Question about Sony VAIO VGN-CR220E/P Notebook
I need cd recovery to my vaio vgn cr 220e. Replace hard drive and i dont make recovery cd. HELP ME PLEASE!!!!!!!!
    President:
  • 2,678 Answers
Why did you replace the HDD? Was it faulty or just an upgrade?
Posted on Jun 19, 2009
Just got a second hand VGN CR 220E running Vista 32 bits that had the hard drive changed ( the OS is the same ). Now the Web Cam and the Instant Mode dont work. I believe its missing some drivers ( the...
If you want to shell out a few dollars, driver detective is an option. I don't like to recommend it, but it does work if you don't wish to download drivers one-by-one. If you don't want to do this, you should go down the components in the device manager and install or reinstall every driver. That's the only surefire way to get your peripherals working again.
Jul 28, 2011 | Sony VAIO VGN-CR220E/P Notebook
I have a sony VGN CR-220E which re upgrade to vista ultimate that i could not install the webcam driver ?
According to the spec. it should be OK. Don't forget to download the drivers from Sony.com otherwise it won't work correctly.
Learn more about the Sony VAIO VGN-CR220E/P Model BrandSONY SeriesVAIO CR Series ModelVGN-CR220E/P General ColorCosmopolitan Operating SystemWindows Vista Home Premium CPU TypeIntel Core 2 Duo T7250 2.0G Screen14.1" WXGA Memory Size2GB DDR2 Hard Disk200GB Optical DriveDVD Super Multi Graphics CardIntel GMA X3100 Video MemoryShared memory CommunicationModem, LAN and WLAN Card slot1 x ExpressCard /34 Slot Dimensions13.2" x 9.8" x 1.25-1.67" Weight5.5 lbs. TechIntel Centrino Duo Mobile Technology CPU CPU TypeIntel Core 2 Duo CPU SpeedT7250(2.00GHz) CPU FSB800MHz CPU L2 Cache2MB Chipset ChipsetIntel GM965 Display Screen Size14.1" Wide Screen SupportYes Display TypeWide XGA Resolution1280 x 800 LCD FeaturesXBRITE-ECO technology Operating Systems Operating SystemWindows Vista Home Premium Graphics GPU/VPUIntel GMA X3100 Video MemoryShared system memory Graphic TypeIntegrated Card Hard Drive HDD200GB HDD RPM4200rpm HDD InterfaceSATA Memory Memory2GB Memory SpeedDDR2 667 Memory Spec1GB x 2 Max Memory Supported4GB Optical Drive Optical Drive TypeDVD Super Multi Optical Drive InterfaceIntegrated Optical Drive SpecDVD+R DL Write: 4x max
DVD+R Write: 8x max
DVD+RW Write: 8x max
DVD-R Write: 8x max
DVD-RW Write: 6x max
CD-R Write: 24x max
CD-RW Write: 16x max
DVD±RW: Yes (DVD±R DL/DVD±RW/DVD-RAM)
CD Read: 24x max
DVD Read: 8x max
DVD-RAM Write: 5x max
DVD-R DL Write: 4x max
DVD-RAM Read: 5x max Communications ModemIntegrated V92/V.90 Modem (RJ-11) LAN10/100Mbps WLANIntel PRO/Wireless 4965AGN Network Connection (802.11a/b/g/n)
Jan 01, 2011 | Sony VAIO VGN-CR220E/P Notebook
Recovery DVD for Sony Vaio VGN-N130G
Contact Sony WEB site support, they can supply a recovery CD.
Sep 14, 2009 | Sony VAIO VGN-N130G/W Notebook
I want to complete change hard drive on a vgn s4hp/b but i dont have recovery cd.how can isolve this prpblem?
You definitely need to get a recovery CD (Windows XP or Vista). There's no way for you to reinstall windows if you don't have the CD.
May 07, 2009 | Sony Computers & Internet
Brought LCD Screen to replace cracked one. How to I take apart and replace screen. Any help would be greatly appreciated
there will be two random black spots on the side of your laptop if you pull them off you will find two screws that will be the same on the other side undo all of the screws and pull the plastic of the front of your laptop and the screen will just slide out then follow the wires and you will find a little bit ware you can unplug the wires then do the opisit to putt the screen back in .
please rate my help to you as i am becoming a expert. thank you.
Apr 21, 2009 | Sony VAIO VGN-C140G/B Notebook
I have vaio cr 220E the motion eye stop working :-(
Re-install the drivers of the Camera and everything will be fine :)
Mar 04, 2009 | Sony VAIO VGN-CR220E/P Notebook
Cannot launch vaio recovery center after unsuccessfull restore to original condition, now have hard drive error and bugs with windows vista. Sony support does not list the vaio cr-220e on its driver update...
Click here for Driver page
Try again to launch the VAIO Recovery Center by following
  1. Restart the Computer, tap the F10 to access the Recovery Partition.
  2. At the Edit Boot Options, press the Enter Key.
  3. Then, in the VAIO Recovery Center window, select the Restore C: Drive.
  4. Then, follow the onscreen instructions..
hope this helps..
If any error occurs while recovery..reply with the error message..
Mar 02, 2009 | Sony VAIO VGN-CR220E/P Notebook
Formating problem
hi i have sony vaio VGN-NR-220E i want to know how i can format this system there vista operating i want Windows xp
Aug 22, 2008 | Sony VAIO VGN-NR220E/S Notebook PC
Sony Vaio VGN CR-220E
Haha!
I had such dreams too with one of my old Vaio. I really wanted to upgrade the processor and graphic chipset. Turns out that the latter is impossible (it was soldered to the motherboard - it wasn't a graphics card, just an all-in-one chip), as for the processor I was able to take it out but I ran into several problems:
1) vaio added electronic components to the motherboard that made higher CPU speeds unachievable even if the motherboard's cipset (VIA) was able to do that.
2) the cpu maker (AMD in my case) kept telling me that their mobile cpu were custom designed for that specific laptop, so new cpu would be incompatible. Also mobile CPUs are, apparently, only sold to laptop makers, unlike OEMs... (eBay but at ur own risk!).
3) When buying a new CPU, u need to check factors such as the number of pins (mobile cpu are much smaller), voltage, current, wattage and heat dissipation (very important, ur current heat sink was designed for ur current cpu).
But maybe things have changed now. In my case, I could only upgrade the RAM and the hard-drive to larger and faster versions, and the difference was quite significant difference. Faster booting and better internet experience.
May 03, 2008 | Sony VAIO VGN-220E/B Notebook
Sony VAIO VGN-CR220E/P Notebook Logo
238 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
