Maytag neptune washer 5r code
The washer workes but it will turn on by itself , starts chiming and gives a 5r or Sr error code . Can turn the power off and after 15 seconds or so it comes back on and shows this code ....
agitateme
  • 88 Answers
SOURCE: washer Maytag Neptune
Most likely the motor control unit, the MCU controls the timer (loop circuit). Best way to check is to just pull the MCU out and visually inspect it for burned components, although it is not always visible. You may need to make some involved voltage readings to verify.
Posted on Sep 22, 2008
  • 106 Answers
SOURCE: MAYTAG NEPTUNE MAH9700AWW continues to fill on rinse, code ''oe'',
Check your exit hose spigot, it may be clogged. This is if your filter is all clean (ref manual, it may not be there, they want a tech to come by to make more $). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it (4 to 6 inches maximum) Of course some direct the hose into sink, fine. Snaking out your standpipe would be good too.
Rate me nice or not at all. Happy spinning! Nice to watch the machine spin, not your head!
Posted on Mar 04, 2009
  • 219 Answers
SOURCE: washer will not drain or run. It gives a code nd
pull back off washer and check your waterpump
Posted on Apr 17, 2009
  • 12 Answers
SOURCE: My maytag neptune washer will come momentaraly
There is a door locking unit that should lock when you press go. This must have failed. It lives just under the lid in the middle at the front. It is thermal piston, when you press go it gets power and extends. When it hits a micro switch that tels the washer the door is shut and allows it to continue, else it shuts down. To get at it you have to take the front off, leave the door on.
Posted on Nov 07, 2009
FAV6800AWDIY
  • 526 Answers
SOURCE: Neptune FAV6800AW Top Load Washer: My Neptune washer is showing error code dc..Once i...
See this post Clutch Fix if you want to DIY I will help you.
Post back if you have questions……..Rich
Posted on May 23, 2010
Maytag washer giving error code A0
Maytag Neptune Priority One Service
(888) 462-9824 call to the company to due the error code.
God bless you
Aug 01, 2012 | Maytag Neptune MAH5500B Front Load Washer
When i try to spin my clothes the code E3 pops up
Turn the machine off and then on. Enter the Service Mode by pressing the Chime and Exrta Rinse keys for 3 sec. Display the Diagnostic Codes by pressing the Rinse and Spin key. Clear the codes by pressing the Delay and Chime keys for 3 sec. Turn the machine off, unplug and plug in the power cord.
Nov 28, 2010 | Maytag MAH8700AWM Neptune Front Load...
There is an intermittent chime going off and it is say SR-5 on the screen
Found the manual which says it is a control problem and machine needs to be serviced.
Feb 08, 2010 | Maytag Neptune MAH6700A Front Load Washer
Maytag Neptune FAV6800AW Top Load Washer? makes a
more than likely it just needs a little leveling...lift front of washer . there are 2 leveling feet on each front corner under the washer.. they turn like a screw ..just adjust these feet till its level and you should be ok....shake the washer by hand . if it doesnt move it shoud be level,,,,an unlevel washer makes terrible noises ...as you know..thanks and have a great day
Jan 03, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune MDE9700AYW ts t5 error
Check to see if your thermistor is bad by measure the resistance. It should be 10K Ohms at room temperature.
If it's bad, replace it BUT you have to CLEAR to error code.
1. Enter to Service Mode by press CHIME and TEMPERATURE keys for 3 seconds or until 3 beeps are heard.
2. Access Diagnostic Codes by pressing WRINKLE PREVENT. A d will be displayed. Rotate the CYCLE SELECTOR KNOB in either direction to read it.
3. Press SENSOR DRY and TIME keys for 3 seconds to clear it.
4. Power OFF to exit Service Mode
5. Power ON
Hope this helps
Jul 25, 2009 | Maytag Dryers
What does the code Sr mean on a maytag neptune front load washer
Technical Manual say "System Relay Failure"
Diagnostic Code 34
Jul 16, 2009 | Maytag MAH8700A Front Load Washer
Maytag may8700aww washer with e3 code
This worked for me for the E3 error code: Turn the machine off and then on. Enter the Service Mode by pressing the Chime and Exrta Rinse keys for 3 sec. Display the Diagnostic Codes by pressing the Rinse and Spin key. Clear the codes by pressing the Delay and Chime keys for 3 sec. Turn the machine off, unplug and plug in the power cord. This dumps the memory. Evidently, if it gets full, it causes problems with the programming and messes up the cycles.
May 05, 2008 | Maytag MAH6500 Neptune Front Loading...
Error code PF
THIS is a "Power Failure " Clease the code (press Cancel button) and see if it starts up
Jan 23, 2008 | Maytag MAH8700A Front Load Washer
Error code "sr"
Sr is a stuck relay on your main board.Replace your pc board.
Dec 30, 2007 | Maytag MAH8700A Front Load Washer
Washing Machines Logo
165 people viewed this question
Top Washing Machines Experts
