My whirlpool microwave model # MH1170XSB-5 is not working. When I close it, the light will not go off and it says close door when I try to use it. Please help
Simple issue here,there is a micro switch that shuts the light off when you close the door ,it may also open a circuit depending on yuor particular switch that lets the microwave think the door is open.Not hard to fix if you are handy,remove the screws to the sheet metal cover ,locate the switch and make sure that the switch is being made when you close the door.Could just be it is loose,could be the pin that hits this switch is missing,broke or out of adjustment.In any event,do this with no power on ,also these devices can still store power so be careful here .If you are not careful you could get seriously hurt so remove plug and or call someone that has some electrical experience this is totally at your own risk.
Testimonial: "Thank you so much for the prompt response. Please I live in the Dallas Area. Can you recommend someone that can fix it for me? Thank you."
Every other thing works great
