Question about Pyle Pro - PTCDS2UI - Classical Turntable With AM/FM Radio/ CD/
Turntable won't turn pyle pro
No matter what I do, having the turntable set to phonograph and the lever lifted, the turntable never begins to spin. Seems like it's only taking from the unplugged AUX cord when set to PHO
  • Nick Buran
    Nick Buran Apr 20, 2014
    It's the pyle pro PTCDS2UI. And sorry I worded that first response wrong wrong. On this system the aux setting and phonograph setting are the same, and the turntable is just meant to start when you move the needle. I was able to get it to spin normally once, and it hasn't since. I know these aren't made in the highest quality(just from online reviews) but thought it was possible it could just be a loose mechanic or wiring on the inside since I was able to make it spin once. But I'm no expert haha
  • Larry Fostano
    Larry Fostano Apr 20, 2014
    Yes it sounds like you will need to take it apart and do some investigating,if it worked once ,more than likely it is something loose.Good luck,wish I was closer to look at it for you.
  • 171 Answers
Are you sure that the motor is actually spinning and if it is there is a belt that drives the capistan drive
Posted on Apr 19, 2014
Testimonial: "no the motor isn't spinning. it seems to ONLY play what's plugged in AUX when set to PHO"
  • Larry Fostano
    Larry Fostano Apr 19, 2014
    So if I understand you ,there is no motor spinning unless it is in aux mode?Did I understand you correctly
  • Larry Fostano
    Will need more info to check more in depth model # or anything you can add.Thanks
Crosley turn table is not spinning. Tried replacing belt and moving cue lever to right then left. Think it might be the arm or cue lever. Does anyone have an idea what the problem is or a solution?
Since it is new, you should probably return for refund or exchange.
My guess would be it is the micro switch controlled by the arm.
Make sure the power is turned on and the unit's function selection is set on PHONO and then gently move the tone arm to the right until you hear a "click". Remove any cassettes that might be in the cassette player. Lift the tone arm and carry it over to the beginning of the record.
TroubleShooting
Jan 27, 2016 | Crosley CR49 Portable Traveler 3-Speed...
Turntable spins constantly and needle wont go down on record
Does the deck have a Lift/Lower lever for the tone arm? Make sure that it is set to the Lower position
Sep 09, 2014 | Aiwa PX-E860 Turntable
Aiwa PX-E850
Hi, most likely the auto function needs resetting. With the power off turn the platter manually clockwise a dozen or so times. Power up and play. Cheers john.
Apr 08, 2013 | Audio Players & Recorders
Turn table doesn't start when tone arm is lifted
Did it used to start when you lifted the tonearm?
Many turntables start when the arm is moved over the record.
Jan 29, 2013 | Audio Players & Recorders
After sitting unused for many years, I just
Hi, Does the arm have a lever to lift the arm up, also called a cue. I had an arm where it did exactly the same thing and found it to be the lifting device. What turntable is it you have?
May 12, 2010 | Audio Players & Recorders
I have a Califone 1620 model economy classroom phonograph in need
Probably a bad relay switch. Open up the turntable. Identify the motor that spins the table. Follow the wires of that motor to, perhaps, some type of little circuit board with a relay. I have a Backley-Cardy 322-487 classroom phonograph which uses a Califone 1620 amp and a BSR turntable. To get the table to spin, you have to move the tone arm. Mine doesn't move and I'm in the process of replacing the faulty relay that is the problem.
Sep 30, 2009 | Califone International 1030AV Turntable
AT-PL50 won't play
take the turntable arm by your hand and place it above the record,then use the up and down lever to lower arm on record!!
Aug 18, 2009 | Audio Technica AT-PL50 Turntable
Getting the turnable to come on
some platters will not begin to spin until the tonearm is lifted up from the rest and over to where the record is, then it starts spinning.
alternately the belt may have come off.
http://www.archive.org/details/Turntable_Belt_Installation
will provide general info on how to put it back on.
Jan 11, 2009 | Crosley CR248 Turntable
Platter not spinning properly
Make sure the platter is seated correctly. Lift it off, and set it back down. Also check to see that there is no debris or foreign matter stuck underneath the platter or where the platter sits.
Check to make sure the platter itself is not bent or warped. Do this by removing the platter (lift up), and then put it on a flat table/surface. Look at it from the side. Is it warped?
Hope this helps
- Davis
DJ Pro Audio
www.djproaudio.com
www.repairnyc.com
Jul 24, 2008 | Vestax PDX-2000MKII PRO Turntable
Phonograph vs Cassette Player
Is your needle tight.  It has to be tight for it to work
Oct 20, 2007 | Crosley CR248 Turntable
Pyle Pro - PTCDS2UI - Classical Turntable With AM/FM Radio/ CD/ Logo
251 people viewed this question
Top Pyle Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Are you a Pyle Audio Player and Recorder Expert? Answer questions, earn points and help others
