Question about LG Televison & Video
Lg ht 552
Stuck in DVD function,can't play radio,but remote works!what should I do?
  • Apostolos
    Apostolos Apr 21, 2014
    On another device(on my lg sound box )I can see that my "band " button(on the remote of lg ht 552)corresponds when pressing it,by lighting a small red light in the other sound box device,so I can assume there is no problem with my remote control!problem is that I can't move it to the "band"(or radio function)!
ungatt0
  • 32 Answers
SOURCE: home theater system
have you tried the wiring or if your fuse for the speakers are broken
Posted on Jun 12, 2008
ungatt0
  • 32 Answers
SOURCE: dvd does not load
some times its because of the CD (it cannot read the CD) all you have to do is try a different range of CD's to see what the prob is if it still doesnt read it may be coz of a scratched CD / Lens!!!!
Posted on Jun 26, 2008
  • 98 Answers
SOURCE: sony dvd player dvp-fx810 stuck on "disk loading"
Make sure the switch on the side is set to video out not video in hopefully this helps out
Posted on May 16, 2009
SOURCE: I have a Home Cinema with DVD model HT-M700H and a
If the disk is stuck in then the is a big problem with the dvd draw, sounds to me like the motor has shorted out if there isnt any noise, you can getthe disk out manually by unplugging the Cinema system, get a paperclip , its either to the left or the right of the dvd draw is a set of gears that is explosed to allow manual retrevial of the disk, push it into either the left or right bottom of the dvd draw and if you feel a little resistance , you have found the gear, just keep pushing in until you see the dvd draw start to emerge, then gently pull it out with your fingers.
jon.
Posted on Aug 12, 2009
SOURCE: My Samsung HT-Z110 does not play any DVD's anymore...
check if the cds works if they work you need to replace the motor disc spindle
Posted on Jan 11, 2010
I have a Panasonic sc-xh150 DVD home theater soundsystem I need to hook it up with myc ox cable dvr ,ps3 and LG 42 INCH LED TV#42LN5300 I have no remote for the Panasonic and also won't play DVD
This Panny is a pretty sophisticated home theater (HT) system. It will play music from and control an iPod or iPhone up to 5th generation units in addition to DVDs, CDs, FM radio, and other sources like your PS3, cable DVR, etc. Everything you need to know about setting it up and running it is in the user manual. Go to http://service.us.panasonic.com/OPERMANPDF/SCXH150.PDF to download one for free.
Unfortunately this HT has two issues that will affect your ability to use it. First, like most modern systems, you absolutely need a remote to run it. Only the basic controls appear on the main unit. You can buy a $10 "universal" remote and see if that works -- they're available at Walmart, Staples, Home Depot etc under names like RCA, Philips, and Sony. But quite often they only have buttons for running a unit, not for setting it up. If that's the case you'll need the original Panny remote, which is much more expensive. Go to shop.panasonic.com and poke around to find it.
The second issue is what you want to plug into it. It has very limited inputs. There is no HDMI input at all, and no component video inputs, which means you'll have to run a cable from your DVR directly to the TV if you want Hi-Def video. The same holds true for the PS3. Unless your LG TV is ARC-capable, you'll also have to run a separate audio line back to the HT unit to hear the sound from the DVR, the PS3, or TV programs. Not a huge deal if the LG has enough inputs, but kind of disappointing. Good luck.
May 23, 2014 | Audio Players & Recorders
How to play blue ray dvd on the LG HT554
Unless it is specified as being able to play Blu-Ray discs, it cannot do so, and there are no 'hacks' to enable this function as the HT 554 is a DVD player/home theatre system. You would require a Blu-Ray player to play both types of disc.
Apr 05, 2011 | LG Electronic LRA516 DVD Recorder
Dvd does not play without the remote pressed play constantly to no avail. what can I do to remedy this?
Something is overriding the Play function. Perhaps on the remote itself or in the machine's hardware switches. Hide all the remotes. Try the front panel Play button. Works? Figure out which remote is causing it.
Still not working? Turn it OFF. Manipulate all controls to make sure they're not 'stuck'. Try again.
Be aware of this:
http://www0.epinions.com/review/Amphion_Mediaworks_T_365_System/content_440913202820
"Recieved unit as christmas present 2007, setup unit enjoyed playing remote radio function, family member shutoff unit using main power button when going to bed, the next day unit does not come on period...the unit was stacked upon vcr and satellite units thought problem was due to electronic heat, but upon further exams, have yet to determine cause...during internet searches, found others having same/or multiple problems..further check tells me company out of business...recommend buyer beware...as repair nearly impossible...unless electronically inclined..tddsim729@yahoo.com"
Feb 05, 2011 | Amphion Mediaworks T-365 System
Installing a LG Network Blu-ray Disc/DVD Home
YOU NEED TO CONNECT OPTICAL CABLE (NOT INCLUDED) TO OPTICAL1 CONNECTION ON YOUR HB405 AND OPTICAL OUT OF YOUR TV. IF YOU ALREADY HAVE DONE THAT TRY PRESSING SIMPLINK BUTTON ON YOUR TV REMOTE NAD CHANGE THE SPEAKER OUTPOUT FROM TV TO HT(HOME THEATER).
Jun 19, 2010 | LG Televison & Video
Jan 11, 2010 | Samsung DVD-Homecinema-Sound-Package ...
Samsung HT-A100 Home Cinema system plays cd only with tv on!
You need to put away the remote for your TV and use only the remote for your HT system. Your HT remote should work on your TV by default. Your Samsung HT remote should have a TV button and a DVD/Receiver button (or HT button). When using only the TV, press the TV button and then use it for just the TV and when using the HT system, press the DVD/Receiver button and then you can use the HT system.
If for some reason your TV is not set on the Samsung HT remote by default, your HT users manual should have a list of codes that you can use to program your HT remote. Hope that helps you. Gary
Mar 18, 2009 | Samsung HT-A100T Theater System
Harmony 880 does not change input with Onkyo HT-R520 amplifier
You will either have to use your Onkyo remote to teach the Harmony those functions or try one of the similar model receivers in the Harmony software. I had to chose a similar DVD player in the list in order to get my Harmony to play nice with my DVD player.
Feb 14, 2009 | Logitech Harmony 880 LCD Remote Control
LG REMOTE WONT SWITCH FROM AM/FM TO DVD
HI THERE, I FIXED THE PROBLEM MYSELF BY KEEPING THE FUNCTION BUTTON ON THE DVD PLAYER PRESSED UNTIL IT FLASHED ""MODE"". THEN I PRESSED IT IN SEQUENCE TILL IT CAME UP WITH DVD/TV THEN IT AUTOMATICALLY SWITCHED OVER TO THE DVD FUNCTION MODE. ALL DONE. BUT THE TV/DVD BUTTON ON REMOTE STILL ISNT FUNCTIONING OR CROSSING OVER CHANNELL. HAVE TO DO IT MANUALLY VIA DVD PLAYER. EVERYTHING ELSE WORKING EXCELLENT. THANKS ANYWAY. HOPE THIS INFORMATION WILL BE OF USE TO YOU IN THE FUTURE. I CUD CHARGE YOU FOR THIS INFORMATION BUT I WONT THIS TIME.... LOL. MERRY CHRISTMAS AND GUDBYE...
Dec 13, 2008 | LG Televison & Video
Samsung HT-Q100 - Changed Battery on TV remote control
Just try to clean your remote,this the common problem of dirty contacts of remote it plays a certain unit but to the other won't play.Just open it take a toothbrush with an alcohol brush the remote control board,and dry it for 1minute and close it back then check if working..
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 17, 2008 | Samsung HT-Q100 System
LG dvd receiver
switch on dvd without disc and let it load till it shows no disc. open tray and using a remote control enter four zeros. region edit will appear and press zero and press enter and then pulse on remote.switch off dvd and on again.dvd is region free. notify me if this works email alfredmalambo@yahoo.com
Dec 09, 2007 | Samsung HT-X20 Home Cinema 600W Theater...
Televison & Video Logo
18 people viewed this question
Computer Repairing
Computer Repairing
