Question about RCA Audio Players & Recorders
Rca ouputs to onkyo HT-R510 - RCA Audio Players & Recorders
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 89 Answers
4 Suggested Answers
  • 5 Answers
SOURCE: My Onkyo HT-R510 will shut down after several
Might be over heating. Make sure you don't have anything sitting directly on top of it. I even put a little fan blowing outward at the back of my system to keep it cool.
Posted on Feb 13, 2010
Grubhead
  • 5484 Answers
SOURCE: Selecting phono preamp for Onkyo HT-R510
The magnetic cartridge preamp should work with the turntable, as presumably it will have a magnetic cartridge in it. The only reason that the amp states "magnetic" is that some very old turntables have ceramic cartridges which should not be connected to that terminal. Even if the turntable had a "ceramic" it could be replaced with a magnetic one!
Posted on Mar 21, 2010
ThePoodleGuy
  • 24 Answers
SOURCE: Sound not working on onkyo ht-r510. It Powers on
Simjones700,
Assuming that everything looks like it should work, that the volume is up sufficiently and the mute is off, and that any power section fuses are set and/or not burned out and that the units 'warm up' temperature feels the same. I would try a process of elimination something like this:
* Always turn the unit of and unplug it everytime you attach/detach speaker wiring *
Unplug all sources (DVD, CD, DVR etc) and use only the FM section as as source:
  1. Does the unit have an indicator that is labeled overload or protect or something like that? If so, then unplug/disconnect and inspect the wiring on the speaker terminals. Ensure that if they are bare wires, there are no strands from different wires contacting each other.
  2. Does the unit have a speaker have an A/B switch? If so, ensure that your speakers are plugged into the correct terminals
  3. Does the unit have earphone plugs? If so, try using those . . . if you don't have any earphones go and purchase a cheap pair . . .make sure you have the proper plug - 1/4" stereo?
  4. Do you know for a fact that your speakers work? Beg, buy or borrow a pair of cheap of speakers and try them.
  5. Try using different speaker wire . . . if you have a fancy monster or vampire wire wiring set up, then go to RS and buy some in-expensive speaker wire (not too thin!) and see if anything changes.
  6. Unplug everything from the unit and then hook up one and only one speaker and see what happens. Move the speaker wiring from one set to another, see if there is any behavior change . . .
If after all this and no joy, then time to take it to be serviced.
The Poodle Guy!
Posted on Nov 25, 2010
Want to control my HT-R510 with my TV remote. Need Onkyo code to control this HT-R510
You should indicate you remote.
In any case, if code is not in your remote you should follow indications for No code
If you don't have a manual, look for one using google,and terms manual, make and model of your remote
Aug 26, 2015 | Onkyo Audio Players & Recorders
Intermittent speaker performance - receiver issue - not a speaker issue
Matt,
Have you checked/cleaned the leads on each speaker as one bad lead or speaker can pull/push extra power from/to other speakers causing shorts, this is likely not the case but could be the easy fix. Try cutting one speaker out at a time rotating which one is disconnected to see if this fixes the issue and possibly points out either a bad speaker or connection.
Dec 04, 2013 | RCA Onkyo Ht-r510 Receiver 6.1 Channel...
Onkyo HT-R510
have you tried to reset it to factory defaults yet? If it has a vcr button on the front, then hold the vcr button and press power...it should say reset on the front. Might not help, but worth a try.
Dec 04, 2013 | Onkyo TX-SR601 Receiver
Onkyo HT-R510 left side speaker garbled
Out put transister could be fried ,Or the speaker is blowin,
Nov 29, 2012 | Onkyo Ht-r510 600w 6.1 Dts Home Theatre...
I lost my remote control for my ht-r510 and i want to reset my speakers volume, how can i do that manually?
HI,
Press the SPEAKER ADJUST button on the frond panel of the receiver. With this button you can select different parameters of the speakers. Using the PRESET/ADJUST button you can change the parameters.
ok
Sep 24, 2011 | Onkyo HT510 Receiver
I can not figure out how to adjust the balance on my speakers. It seems that one speaker in louder than the other. I cant find my manual and i've been tinkering with the receiver with no avail.
Tinkering won't work. HT510??? Not HTR510? Maybe that's what you meant.
All AVR's have settings for individual speaker channel levels and distances from the listening position.
http://filedepot.onkyousa.com/Files/own_manuals/HT-R510.pdf
Jul 11, 2011 | Onkyo HT510 Receiver
How do I connect my laptop to my Onkyo HT-S5100 home theatre system?
You need to stereo on L and R RCA connector. Something like this:
http://www.amazon.com/INSTEN%C2%AE-3-5mm-Stereo-RCA-Cable/dp/B0024CAWS2
Jan 13, 2011 | Onkyo HT-S5100 Theater System
Mar 21, 2010 | Onkyo HT510 Receiver
Dec 04, 2009 | Onkyo TX-SR501 Receiver
HT-R510 home theater system
If bought new return immediately for replacement. The amp section is no good and cannot be reset - needs repair. but you are under WARRANTY - use it.
Sep 06, 2017 | Onkyo HT-S490 System
95 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
