Question about Clarion SIR-CL2 SIRIUS Radio Receiver
Re program infiniti g 37 2011 xm radio to sirius
Xm has no signal in puerto rico but sirius does
I want to send a check to someone in Bayamon, Puerto Rico. Is there a Bank of America in Puerto Rico?
As a matter of fact, yes. Here is the particulars.
255 Avenida Juan Ponce de Le?n, San Juan, 00917, Puerto Rico Phone:(202) 910-2599
Dec 10, 2015 | Cars & Trucks
I have a 2014 dodge ram pickup with xm version of sirius xm. In northern canada xm signal is horrible bit sirius works flawlessly. Is there a upgrade to switch to sirius signal without adding a stand alone...
The 2012 Dodge Caliber had a Sirius radio instead of XM - BUT - you will have to check if it has a "FAST" or a "SLOW" "BUSS SPEED" - that is very important that the radio you replace it with has the correct buss speed. Sirius will only work a little while longer as they are eventually going to phase out their overhead satellites for a geostationary satellite like XM. XM has the better sound than Sirius - if you can receive them. If you can't find a factory replacement from 2012, then BestBuy still sells a Stratus Sirius radio - and you can probably even fish-out the antenna wire that you already have for use with the plug and play add-on Status. Good luck - let me know if you have more questions.
Jul 17, 2014 | Audio Players & Recorders
Sirius radio problems
I would do the following, hoping one of them works.
1) DISCONNECT the power to the radio and SiriusXM unit to "clear" it. Then reconnect and ask Sirius to resend signat.
2) Ask Sirius to UNSUBCRIBE that radio so it is deactivated. Then, have them reactivate and resend programing signal.
3) Be sure your car is outside under clear sky when Sirius sends the program signal.
4) It is possible the antenna cable to your unit is loose at the connections and/or damaged. A weaker signal may get your stations, but may prevent the additional Navigational signals. Have the antenna checked thoroughly and tested. If car is still under warranty, this should be a covered diagnostic/repair.
5) Finally, be sure the correct Radio Serial Number is being activated. If your radio works, that is one service. But maybe they are putting a wrong number by some chance into the system to fix this one? For example, you have TWO radios in TWO cars. Are they sending the turn on signal to the WRONG radio? Not as farfetched as you might think.
Jun 19, 2014 | Delphi Roady XT XM Radio Receiver
Is a passport needed for travel to Puerto Rico
That depends on where you're coming from.
If you're coming from the US, no. If you're coming from another country, contact the US consulate and they can tell you whether a passport is needed for travelling to Puerto Rico.
May 26, 2014 | Nikon Coolpix S9100 12.1mp Digital Camera...
Does the garmin255wt work in puerto rico is it preloaded with map
Yes. The maps preloaded on the unit (assuming it was purchased in North America) will allow you to navigate in the US, Canada and Puerto Rico.
Mar 09, 2010 | Garmin nuvi 255W GPS Receiver
Im tryng to send a fax to purto rico but 4fax
Get Magic Jack and connet it to your computer. You can connect to a fax machine, telephone, and call to Puerto Rico. Connect this to your Computer. You now have an option to call or fax anything.
http://www.magicjack.com/5/index.asp
If this information is helpful, pls rate me.
Good Luck.....
Thanks
Feb 14, 2010 | Brother Multi-Function Center MFC-240C...
I need maps of puerto rico how i can find maps of puerto rico
Hi!
Basicallly, go to google.com, then in search area TYPE press first the image, then type in the Puerto RIco Map then enter.. after you see the pictures or map, point your mouse to the MAP of Purto RIco the right click after right click press copy then go to the desktop and press control V meaning paster. after that you have to double click the file the you can open it in Photoshope or Paint.. Good Luck & Regards
Ronie
Mar 18, 2009 | Navigon 2000S GPS Receiver
My GPS map has only Hawaii and Puerto Rico
there maybe a upgrade for maps out online you can get to help. I have the same GPS as you, and I have 48 state maps and canada and puerto rico on mine.
Feb 11, 2009 | Magellan RoadMate 1400 Car GPS Receiver
Need to disconnect XM Tuner
the xm receiver is in the left rear quarter of van looks like between wheel well and rear of vehicle this is drivers side
Jul 17, 2008 | 2007 Honda Odyssey
Sirius radio with xm antenna
Not advised. They have different resistance and are set up for different Sat signals. Chances are you will decrease the life of your radio if you get a signal at all.
Apr 08, 2008 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
Top Clarion Audio Players & Recorders Experts
xxxxxx xxx
Robert Rankin
richie46
Are you a Clarion Audio Player and Recorder Expert? Answer questions, earn points and help others
