Question about Kenmore HE2 Plus Front Load Washer
Top dishes do not clean well (seems to get too little flow)
If I open it - I can see that the water drains from top sprayer - and it rotates. But it does not clean. A bowl that had oats in it does not clean.
    Problem Solver:
  • 12 Answers
Who makes the unit if . I work on K/A units alot along with other brands. The sump has a screen in it that needs to be cleaned out you should also check the spray arm (take it out) and clean it. But most of the time it is the sump (soft food grinder) is cloged up.
Posted on Jun 19, 2009
The soap does not seem to dissolve to clean the dishes and I do not seem to hear the water spraying during wash cycle
your rotator sprayers may be blocked or pump is broken,
remove rotator sprayers by gripping the stem and pulling or twisting out, check manual.
check that the holes are clear.
then try starting your machine with the sprayers out and see if you can hear the water.
if you dont hear anything the pump might be broken,
fistly check that the filter in bottom of machine is clear.
I hope this was useful.
Jan 24, 2011 | Frigidaire Dishwashers
Our newer dishwasher does not clean the dishes presently. The water heats up, and drains properly, but I noticed the sprayer nozzles are not spinning when I open the dishwasher.
Try manually rotating the spray arm. Check the orifices & clean if clogged.
After loading the dishes check every time before closing the door for free rotation of the spray arm.
Apr 01, 2010 | KitchenAid Architect? II U SERIES KUDS03ST...
Frigidaire Dishwasher FDB2810LDC1 not draining
Sure its redeemable if you have the time and money. If I understand you correctly when you move the lowewr spray arm the water drains out? If this is the case then more than likely its a pump motor or solenoid. Reason I say this is on the bottom of the spray arm is a impeller and under that is filter and then pump impeller that drains the water. If its not draining but will by hand then its your pump motor or solenoid. When you start the washer then press cancel/drain do you hear anything? Maybe a humming sound. One more thing could be a thermal fuse for the motor. These are usually not resetable its a one time fuse if it blows you have o buy another one.Hope this helps
Jan 25, 2010 | Frigidaire 24 in. PLD2850 Built-in...
The top drawer does not get my dishes clean. When the come out, it seems as though water is on the inside but they are not clean
Clean the sprayer arm. You can try running dishwasher cleaner through the machine or remove the arm and make sure the holes are clean and free from obstruction. If this is clear then you will need to check the pump to make sure it is pushing water at a sufficient flow to clean the dishes on the top rack.
Oct 08, 2009 | Dishwashers
DISHES ARE NOT COMING CLEAN BYPASSED THE DOOR LATCH TO WATCH CYCLES,LOOKS LIKE THERE IS NOT ENOUGH WATER PRESSURE TO ACTIVATE THE WATER TOWER AND ROTATING ARM?WATER PUMPS OUT BUT NOT ENOUGH TO MAKE THINGS...
I had the same problem and fixed it by disassembling the lower spray arm and return filter, and cleaning all the junk out.
Most dishwashers have 'risers' that bring the water up to the top sprayer or arm located under the top rack. If the recirculating pump is plugged even a little there won't be enough volume or pressure to get the water up there.
Test this by putting a dry muffin pan in the top rack, flat, and running the dishwasher for a bit. If there is no water on the top (or the bottom) either the top sprayer or the sprayer arm underneath the top rack is not getting enough volume.
To fix this you need to clean out the screen and filter, where the water returns to be recirculated. If you don't have any confidence to remove the parts and clean it out yourself, get an appliance repair person to do the job.
Aug 24, 2009 | Dishwashers
Dishwasher is running but dishes aren't clean
sounds like the top or middle spray arm isn't rotating, most likely a clogged spray arm, try and remove sprayer arm and clean it
Aug 22, 2009 | Kenmore 24 in. 17032 Built-in Dishwasher
Upper rack sprayers not working on LG ldf7811 dish washer
Check the pump out. Even though the Hose is and tubes are clear it does not necessarily mean that the pump is not pumping water to the top sprayer. One way you can do this is take off the upper spray tube and lay it in a glass or bowl and turn on your machine for a minute or so to get the water flowing if it flows then I would take off the spray assembly itself and make sure that there is no blockage on the bearing race
Apr 08, 2009 | LG 24 in. LDF 7811 Built-in Dishwasher
Kitchen Aid dishwasher - top shelf not getting dishes clean
Is the top sprayer clean and not clogged so that the water can flow through? The top may not be functioning properly.
Jan 16, 2009 | KitchenAid Dishwashers
Dishes not clean
There may be a couple of solutions to your problem. First, if you are not rinsing the dishes thoroughly before loading, your sump area in the bottom of the machine will get clogged, thus preventing enough velocity to reach top rack. Second, and most likely, your water inlet valve (or solenoid valve) is restricting. You have a timed fill mode through the timer and if the valve is not opening fully, you do not get the proper rate of flow into the machine. Replace the valve and your problem will most likely be solved.
Dec 01, 2008 | Maytag MDB7100AWB Dishwasher
Dishes not washing clean
check water level in machine
may be not filling enough and the wash pump is starved from water thus not pushing water to upper arm
drain water from machine dismantle and clean out air tube to pressure switch take off air tube at pressure switch and blow back into sump then pinch air tube with fingers to stop air from flowing back up tube then refit to p/s
run and see if that solves problem
Feb 15, 2008 | Dishwashers
Kenmore HE2 Plus Front Load Washer Logo
50 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
