Question about Whirlpool Refrigerators
Reffigerator works frezer doesent - Whirlpool Refrigerators
    Problem Solver:
  • 15 Answers
Your freezer is iced up behind cover some thing is not working on defrost, Need to have it check because it could be defrost bimetal
or defrost time or heater. You need and meter to check it out if you have one turn it in to defrost by turning time to right until it cut off id ice is on coils and it go in defrost then it the timer. But if it don't start to heating up element then you need to check bimetal and if ice is on it and you cant read through it then it is bad. But if you read through its good. Check heating element you should not read through it it will need to be replace. But that is if ever thing is iced up if it not ice up but a little ways up coil you are low in freezon you will have to have it check for a leak and has it fix and they will put freeon in it and it will work fine after.
Posted on May 01, 2014
Frezer works both AC and Propane Refridgerator
move temp sensor inside see side move up to cool down to warm up if no change replace
Sep 01, 2013 | Dometic RM2620 Refrigerator
The fridge is not working.the freezer is working.in the freezer the cold air is not coming in the fridge.
fridge basics
the fridge and freezer are seperate compartments they dont share air there is a chemical filled filiment on your fridge u can see it at the back looks like a big grill that chemical is pumped around both fridge and frezer that chemical carrys heat energy it removes the heat from the fridge and frezer to the radiator at the back this radiator gets verry hot whyle your fridge / frezer becomes cold it shuld be 1 compleate system with better fluid flow in the frezer to make it cool faster
ok so the frezer is working but fridge is not it could be a few things 1 fluid not geting round the fridge lack of fluid or 2 a blockage
im no expert but knowing the basic science of fridges is a help i hope this has helped but like i say im not farmiliar with any fridge and models deviate but the science stays the same hopefully this steers u in the right direction
Oct 30, 2012 | Refrigerators
My amana reffigerator ice maching is making shells of ice cubes.
This indicates not enough water getting to the tray. check the ice maker shoot where the water comes out to see if it's obstructed with ice. You can defrost it if so, but you may need to replace the water fill solenoid in the back of the refrigerator where the supply line connects.
May 28, 2011 | Amana Refrigerators
There is frost buildup on back wall of frezer fridge or frezer dont get cold enough
my fan blade had slipped down and was rubbing makeing a noise and fine particles of white dust was at the rub point. Pushed the fan back up drop of super glue and lubricated the motor. works great!
Jul 27, 2010 | Hotpoint (HSM25IFTSA) Side by Side...
After clean, the magic chef chest frezer no linger frezen.
I think in the defrosting process, the evaporator was damaged causing refrigerant leakage. sorry... dont try to repair.. it sucks in moisture
Aug 26, 2009 | Freezers
Tow dooe refrigerator and frezer, ice in the
likely door gasket door out of alignment. or the defrost high limit switch is not opening in defrost when the evaporator get warm during defrost check the door gaskets good and clean. Tom
Jun 29, 2009 | Refrigerators
Compressor not working warm fan inside frezer run
Heat exchanger was iced over, took a hair dryer and melted ice. I think defrost heater element is bad will check it this week end. I put a new computer in the frige about 3 mounths ago and will check if it has gone bad. The compressor is working fine.
Jun 03, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Frezer temp is 20 deg. fridge temp is 47 deg.
Remove the freezer shelves and bins. Remove the freezer back panel to access the fan motor.
May 26, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
I was pickeing away at the ice on frezer and i poked a hole in the plate for the frezer, i need to know if the fridge will still work or do i need to bye a new one
Yes , should still work as long as you didnt hole the coolant pipes. Use some putty or similar to block the hole.
May 19, 2009 | Refrigerators
Icemaker is not making ice
is there water in your icemaker.if so then its up to icemaker to do its part.frezer temps must be near 0 degrees.if no water in icemaker is the line in the back of the frezer frozen [top back where water passes thru frezer wall into frezer section.if its not frozen,am i then getting voltage to the water valve when the ice maker cycles.if not then icemaker is bad.if your ice bucket is on the door[whirlpool,kenmore]there are boards in the frezer section that can fail.i know that dosen't tell you what the problem is .but it does give you somthing to go on with.God bless ,tom
Jan 11, 2009 | Refrigerators
Refrigerators Logo
32 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
