Drum not spinning
I have an older model Admiral - heavy duty, super capacity plus washer. The belt appears to fine, as does the motor and water pump. When the washer goes into the spin cycle the drum moves a little bit but then stops, yet the agitator still works. Any thoughts?
    Sergeant:
  • 264 Answers
Hi I'm Peter, Usually most problems as such have to do with the washer control switch that you use to adjust heavy, permanent press , or delicate cycle.. you will need to unplug the unit the dial should pull straight off with a little effort You will need to remove the screws in the back panel to access the wiring. You will at this time most likely take the top off above the switch. Most washers are made only by a couple of companies, Roper being one that makes a good portion for the name brand ones so all they do is put their name on it. Regardless go to the local appliance parts ware house ask around or check the yellow pages take your make, model, year if you have it and serial number and explain to them your problem and tell them you think it is the washer control switch and see if they have had to sell many. Odds are this is going to be your problem. Every washer I have ever owned and I keep them a pretty good while until my wife wants a new one I have had to eventually replace the controller. Good luck.
Posted on Apr 19, 2014
SOURCE: won't agitate
Ours did this and it was because the bearings had busted. I called a local repair guy and he told me over the phone just by listening to the sound. Maybe you could do the same. I do know this, if it is your bearings, buy a new washer. It's not worth the repair...trust me.
Posted on Aug 04, 2008
tzweeb
  • 318 Answers
SOURCE: kenmore 90 plus series: heavy duty super capacity won't agitate
this is the site to find out how to fix your washer.
you have a broken drive coupling.
it probably wont agitate or spin, but will fill and drain.
you need to remove 2 screws from the control panel, hinge it back and then remove the 2 brass colored clips that hold the cabinet to the base. once you do then pull the entire cabinet forwards to a 45 degree angle and pull it off the base.
then pull the 2 clips off pump and then 2 more on the motor. that will allow you to get to the drive coupling. you will find it to be broken.
replace it with part number 285753a for about 15-20 bucks.
Posted on Jan 31, 2009
  • 130 Answers
SOURCE: Old Washer won't spin or agitate
You found a belt? Most w/p washer do not have a belt they are direct drive. take off the pump and motor to replace the motor coupling, 2 plastic pieces w/ a rubber in between
Posted on Feb 16, 2009
  • 56 Answers
SOURCE: GE washer agitates but won't spin
I think you may have a stopped up pump does it drain the water out if not it will not spin. A putty knife inserted 2 inches in from each side will release the spring catches and gently pull on front as you release sprins then look to the bottom right hand side and there is the pump clamp the tub to pump hose or **** water out with a shop vac take off tub to pump hose and then two 3/8 in screws that hold down the pump turn over where you can look in the pump may have an obstruction as always disconnect power before service.
Posted on May 31, 2009
tiger56h
  • 176 Answers
SOURCE: Kenmore 90 series Heavy Duty Super Capacity Plus
hi check the lid swetch
Posted on Sep 15, 2010
The drum on my dryer seems to be stuck and is not spinning, the belt is on and seems to have the proper tension. Can someone help me get this dryer running again?
inspect the tumble dryer drum shaft - see image
inspect the dryer belt tensioner - see image listen for sound when electric motor is running
25302111-r0o5diaoq3uxmfwmdgmcujgm-1-0.jpeg 25302111-r0o5diaoq3uxmfwmdgmcujgm-1-2.jpg
Dec 01, 2014 | Frigidaire FGX831FS Washer/Dryer Laundry...
Heavy duty super capacity plus
You dont. If it is making noise drum bearings or idler needs replaced
Nov 03, 2013 | Kenmore 24032\24036 Top Load Washer
Admiral Heavy Duty Super Capacity Plus dryer does not start when button is pushed. The dryer buzzes when the start button is pushed, but the dryer will not start tumbling. The model number is ADE7005AYW...
Motor runs, but drum does not turn
1. Broken or slipping belt---replace
2. Loose pulley---tighten pulley on shaft
3. Drum jammed or bearing frozen---check for foreign object & clear it
Clean or replace bearing
Sep 21, 2011 | Dryers
Feb 15, 2009 | Whirlpool Washing Machines
Whirlpool Heavy Duty Super Capacity Plus not spinning
HI thanks for the question . On your model thers is no belt it is a direct drive.IF the washer stoped pumping the water out in pump out then your problem is with the lid switch. The lid switch is located under the top Thanks for your question hope this helps you ,THE appliance doc
Sep 10, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Won't agitate
Jul 24, 2008 | Admiral AW22 Top Load Washer
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
