Question about Goodman Manufacturing 3.5 Ton 13 Seer Goodman Air Conditioning System - GSX130421 - ARUF36421
Goodman Manufacturing Model aruf36421
Unit keeps breaking the circuit. have changed both sequencers to no avail
  • Lynn Burrough Apr 20, 2014
    Found and fixed a loose wire on the circuit breaker
I just installed this unit and can not get the blower to run
Seriously depends on what unit you have. Model # & serial #? You can "jump" R to G at the unit. If its a standard Goodman AHU there may be a terminal block or just some wires that were factory installed outside of the unit. R to G will send 24v to the blower relay, sequencer or board (depending on model) energizing the relay and then returning to common. If you have tried that you should ensure you have proper line voltage 220-240vac. at the service breakers on the AHU.
May 18, 2015 | Goodman Manufacturing Goodman GPH1330M41...
My Goodman ARUF182416 does not stop running. I have disconnected the thermostat and the blower and heat element stay running until turning off via circuit breaker.
From what I can gather it seems like a power source error (red wires attached to the transformer) is allowing it to keep running. Another possibility is it could be your speed tap. These are my speculations about what is occurring.
Dec 11, 2014 | Goodman Manufacturing Goodman ARUF182416...
Goodman model aruf486016AA is not blowing hot air
Need more info. Does blower come on when calling for heat?
Nov 11, 2013 | Goodman Manufacturing Goodman ARUF486016...
Fan keeps running
the safety built in is when the sequencer goes bad it turns on the fan so it doesnt create a fire. replace sequencer. to make sure check amps if over 6 or7 amps sequencer is faulty
Jun 08, 2013 | Goodman Heating & Cooling
Air handler keeps running
Most likely this the fan delay. They weld closed and cause the fan to continuously run. They are available at your GOODMAN dealer.
Feb 20, 2013 | Goodman Manufacturing Goodman ARUF193116...
#model-cple48-1 split unit sometimes inside fan dont turn on,appears to be circuit board in outside unit#b12260-08 is this still available.
Can you set your thermostat to on instead of auto on the fan? If this fixes it it would be a loose connection at the themostat or broken wire. (broken wires are very common and they will make and break connection they break because the copper wire is small and it gets scored when stripped) I do not see a way the outside unit could cause your problem. If it was any circuit board it would be the one in the furnace.
Aug 03, 2010 | Goodman CLQ36AR49 Air Conditioner
Outside unit not running, inside unit is running, but blowin heat. Goodman unit MODEL CK-J60-1
eletrick furnace? then it is a stuck heat sequencer(relay) the first stage heat sequencer also runs the fan in heating
Jun 26, 2010 | Goodman CKL60AR60 Air Conditioner
Unit continues to run in emergency heat when shut off.
If you turn tstat off does it still run. If so you have sequencer stuck. Replace sequencer. Also you may ahve abad defrost board out side. When a unit goes into defrost it will bring on heat so you will not get a blast of cold air. Sometimes the defrost board sticks and keps the heat on. Disconnect white wire at outside unit to break circiut. If hat goes off bad defrost board. You can change that yourself. Keep in touch Rus
Dec 08, 2009 | Goodman CPLE24-1 Air Conditioner
Goodman Manufacturing 3.5 Ton 13 Seer Goodman Air Conditioning System - GSX130421 - ARUF36421 Logo
41 people viewed this question
Top Goodman Manufacturing Hand Tools Experts
Don Numinen
Don Numinen
Ivan
Ivan
Level 1 Expert
Bill Boyd
Are you a Goodman Manufacturing Hand Tool Expert? Answer questions, earn points and help others
