Question about Westinghouse LTV-32w1 32 in. HD-Ready LCD Television
Ltv-32w1 as pc monitor
Do I need any software or special hookups to use tv as a pc monitor?
    Guru:
  • 1,463 Answers
Have a look here http://microsoft.com/windowsxp/mediacenter/using/setup/cables.mspx
riz.
Posted on Nov 02, 2007
Nothing at all is required, it acts just like a normal monitor. It even supports plug n play.
If your computer supports it, I would suggest using the DVI connection to the TV, as it will result in a cleaner picture. The TV does have normal VGA inputs as well, so at most you would need a cable (if you dont have one already).
Posted on Nov 11, 2007
Monitor keeps going into sleep mode
try a different monitor / tv (some have pc hookups) and see if it really is your monitor or your PC not providing a signal
Sep 02, 2014 | Compaq Computers & Internet
How to install software to gfive g111 mobile
Computer Monitors
Nintendo home consoles are designed for use through home televisions and VCRs, using standard A/V, S-Video, component, or RF connectors (for older systems). Computer monitors typically do not have these connections. There are however two ways a hookup to a computer monitor could be accomplished:
With a PC TV Card:
A TV card inserted into your PC may allow you to connect your system if the card has the proper connections (such as RF, A/V, S-Video, component, or Coaxial). However, we have found that the image quality is not as clear as it is on a TV, in most cases.
With a Direct Connection (RGB or DVI Cables):
Nintendo does not manufacture any cables to make an RGB or DVI connection. While other companies may manufacture wires that can make this possible, we are not able to recommend them, as they are not licensed by Nintendo.
May 19, 2012 | Nintendo Super NES Console
How to connect laptop to Panasonic TV LCD TX-L42U2B
Laptop to TV hookup all depends on what the laptop has for output to a monitor and what the TV has for input. Your laptop should have a monitor output, a 15 pin female jack. You need a cable (male to male) with these 15 pin connectors at each end to hookup to a TV with a PC input jack. For the audio, use a 3.5mm stereo audio cable. Hookup from earphone out on the laptop to the TVs PC audio input jack. If the TV has no PC input jacks, there are other ways to connect. See this link:
http://columbiaisa.50webs.com/laptop_to_tv.htm
May 18, 2011 | Televison & Video
I hooked up my PC to my LG 50 in. HD 1050P to use it as a large PC monitor nothing happens, my Pc is an IBM NetVista do I need software to activate?
if your PC works with a standard monitor, just make sure you select the correct input on your TV. No special software needed.
Dec 27, 2010 | IBM NetVista PC Desktop
DSC hookup
It appears to have a computer interface,It uses an RS232C Interface, a small D9 Socket on unit, you need a specially wired cable, to talk to your unit, with GPS software, it sends out NEMA codes to the PC. You also need driver, and software, software at the least. www.jeppesen.com/documents/.../FullCompatabilityListAug09.pdf software compatibility list above.
I looked but couldn't find a manual...
Apr 03, 2010 | JRC Plot 500F GPS Receiver
How do I hookup my sharp liguid crystal tv as a pc monitor ? I have the analog RGB hook to my PC in but I cant see the picture.
If the tv is connected to your pc, then you need to go into your video properties and select the tv as your monitor.
Feb 15, 2010 | Sharp LC-19SB25U 19 in. LCD HDTV
What wires / connections do i need to run my home pc through the t.v
Depends on what hookups the Tv and PC have. Newer laptops have a HDMI jack, otherwise the external monitor jack will do. Then the TV must have a monitor hookup. Most likely not. So then you'll need some type of a conversion cable to go from PC to TV. Check your local Best Buy for the cable.
Nov 25, 2009 | JVC LT32DS6 32 in. HDTV-Ready LCD TV
What to hookup wireless camera and dont have connections on compu
u need a port on PC at which u can hook up the output from ur wireless reciever those red and yellow rca pins if u dont have a tv card yet, cheap solution is either u buy a PCI TV card normally it comes with an input port for video capturing check it out when buying, u can watch ur transmission live on software tv screen and plus u can enjoy watching tv on ur PC as well if u hook up ur RF cable to it but if u need specifically for monitoring purpose then u can go for DVR card for more func of rec the feed and hook up multiple cameras and watch them together
choice is urs
let me know and pls do vote me if u find me fixing ur problem
Feb 21, 2009 | HP Compaq Presario SR1123WM PC Desktop
Wiring problem
waste of time.
if you need a monitor, buy a monitor.
if you need a tv, buy a tv.
Sep 27, 2008 | LG Studioworks 700S 17" CRT Monitor
How do you take off power save mode on a T1100 emachine. When you turn on the computer the monitor says PC in power save mode.
This means that there is no Video Signal that Is going to the Monitor, I would check all the Connections and make sure that it is plugged in correctly. Also, Not all the time, But in a Rare Case, You need to install the software that comes with the Monitor, I have had this Happen Once or Twice. Hookup the Old monitor, Install the Software, and then Connect the New Monitor, This should work.
Jul 07, 2008 | Computers & Internet
Westinghouse LTV-32w1 32 in. HD-Ready LCD Television Logo
82 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
