Question about Samsung Series 7 700A3B - All-in-one - 1 x Core i5 2390T / 2.7 GHz - RAM 8 GB - HDD 1 TB - DVDnRW nR DL / DVD-RAM - HD Graphics - WLAN : 802.11b/g/n, Bluetooth 3.0 HS - Windows 7 Home Premium 64-bit - Monitor : 23" wide LED backlight TFT
Hard drive
How do you open the case on this samsung unit ?
    Genius:
  • 1,061 Answers
Are you trying to replace the harddrive??
Posted on Apr 28, 2014
Open case of samsung writemaster external dvd drive how to
I just had the same problem and this is how to do it:
1: Carefully pry the silver trim off. Begin at the back of the unit. You might need to use a knife or small screwdriver to pry it loose.
2: Unscrew the small philips screws, two on each side.
3: Press the plastic tabs (three on each side) to release the top.
4: lift off the metal cover at the back.
If you need to, you can lift out the optical unit from the front since it's not fastened in any other way than the standard IDE and molex connectors.
Feb 04, 2014 | Samsung SE-S184 DVD Writer DVDR/RW...
2tb verbatim external hard drive will not power up all of a sudden
A 2Tb drive is most likely to be a SATA drive, so you can use a SATA cable and power connector in your computer tower. The case is just there to allow the power and data interfaces to be contained. Or just plug it into a hard drive dock.
Apr 15, 2013 | Verbatim Computers & Internet
My samsung G2 cant read, it ask to be formatted but it cant be completed n propreties shows 0 used space, 0 free space
Most likely the hd is bad. If you want to know for sure purchase a usb enclosure, break open your drive case and put the hd in the enclosure. That will tell you if it's the hd or the circuitry of your case.
Oct 29, 2012 | Samsung G2 Portable External HX-MU064DC/...
I plugged in the wrong power cord to my p/n 9nk2ag-500. Is there a way to fix? or self extract files? I keep hearing about a SATA gadget that can convert any externat HD to a USB powered, will this bypass...
yes if the hard drive is not damage
you can use a external sata case to read your hard drive.
remove the casing off the seagate freeagent to get to the hard drive.
you need to get a 3.5" external sata case.
you can get one from newegg.com or at your local fry's
this is what i have
http://www.newegg.com/Product/Product.aspx?Item=N82E16817153066&cm_re=thermaltake_sata-_-17-153-066-_-Product
which supports both 3.5" and 2.5" sata hard drives.
Mar 20, 2011 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Damaged hard drive
are you sure you set your Hdrive with correct jumper setting? check for jumper setting of your Harddrive
Mar 25, 2010 | Toshiba 6 Bays Magnia 6 Unit Hard Disk...
I have Samsung SHR-1040 DVR in use for 3 years. It is giving a humming sound now which is annoying. All other function working OK. What could be the problem
There is a small fan in the back of the unit which might be rubbing or failing. It's a standard type of fan so any good computer parts store will have a comparable replacement. Or it could be the hard drive is beginning to fail. You will have to open the case to find out.
Mar 17, 2010 | Samsung 4 Channel Dvr
I accidentally dropped my 350 GB WD Passport external hard drive and now my computer does not recognize it. Is it still repairable and can i recover the files stored there. Do you have a service center...
Try it another computer.
If it still fails, there are alot of online companies that will be able to retrieve the data for you- although Im guessing the drive its self will be unusable.
Sep 16, 2009 | Western Digital Passport WDXML800UE...
Unit will not power up.
Hey,
The case is most likely faulty, open the case and take the hard drive out from it, then connect it to your computer directly, inside.
If the hard drive has a special connector that you can't connect to your computer please tell me what kind of connector it is and I'll see if theres a adapter available or new case.
Thanks and good luck.
Ekse
May 05, 2009 | Seagate FreeAgent Go 120 GB USB 2.0 Hard...
Samsung SP0802N External Case?
Hi, try this. This will work with your HD. 2.5"/3.5" EN391-S2HC USB 2.0/eSATA SATA HDD Dock w/Card Reader & Hub
Dec 12, 2008 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Opening external drive case
Actual solution. The darker side panels pop off and they alone hold things together. Simply pry each side away at rear. That would be end with power and USB connections are.
Dec 10, 2007 | Maxtor Personal Storage 3000LS (G01J060)...
Samsung Series 7 700A3B - All-in-one - 1 x Core i5 2390T / 2.7 GHz - RAM 8 GB - HDD 1 TB - DVDnRW nR DL / DVD-RAM - HD Graphics - WLAN : 802.11b/g/n, Bluetooth 3.0 HS - Windows 7 Home Premium 64-bit - Monitor : 23" wide LED backlight TFT Logo
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
