Question about HP LaserJet 6L Printer
Hp laserjet 6l will not feed paper
Pick up rollers will not advance paper Replaced paper feed rollers pad assemblies shoes etc. Paper still will not feed. When selecting the green button the selinoid clicks as the clutch gear turns but paper does not advance. Please confirm installation and contact points and direction of the parts to be installed. Observation: The clutch gear (makes contact with the paper feed roller but does not make contact with the gears on the right. However it does make contact with the small gear left below. Not sure if this is correct? I would appreciate some assistance with resolving my problem.
  • 66 Answers
SOURCE: HP Laserjet 4100 series , paper jam output tray
Hi F_bulsara,
First thing to try is to flip the paper over in the input tray. There are 2 sides to paper. One side may curl a bit too much due to heat of the fuser and get caught near the output rollers.
Unless the Output Assembly was assembled wrong, it is impossible for the rollers to turn the wrong way. The gear in the fuser drives the output assembly. The top rollers are rolling out.
If the rollers are not rolling, then one of the gears must be broken or missing. The output rolllers might need cleaning.
Next check the fuser unit. Disconnect power to printer and turn printer round. Remove the back output tray and the two small covers (left and right). Undo the 2 screws that hold the fuser in place. Pull the fuser out. Check the gears on side of the fuser. A broken gear in the fuser could cause this problem.
S88
Posted on Dec 18, 2008
frcs68
  • 1605 Answers
SOURCE: Broken paper feed roller
you cn the roller from the link below:
http://www.precisionroller.com/manufacturers/hp-photosmart-c5280.html
Posted on Jan 27, 2009
  • 8 Answers
SOURCE: HP Officejet Pro L7580 ADF will not pick up paper
You can lift the top of the unit to inspect the rollers. Be careful because the L series the roller can pop off easily and if you're not paying attention to original orientation, can be a pain to put back in.. you press the blueish button to release the pick up assembly. See if any rollers are dusty. If they are, use Isopropyl alcohol (highest % you can find) and a LINT FREE cloth (dryer sheets/coffee filters or something of that nature..) and wipe clean
Hope this helps, I'm honestly doing all this from memory, I used to work for that dept here in Oregon ..
Posted on Sep 08, 2009
Adi_Taticu
  • 71 Answers
SOURCE: 1320 HP Laserjet Still Won't Pick Up Paper
Please check limiters paper in tray 2 to be on A4, letter, depending on paper format. Otherwise you have problems with taking the sheet from tray 2.
Posted on Oct 09, 2009
Testimonial: "Excellent suggestions on troubleshooting HP Laserjet 1320 Printer. It took a few times to get the correct solution, but it works now! THANK YOU!"
komguy
  • 2306 Answers
SOURCE: paper feed problem
You can try to clean the rollers with alcohol, usually it's just the paper dust and ink that makes them lose traction. With the back door open you can clean the roller with alcohol on a Q-tip.
Posted on Jan 10, 2010
Testimonial: "After getting your answere,it did fix that problem. thank you v"
Unable to pick up papaer on tray 2 error 13.00
common faults for poor feeding on lj5200
1, feed rollers are worn - replace
2, sep pad is worn ( cant seperate pages correctly)- replace
3, paper empty tray sensor actuator arm snapped - unable to raise cassettetray- replace arm
4. paper feed roller fail to turn- feed unit clutch assy faulty- replace feed asseembly
5.paper tray pass guide out of position (blocking feed path) - pin that holds in place has snapped- replace feed assembly
Dec 13, 2013 | HP LaserJet 5200 Printer
HP Laserjet 6L Dark Printing
Check your Toner, and also the thermal roller of the printer..
Thank you
May 29, 2008 | HP LaserJet 6L Printer
I have an hp p3005 with the jam code 13.01.00. It has had the feed rollers and sep pads replaced. When it runs it appears to catch on the separation pad itself since it shows a small buckle in the middle...
Replaced seperation pad?. separation pad work is to block multiple paper feeding,but in yourcase paper not at all feeding means paper pickup roller not picking up the papers.replace both 2 & 3 paper pickup rollers..
See the snap shot,view from under.
Pickup roller( red)
Un lock to remove pick up roller(blue),observe the angle of the roller & same way insert new one other wise it wont fix..
Bee care full while removing roller, paper sensor flag should not distubed(yellow)
bee pateince dont do harsh..best of luck.
Oct 11, 2011 | HP LaserJet P3005 Printer
HP Laser 6L - Printer makes a squealing noise but does not advance the paper to complete the print.
Old age printer, it needs to replace feed roller assm,pick up roller & separation pad to avoid pickup issues.must be replace these item at a time to avoid tension.
Sep 23, 2011 | HP LaserJet 6L Printer
Hi, I have a HP Laserjet 6L. I recently made the mistake of pulling a paper jam out incorrectly, I pulled the paper out from the paper feed tray rather than pulling it out from inside once the toner...
One thing pl understand this is old printer, while handling you should be carefully, parts are became delicate because of old age.check that paper pick up roller surface got smoothness or dirty, first clean with wet cloth surface of the roller & check, even its not picking up replace both pickup roller & separation pad.best of luck..Vinay.
Sep 05, 2011 | HP LaserJet 6L Printer
I have a hp laserjet 4250 printer it had a paper jam in tray 2 i have cleared the jam but it keeps saying i still have the jam in tray 2
There is still paper stuck in the printer. try lifting the printer off of tray 2 to inspect it or here it is straight from the service manual...
Jams in tray 2
Table 7-10 Causes of tray 2 jams
Cause Solution
The feed or separation rollers are dirty, worn, or damaged. Clean the rollers. If they are dirty after cleaning, or if they are
worn or damaged, replace the rollers.
The pickup roller is worn or damaged. Replace the pickup roller.
The tray 2 paper pickup assembly drive gears are damaged
or the assembly is defective.
Check the drive gears in the paper pickup drive assembly.
Replace the pickup drive assembly if the gears are
damaged. See Paper-pickup drive assembly.
The tray 2 pickup solenoid (SL101) is damaged. 1 Disconnect the connector for the tray pickup solenoid
from the dc controller PCA (location J92).
2 Measure the resistance between the cable connectors.
3 If the measured resistance is not approximately
160 ohms for the HP LaserJet 4200/4300, or 110 ohms
for the HP LaserJet 4250/4350, replace the tray 2
pickup solenoid.
The tray 2 lifter-drive assembly or the stack position
sensor (PS107) is defective.
Replace the lifter-drive assembly. See Tray 2 lifter-drive
assembly and/or Printer switches and sensors.
The dc controller PCA is defective. Replace the dc controller PCA. See Dc controller PCA.
Dirty, worn, or deformed pick-up roller, cassette separation
roller, and cassette feed roller.
Clean the rollers if they are dirty. Replace any worn or
deformed rollers. The cassette separation roller and the
cassette feed rollare are to be replaced together.
Damaged gears in the cassette pick-up drive unit. Move the gears in the cassette pick up drive unit. If the
gears are not rotating correctly, or are damaged or worn,
replace the cassette pick-up drive unit.
Dec 25, 2010 | HP LaserJet 4250 Printer
Paper feed feeds more than 1 sheet at a time
he problem you are having is caused by a worm separation pad assembly. This assembly is what separates the paper into individual sheets. It takes about 30 minutes to disassemble the printer and replace the part. Most printer repair shops will do the repair for you but the cost may be a bit much. If you are interested in doing the repair yourself we do stock the part. We can provide the separation assembly and a service manual on CD that gives directions for replacing the parts plus other information about the printer. The part and guide runs $14.95 plus shipping. Let me know if you need one, tech
Apr 26, 2010 | HP LaserJet 6L Printer
Error message keeps appearing "paper jam in tray 2" although there is definitely no paper jam.
If you did not get ALL the jammed sheet out, there is still a small piece of paper in there somewhere, probably covering a sensor or micro switch. Get a torch and look carefully. If you don't find anything you may need to disassemble the printer to find it.
May 02, 2009 | HP LaserJet 2300dn Printer
Manual feed pickup
replaced the manual feed tray separation pad (it is right under the pick-up roller). The HP part # is RG5-2703. First remove the pickup roller then you can pops it out with a small straight slot screw driver.
Jan 23, 2009 | HP LaserJet 8150n Printer
Paper feed
Yep the paper feed roller wears and will need replacement (open front cover in centre of machine tabs on either side it just clicks out.
should also change sep pad (multi feeds)
Here in LINK to purchase items pic below
Dec 21, 2007 | HP LaserJet 1000 Printer
HP LaserJet 6L Printer Logo
50 people viewed this question
Seeker5211
Seeker5211
