Question about Irons
Iron shuts off automatically when using - Irons
  • 171 Answers
There is a fuse link and an over temp disc in these ,if the disc is not working correctly it tells the iron to open the disc until it cools to a lower safer temp then resets.
Posted on Apr 19, 2014
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: Iron Shuts off Automatically when using iron.
The cord is broken...
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Posted on Jul 14, 2010
I HAVE AN OLD BLACK AND DECKER 300 QUICK AND EASY IRON. DOES IT CONTAIN MERCURY?
I just looked up the manual. Unfortunately the best way to find out is to contact B&D.
This is from a recycling website.
Purpose of the Mercury: The reason that mercury tilt switches were widely used in irons and other appliances was because of the conductive and liquid-like properties of mercury. In a mercury tilt switch, as the switch is "tilted" the mercury flows with the switch to complete the circuit by conducting electricity and turning the appliance on or off. In irons the mercury switch controls an electronic shut-off timer, constantly resetting the timer when the iron is in motion. If a person leaves the iron turned on and motionless, the automatic shut-off timer turns the iron off after a certain amount of time, reducing the risk of a fire. If an iron falls, this feature will also prevent it from continuing to release heat potentially causing a burn or fire.
Potential Hazards: As long as the iron remains intact, there is a low probability that there would be a mercury release.
Recycling/Disposal: There is no easy way to identify whether or not an iron contains a mercury tilt switch. However, if the iron is more than 10 years old and it contains an automatic shut-off, consumers should assume that it contains a mercury switch and dispose of it properly.
Unfortunately, they keep referring to 10 years old, but it doesn't say when this information was written up. If it was written in say 2006, then it would be referring to 20 year old irons.
Jul 28, 2016 | Irons
Premature shutting off
Have you try with lower heat setting?
It seems like it might be thermostat or thermal fuse that is not working properly.
Apr 21, 2008 | Rowenta Effective DX1700 Iron with Auto...
Breville TECHnique VIN158
if the iron use electronic control, will be a little difficult to adapt or reset .However i recommend follow this steps and fix it. God bless you
Clean an iron:
  1. Unplug the iron and make sure it is cool before cleaning.
  2. Use a toothpick or pipe cleaner to remove buildup in the steam vents, making sure the debris doesn't fall into the vents.
  3. Use a fine sewing needle to carefully clean the spray nozzle of mineral deposits.
  4. To flush sediment from a steam iron, pour 1/2 cup water and 1/2 cup vinegar into the water tank. Place the iron on a rack over a broiling pan and set the iron to steam until the tank runs dry. Repeat if necessary. Or follow the instructions for using a commercial iron cleaner.
Service the steam and spray mechanism:
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
Clean a metal soleplate:
  1. Unplug the iron.
  2. Use a sponge and commercial soleplate cleaner or baking soda and water to remove dirt buildup on the soleplate. Rinse well with water and dry. Don't use harsh abrasives or immerse an electric iron in water.
  3. Use very fine steel wool (0000) or an emery cloth to remove scratches and burns on the soleplate, then clean the soleplate.
Jun 11, 2013 | Irons
I have a Shark automatic shut off model G149011 It just shut off and will not come back I have only had the iron for 10 months I purchased at Walmart. How can get the iron fixed or replaced
you prolly have a 1 year warranty, return it to walmart or they will have the address of the local repair depot or contact shark for the local repair depot they use
May 25, 2011 | Euro-Pro Shark GI490 Iron
I plug the iron in , 5 minutes later it turns off ! Is that a auto shut-off problem or something else
The iron has an auto shut off of usually 8 minutes. The iron will automatically turn on if you move the iron. If this does not answer your concern, let me know and we can look for a solution. Thanks.
Mar 15, 2011 | Rowenta Irons
Auto shut off how to turn back on?
The automatic shut off is a protective device to let the iron cool down when not in use. Normally, if you pick the iron up and sit it down on the board or fabric, the iron will "sense" the motion and click back on to the heating cycle. To turn the iron off, just move the dial to the lowest position, or OFF and or unplug it from the outlet. If left unattended for a while, and when picking it back up to iron, if it does not come back on then you may need to increase the heat setting, move the dial a little, till you see the power light come back on. This is a safety item, and a good one, given the hectic lifestyles we have now, and having busy lives. If we forget to shut the iron off, it does it for itself after a period of non-use. No more trips to the store or wherever and remembering "I forgot to unplug/turn-off the iron I was using". Still, it's best to unplug and or turn it off when not in use. I prefer unplugging, so that it does not be a "vampire device" drawing even little amounts of current when not in use. And it's safest when unplugged and cool.
Sep 26, 2009 | Irons
Rowenta won't shut off automatically
Unless you have a 5 or 6 hundred dollar iron, or unless it is brand new, and still under warranty, there is an excellent rule of thumb when an iron quits working: Buy a new one! These days, irons can be purchased cheaply enough that it is WELL worth the money. Not just for the convenience, but for the safety issues. This is an appliance that could burn your house down even if it's in PROPER working order. Hope this helps!!
Chad
Sep 30, 2008 | Rowenta Professional DE880 Iron
My Iron keeps turning off while I'm ironing
First I called Black and Decker. No help there, just a very condescending man on the other end of the phone who finally put me on hold for more than 10 minutes. I hung up, and went to the store where I purchased the iron and without a receipt they listened to the explanation and exchanged it for the exact same new iron. Now THAT'S customer service.
Sep 29, 2008 | Black & Decker Irons
heatman101
Apr 03, 2008 | Conair DPP4000 Iron
Shark Euro-Pro G1490
Our G1490 quit after one year. Just won't come on. Period. I can't get it to open after removing the back screws either.
Jan 08, 2008 | Euro-Pro Shark GI490 Iron
Irons Logo
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
