulbs, DVDs, etc.) failing lately? This could indicate improper power line voltage.
Let us know if the hard reset doesn't fix it.
Posted on Jul 18, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Samsung MW1080STA Microwave Oven
This is due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or maybe the wire mesh RF gasket was not installed or got pinched.
It may also need a new high-voltage diode and stirrer, and the cavity may be affected.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
You can order Samsung parts here.
You can find your nearest Samsung-authorized service center here.
To find out if yours was recalled, please call Samsung's Service Division at 800-932-3837.
Posted on Nov 21, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave Oven Does Not Start Cooking
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
If yours is not shown at the parts site or manual site linked above, Please reply back with your brand and model number so we can help you.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
Posted on Dec 25, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Touch sreen won't work
I would suspect it either needs a hard reset (unplugging it for a few minutes, then trying again) or the membrane keypad is failing.
Instead of JMV1540BMC01, it would probably be one of these models:
JVM1540DM1BB
JVM1540DM1CC
JVM1540DM1WW
JVM1540DM2BB
JVM1540DM2CC
JVM1540DM2WW
JVM1540DN1BB
JVM1540DN1CC
JVM1540DN1WW
JVM1540DN2BB
JVM1540DN2CC
JVM1540DN2WW
JVM1540LM1CS
JVM1540LM2CS
JVM1540LN1CS
JVM1540LN2CS
JVM1540SM1SS
JVM1540SM2SS
JVM1540SN1SS
JVM1540SN2SS
Since FixYa is not currently notifying us Experts when Clarification Requests are answered, feel free to contact me directly (and please include your full model number from the tag in or on the unit) for a free estimate and free tips & do-it-yourself advice.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Oct 11, 2009
Frigidaire microwave model FFMV164LSA. Have a new touch screen to replace bad one. Need to know how to remove vent to access screw holding screen.
For disassembly info, you can watch the video at my site, or see these text files: http://www.microwavecontrol.com/safety.htm
http://www.microwavecontrol.com/disassembly.htm Feel free to contact me directly (see below) if you have other questions.
.- William E. Miller, AS-EET
pupista@gmail.com
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Nov 29, 2017 | Frigidaire Microwave Ovens
Frigidaire microwave model ffmv164lsa constant beeping, with little symbol to the top left hand side of the clock displaying with the beep.
Hopefully no one sprayed a liquid cleaner directly onto or near the keypad...
From page 23 of the owner's manual:
"Wipe the microwave oven inside and out with a soft cloth and and warm (not hot) mild detergent solution. Then rinse and wipe completely dry."
"Clean the outside surface of the microwave with soap and a clean damp cloth. Dry with a clean soft cloth. To prevent damage to the operating parts of the oven, do not let water seep into any vents or openings."
If there is moisture damage, it may dry out by itself if you leave it overnight with the door open. If not, the warranty would be voided and you'd have to arrange for out of warranty service.
If there is no moisture damage, and it failed not due to outside forces, then you should contact the manufacturer to arrange warranty service.
Oct 05, 2016 | Frigidaire Over-the-Range Microwave
Frigidaire microwave ffmv164lsa constant beeping, with little symbol to the top left hand side of the clock displaying with the beep. Keypad not responding to presses. Unplugged the unit the problem r
Hey JT Tai, I appreciate your post!
The symbol at the top left hand side of your display could be child lock symbol or vent symbol. If it is the child lock you should be able to press and hold the stop/cancel button down for 3 seconds to release the child lock.
If the light is on for the vent I would seek assistance from a professional for proper diagnosis and repair to be completed on your microwave. I hope this is helpful. -Matt
Oct 12, 2014 | Frigidaire Microwave Ovens
Unlock frigidaire microwave model FFMV164LSA
Good Afternoon Friend,
I understand you are trying to unlock your Frigidaire microwave, model# FFMV164LSA. This has two different meanings to me. First, if the door is locked and will not come open, I suggest contacting your local authorized technician. Secondly, the control lock is on. If the control lock is on, you will need to press and hold down the "Stop/Cancel" button for 3-5 seconds, to unlock it. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your microwave status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 30, 2014 | Frigidaire FMT118E1W Microwave Oven
My Frigidaire ffmv162lw Microwave just shows "0:05" on the display and no buttons work.
You have a shorting membrane keypad. And you are correct - if and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and of course one should never leave a microwave unattended while cooking, especially if it's doing this!
The details of my answer assume that your model number (from the tag on the microwave, not the manual) is FFMV162LWA (white). If not, please let me know.
On these models, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job.
You can order part number 5304477374 from the Sears Parts Direct Web site for $98.65 (prices subject to change).
There is a video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then detach the keypad connector as shown in the photo below, and then remove the control panel screws.
Be careful not to crack the glass display when handling it, or it's a goner.
Reassembly is the reverse of disassembly.
Feb 16, 2014 | Frigidaire FFMV162LW Microwave Oven
Frigidaire Microwave Plastic on KeyPad
Many are shipped with a protective sheet over just the keypad. Your owner's manual should address that if it needs to be removed upon delivery.
If not, then the keypad itself may be worn.
If it all works, and does not do come on or do anything by itself (which poses a fire hazard) then it may just be wear.
No action is necessary until some pads fail to activate or the oven comes on or does anything by itself. Then repair is necessary.
At that time post a new help request with the full model number from the tag on the oven (not the manual) and exact symptoms - what it's doing or not doing, and when.
Feb 15, 2014 | Frigidaire FMV156DC Microwave Oven
My Frigidaire microwave display reads "LOCK" and it will not work. What should I do?
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If it is still locked or goes into lock mode by itself, the "clear" key on your keypad may be shorting.
Here's how the child lock works on model FMV145:
Child Lock-Out
You may lock the control panel to prevent
the microwave from being accidentally
started or used by children.
To lock or unlock the controls, press and
hold CLEAR/OFF for about three
seconds. When the control panel is
locked, an "L" will be displayed to the
extreme right.
You can find your manual here.
If you think the controller or keypad may have failed, see us here or order parts here.
Nov 24, 2010 | Frigidaire FMV145K Microwave Oven
Microwave Ovens Logo
873 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
