Question about Briggs & Stratton Garden
Not getting gas - Briggs & Stratton Garden
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 26 Answers
If there is a cracked or loose fitting fuel line, air can get in and interfere with the suction needed to draw up from the tank.
Another possibility, if it has been sitting for a while: you might have built up just enough "shellacking" inside the carb to interfere with fuel delivery - might try spraying some throttle body cleaner into the air intake - let it sit for a few minutes to dissolve any build up it can get to, then spray in a bit of starter fluid and give it another try to see if the fuel will draw through the build up; if this is the problem and you can get it to run, it will dissolve any remaining buildup after a few minutes hot.
Posted on Apr 21, 2014
I tried to get gas to come to the primer bulb but it wont. Now what?
needs new gas lines if your gas has ethanol in it melts the gas lines I use 100% gas its out there, the gas filter might be full of water fish it out of the tank dry it out with rags and a hair dryer or go get a new one take it with you so you get one that fits, good luck
Jun 07, 2014 | Troy-Bilt TroyBuilt Hand Held Gas Blower
Kenmore range will not light, not getting gas flow.
Have you purged the gas line to get gas to the range? What is the model number?
Feb 10, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Does this valve have a standing pilot? if not, if my hot surface ignitor lights up and the furnace fails to light would you consider it to be a faulty gas valve? I am getting a constant 24 volts fro
If your getting 24 Volts to the gas Valve and the gas Valve is not opening replace your gas valve If your not getting a full 24 volts check your Transformer and the ground to the gas valve.If the gas valve still does not open change the Gas valve.
Nov 18, 2013 | Honeywell Furnace Gas Valve Sv9501h2409
Gas tank
Un hook the gas line,.drain all gas out.Get a rag,stuff it in gas tank.Get a 1/2 inch dowl.About 7 inches long.Stir the rag inside gas tank.Take rag out,put new rag in tank Swish around inside tank.Get as much as you can out of tank.when you get it Quite clean,add /spray Carb cleaner into the tank.And some gas,drain again until its clean.Only enough gas to swish around.You can see inside tank with a mirror.
Jul 24, 2013 | Craftsman YT 4000 42" Briggs Stratton 24...
Does not ignite, no gas getting to unit to ignite. Gas supply is on.
More than likely your gas valve or control board is malfunctioning. You can use a multimeter to check for voltage at the gas valve when the furnace calls for it. In sequence, the IDM will come on, then another click that starts the ignitor which glows, then the next click will be the board sending power to the gas valve. You should have 2 wires on the gas valve, put the meter leads there and when the board calls for the gas valve, you should have 24v at the gas valve. If not, the board is faulty. If you do have the voltage there, the gas valve is faulty and needs replaced. Sometimes you can take a pair of pliers or similar tool and gently knock on top of the gas valve and it will get the valve "unstuck" which can get you some heat if needed. Hope this helps!
Nov 28, 2011 | Goodman GMS90703BXA Heater
Pilot will not light, seems to not be getting any propane to it. The regulator on my propane tank works fine. What could be the cause?
I would trace gas line out and determine were you are getting gas and where it is not. With the gas on I would carefully loosen union or flex fitting going to gas valve.If you have gas there then retighten union and go to fitting on pilot line and check it.You should be able to get gas there by depressing pilot light button.If you have gas there then go to pilot assembly and remove it from gas valve and burner. Remove pilot orifice and carefully clean and blow thru pilot line to make sure it is not obstructed.
If you cannot get any gas thru gas valve then shut off gas before valve and remove inlet line. There should be a fine mesh steel screen there. Make sure it is clean.If you are getting gas to gas valve but not thru it then you probably need to replace gas valve. Thank you
May 17, 2011 | Procom ML060HPA Heater
Won't start its like its not getting gas. I can turn the key and pump on the gas it will rev up and shut off. I thought it was the fuel pump so I changed it and that didn't solve the problem what else can...
maybe its bad gas, or an idle issue. you shouldnt have to pump the gas when you start that can actually lead to flooding the engine with gas. Turn the key on and wait about 30 secs before cranking this will ensure your getting proper amount of gas to injector lines. It may take a bit to get rid of gas in there but keep doing it until it starts properly. Also note in doing this do not continuously crank it as the starter and solenoid will fry. Also if you fear there is no gas going to engine look for a gas line bleeder valve. Looks like a tire valve head and usually is covered with a black plastic lid. If you push it in and gas squirts out then your getting gas to engine. If you release all gas and turn the key on and test gas line again and no gas comes out then its what is called a dry start, aka no gas getting to motor. Hence failure of fuel filter or fuel pump. Or a general clog in gas line.
Aug 18, 2010 | 1994 Chrysler Concorde
Disconnected intake hose from gas tank to primer bulb
is gas line broke or disconnected? Either way it has to be reinstalled.First, get new gas line, and be sure to get it longer then you need, because, you will need to cut a sharp angle on one end then install this end into gas tank, then reach thru gas cap opening with needle nose pliers, get ahold of fuel line and pull thru. if you do not cut angle on new fuel line, you will never get the line into gas tank.
Apr 29, 2010 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
My gas grill is not getting gas to the burners.
most likely it is regulator and hose
Jul 29, 2009 | Grilling
Garden Logo
20 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
