Question about Fujitsu LifeBook S7010D Notebook
Need to replace fan
How do I replace the fan (diagrams, instructions)? I am savy enough to replace memory, hard drives etc. but have never done surgery on it. Is this something best left to a trained technician?
  • 240 Answers
Www.insidemylaptop.com/replace-fan-fujitsu-lifebook-t4200-tablet-case/
i think this site will be enough to know instructions to replace it
Posted on Jun 19, 2009
Flashing yellow light and code 1 and 2
According to the Dell support site, this is a possible motherboard failure. The suggest corse of action is to disconnect all interal and external peripherals, with the power off and disconnected. This would include the printer, scanner, ext. drive, monitor, interal dvd drives, extended graphics card (if installed), ect. I would leave the memory and hard drive in place for now. If the comuter boots up, turn it off again and add the monitor to the mix (on the integrated video card). Then add one peripheral at a time and repeat till you find the bad part.
If the computer is still giving you the error, it is most likely a bad motherboard, and that will need to be replaced. If you are not computer savy enough to do this, take it to a computer repair shop to get the work done.
Hope this helps
Feb 02, 2012 | Dell OptiPlex 760 MT Desktop Computer
Wharfedale DVD1100 PLayer does not detect USB Hard drive
It's unlikely that you're doing something wrong. Did you buy this DVD player as one that is supposed to support connecting hard drives? If not, then the player probably doesn't support connecting a hard drive.
Jan 08, 2008 | Wharfedale DVD-M3 DVD Player
Beeping
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
the grrr is the sound its not getting enough power
test your PSU power supply unit or replace it if the fan is not working the PSU is faulty
One bad/faulty lead can cause a computer with lots of problems
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Dec 16, 2010 | Dell OptiPlex GX270 PC Desktop
When pushing power button on, there is a beeping sound with a red light coming on and nothing happens?
test your PSU power supply unit or replace it if the units fan is not working the PSU is faulty
hope this helps
Dec 14, 2010 | Compaq Computers & Internet
Rsuppose i want to save apara etc on to my hard disk what can i do i am not comp savy .pl explain in detail.thank u.
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Jan 09, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I can't find a diagram of the drive belts in my 95 toyota pick up. I had 2 slip today so it's hard to tell which belts go where!
go to 2carpros.com, enter your information about belt routing, and vehicle information. I'm looking at it right now, but I'm not computer savy enough to paste it.
Sep 02, 2009 | 1995 Toyota Pickup
Forgot windows login password for laptop running vista
To remove or change the Windows password is not easy to do, but can be done with Linux Password Removal program. You need a computer savy friend to help you.
The other way is to install Windows from scratch again to get a working laptop again but you may lose your data. There is a way to retrieve your data before you install Windows again.
If you didn't protect the hard drive with a password and if you did and still know your BIOS password, THEN go into the BIOS setup and remove the password on the hard drive first.
Then remove the hard drive from the laptop and connect it to an USB hard drive adapter. Insert the adapter into a working computer's USB port and the computer will see this as an external hard drive. You can then open the folders and view your files. Copy the various folders and files you require to a USB memory stick and/or burn these to a CD etc.
Now you can return the hard drive back to the laptop, install Windows, the device drivers, your programs and copy the data back into the laptop.
It pays to backup your data regurarly because if the hard disk fails and this can happen unexpectedly, you will lose your data.
Jul 06, 2009 | IBM Computers & Internet
T30 still won't boot after fan replacement
One of your memory slots might be bad as I'm assuming you tried both memory chips in the known working slot.
I found setting the boot up sequence in BIOS is better than using F12.
Set your BIOS to boot the CDROM first. I suspect the hard drive has failed or has a problem. Do you have a floppy boot disk? Lenovo has PCDoctor bootable diagnostics on their website. You may have inadvertently bent a pin inserting the hard drive. Your CMOS battery could be dead but since that was untouched I would be surprised.
Sep 08, 2008 | IBM ThinkPad T30 2366 Notebook
Nothing happens
Depending on how big the knock was it could have been severe enough to damage your hard drive.  The boot up of the machine hence the fan is caused by the CPU heating and the fan cooling it however when the bios and CPU ask the hard drive to boot up it cannot thus that is the failure of your startingup. It may need the attention of serviceman to repair it and even he may suggest a replacement of the hard drive.
Oct 22, 2007 | Acer TravelMate 290 Notebook
Fujitsu LifeBook S7010D Notebook Logo
347 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
