Question about Siemens TOUCHPANEL TP177B DP-6 MSTN 6AV6 642-0BC01-1AX1 HMI w/ NEW Touch Screen
The touch screen does not work, work to install a mouse in the usb port. which may be the fault?, as under?, and what can be the solution? thanks
  • 24 Answers
Is it the screen or the touch-pad?
What is the make and model of the Notebook or the device?
Check if the pad lock is on if you are referring to the notebook.
The location of the lock depends on the make.
If touch screen,
Step 1: Power cycle--- Turn off the device > remove the batteries>> wait for couple of seconds>> place the battery and turn it on.
step 2 : Do a Hard reset -- Depends on the make and model of the device
Back up the device before you reset. As you'll lose all the data once reset
Posted on Apr 20, 2014
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 41 Answers
Install the chipset drivers that came with the machine
Touch screen function not working but mouse working
try to shut it off. and turn it on after 10 sec. dont touch the screen when the unit is booting.
Sep 13, 2012 | Lenovo ThinkPad X60 Tablet PC
Mouse pad doesn't work. If I plug in a mouse to a usb port the mouse does't work.
Re install the touch pad driver again and restart.
Hope this helps. Let me know if you need more information Thanks
May 02, 2011 | Acer Aspire 5100-3357 Notebook
Ok i have this mouse that does not work when i plug it into the usb port. the mouse dosent light up or any thing... what do i do?
First thing to do is to determine which one is at fault : is it the mouse, or the other way around?
Here's how :
  • Try another (known working) USB port
  • Try the mouse onto another known working computer
  • Try another known working mouse
  • Try another known working USB device (flash drive, etc) on USB port
Typically, the mouse needs replacement if it still does not work with another known good usb port or computer. If it's the other way around, then you may have USB port issues with your system.
Thank you for using Fixya.
Feb 20, 2011 | Computers & Internet
I have a IT works wireless optical mouse model MWO 03 I had problems with my laptop and now it won't work, what do I do?
1.if you check with another mouse,it is working fine means may be your mouse is only fault.
2.Otherwise,check one thing in device manager and right hand side over the touch bad,weather yellow or red color over there or not,once over the color means it is driver fault so update the driver through device manager.
3.Otherwise eneble the touch option.
4.otherwise may be USB port problem,so update the usb driver via device manager
Nov 17, 2010 | Computers & Internet
My laptop touchpad stopped working
this is probably a driver issue if you are lucky other wise the touch pad must have become faulty
if its a driver issue go to this site
http://www.synaptics.com/support/drivers
and download the drivers according to your operating system
install them and check if the touch pad starts working
if not then its probably a physical fault and needs replacing
Sep 29, 2009 | HP Compaq Presario CQ50-110US Laptop
Ps2 port doesn't recognize Microsoft Optical mouse
You might think about a USB hub for all your USB devices. ps2 port is more or less dedicated for mouse, which is why your mouse pointer is stuck in the middle of the screen. Go ahead and get an externally powered USB Hub to power other USB devices. To answer, ps2 for mouse needs just a mouse, not USB device.
Sep 28, 2009 | Microsoft Windows XP Professional
Dynex wireless mouse DX-PWLMSE won't work
The mouse should be Plug and Play. Did you install the drivers before plugging the mouse's receiver in? The PC has to have the drivers first in order to take advantage of the Plug and Play capability. If you plugged the mouse's receiver in before installing the drivers, unplug the mouse receiver, uninstall the driver, reboot your PC, reinstall the driver, then plug the receiver in and you should be fine.
Otherwise, press the Connect button on the receiver first, and then the Connect button on the mouse, and that should establish the connection. You don't need to disable your touch pad in order to use the mouse.
Jan 22, 2009 | Dynex Wireless Keyboard/Optical Mouse...
MS wireless notebook optical mouse 4000
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Jan 20, 2009 | Computers & Internet
Mikomi/USB optical mouse has started scrolling problem like page refreshing each movement of scroll wheel and if a large movement is made,pages wont stop "refreshing." XP home software,service...
Solution found by altering the screen resolution, this brought the mouse under normal scrolling control
Thanks for your time
A Brownless
Nov 22, 2008 | Computers & Internet
USB Port Problem
Did something happen to the port setting? To find out, right click on My Computer, select properties, then select Device Manager. Does the Universal Serial Bus controller show up with no X's? Did it show up under the ? Other Devices section? You may need to uninstall and then reboot. Windows will discover new hardware and should find the driver for you.
That's my thoughts, so far. Except for the random shutdown. I am reminded of a guy who brought his system in with USB problems, no Internet, and a host of other problems. I discovered that almost all of his services had been disabled. Services and Applications, Services, also under Manage. I put my laptop on the same screen and restored his settings to match mine. Good luck in your hunt.
Mar 27, 2008 | Acer Aspire 5500 5570-2609 Laptop
Siemens TOUCHPANEL TP177B DP-6 MSTN 6AV6 642-0BC01-1AX1 HMI w/ NEW Touch Screen Logo
189 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
