Question about Janome MyLock 634D Mechanical Sewing Machine
Why does the right needle keep breaking in myloc 634d
The right needle in my Mylock 634d keeps on breaking & I cannot see where or what is causing it to happen. I have checked & rechecked the threading of the loopers and the needles.
    New Friend:
  • 44 Answers
I agree with John Smeed It could be that the needle is bent or in the wrong way if it keeps on breaking it must be hitting the throat plate or it's timing may be out( a pro job) Also check the needle is in as high as it can go.
Posted on Apr 20, 2014
    New Friend:
  • 9 Answers
Check that the plate that the needles go through is not damaged or warped in any way ....also check on the needles themselves as if they are cheap you may have rogue needles or indeed not the right needles for the job,
Posted on Apr 19, 2014
  • Janome Master
  • 1,388 Answers
  • 11 Answers
SOURCE: janome mylock 634D overlocker
this very same thing happened to my flat machine turned out to be a piec of material jammed in the workings also wrong oil used or it might be thread jammed try and see
Posted on Jun 16, 2009
mohammed387
  • 1952 Answers
SOURCE: threads fine, lower looper breaks after serging three inches
tight for thread in loower looper
Posted on Jan 22, 2009
  • 29 Answers
SOURCE: Janome left needle thread breaking CONSTANTLY
Sounds like a tension problem. Your machine should have two tension adjusters. One for each needle. The book that came with your machine will tell you how. Another possibility is a bent needle.
Posted on Feb 27, 2009
SOURCE: MyLock 634D won't serge
Check that your lower looper is actually threaded and not tangled with the upper looper (needle thread) when it moves. I wish they'd include pictures in the manual how to lay the thread.
Posted on May 18, 2009
SOURCE: The needles on my Janome 9102D keep breaking
I had a similar problem with my machine. What I've started doing with mine is setting the stitch length at 3 and the differential feed ratio at 1.0 then I set all 4 thread tensions at 3. I thread the machine from right to left, and then when everything seems to be working okay I take scrap material to test the tension and then set them to suit the material I'm using. Right now I'm working with a twill so my settings are 4-4-5-5. This seems to have stopped the thread slipping off the bottom looper and I haven't had any more needles break. I hope this is helpful.
Posted on Sep 01, 2009
Thread breaking
adjust the thread tension of the one that is breaking. If it is the needle the adjust will be in front of you . If it is the bobbin then there will be a small screw holding a flat spring that the thread goes under. Have you put the bobbin in the holder correctly as it is critical the way the thread un winds from the bobbin.
May 29, 2013 | Janome MyLock 634D Mechanical Sewing...
Tension to loose and missing stitches
SKIPPED STITCHES ON A SERGER
1. Is the needle bent or worn--replace
2. Is the needle inserted correctly into the needle holder--check needle
3. Is the Serger threaded correctly--rethread
4. Is the presser foot pressure right for the fabric--adjust
use a scrap piece of fabric to sew on as you adjust the tension
when the tension is to loose adjust one number higher till stitch
looks good
here's 2 links for a manual one is a hardcopy & the other is a
pdf downloadable--one is a different price from the other
http://www.sewingpartsonline.com/instruction-manual-janome-mylock-634d.aspx
http://www.sewingpartsonline.com/instruction-manual-janome-mylock-634d-download.aspx
Sep 08, 2012 | Janome MyLock 634D Mechanical Sewing...
MyLock 134D keeps scrunching
have you tried changing the needle or needles?
are the feeddogs in the up position?
check the tension to make sure it's not to tight
rethread the machine,, just incase the machine is not threaded
correctly
Jul 11, 2012 | Janome MyLock 634D Mechanical Sewing...
New Home My Lock 134D Serger. The right needles keeps breaking. Yesterday I realize it is hitting the pressure foot. I have changed out the needle (size 14) about 7 or 8 times now. I have adjusted the...
check to see if the presser foot is loose
check to see if the needle is in backwards
if the presser foot is tight & needle is not in backwards then it could be a timming problem, since you said the needle is hitting the presser foot
please rate this with the thumbs in upper right hand corner
Aug 08, 2010 | Janome MyLock 634D Mechanical Sewing...
Top needle thread keps breaking
top needle thread breaking is probably caused by a dull or bent needle or a needle that is not the right type for the machine
Apr 12, 2010 | Janome MyLock 634D Mechanical Sewing...
Janome mylock 634D overlocker
Feb 25, 2009 | Janome MyLock 634D Mechanical Sewing...
Left needle thread breaking
My first inclination would be to change the needle. I could have been defective from the beginning. If it will serge without left needle, then you know that everything else is threaded correctly. Good luck.
Mar 24, 2008 | Janome MyLock 634D Mechanical Sewing...
Janome MyLock 634D Mechanical Sewing Machine Logo
102 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
