Question about RTO Oar Sockets
Rom not working - RTO Oar Sockets
Cdvd rom dont work on emachine, will a usb 2.0 external dvd rom drive work
If it is USB CD_Drive you can plug it in a USB port of the computer. You may have to install drivers, but usually Windows Update can download them from the Internet.
Apr 07, 2013 | E-Machines emachines (emachinees) CD-ROM...
My cd rom drive does not recognize media
First check CD (bad, scratch) Change it... if not OK then
then Check Software (like media player, VLC player) re-install it
if not OK then...
Then check Cable of cd rom (loos connection) in not OK then
bring any friend's or neighbor's CD ROM for few minutes and replace... if other CDROM working ok then problem in your CD ROM
open cd rom and Check Lance (head) of CD rom... mostly lance not working in these cases.
Oct 13, 2012 | Dell Inspiron 8600 Notebook
Cd rom doesnt work with service pack 3
try to reinstall the device driver of your cd rom, i also have my cd rom but it works with my service pack 3, it may somehow impossible that it wont work unless your cd rom becomes faulty due to power surges, etc.
Jan 11, 2010 | HP Pavilion 520c PC Desktop
CD-ROM drive doesn't acknowledge DVD-ROM, what's wrong?
CD-ROMs dont play dvd becuase they are not designed to read dvd.
If a dvd drive for your model is not available, you can buy an external usb dvd drive.
That should solve your problem
Dec 28, 2009 | Dell Dimension E521 PC Desktop
How to fix my cd-dvd rom,its not working?
Shut down your system, turn it upside down, loose the screw(s) that holds the Rom to the system, detach the Rom from the system and turn the system back on without the Rom.
Allow the system to boot and after a while shut it down again. Then fix back the Rom to the system, screw it and put on the system.
Test the Rom and if it still does not work, use cotton board to clean the lens. If after all these and your Rom does not still work, then I think you need to get another Rom.
Best wishes.
Dec 23, 2009 | Acer Aspire 3000 Notebook
My acer aspire 5315 dvd rom doesnt work at all but somtime it do
There is a problem with the DVD ROM. Maybe it is not well fixed and causing conflict which result in making the computer slow. And maybe it is not contacting the system well again, that's why it worked and later not worked when it loose contact.
I would advice that you shut down your system, loose the DVD ROM and put the system back on without the DVD ROM after a little while when the windows must have settled, shut down the system again and fixed back the DVD ROM. Make sure it is well connected and put the system back on again. Test the DVD ROM and see if it would give the same problem. If it does, then may be you will have to replace the DVD ROM.
One a DVD ROM is bad, another one needs to be purchased, because it is usually difficult to repair DVD ROM expect in minor case.
I wish you the best.
Dec 18, 2009 | Acer Aspire 5315 Notebook
My samsung cd-rom sc-148c drive is not working. It is not listed in "My Computer". I have uninstalled and reinstalled it but that does not work.
Is the CD-ROM drive on a separate cable on the second IDE controller on the desktop motherboard? Then the jumper setting can be set to Master or Slave if no other drive is connector to this cable.
If the CD-ROM is also on the first IDE controller and IDE cable as the hard drive then the jumper setting on the CD-ROM must be set to SLAVE because the hard drive would be jumpered as MASTER.
Check the BIOS setting to see if the CD-ROM drive is detected.
If the CD-ROM still does not work after you checked and configured the CD-ROM drive, then is is faulty and needs to be replaced.
Dec 16, 2009 | Samsung SC-148 CD-ROM Drive
Toshiba Satellite P205D-S7479 Drivers for DVD-ROM
Download new driver files of pioneer dvd drive fron internet.
Apr 17, 2009 | Toshiba Satellite P205D-S7479 Notebook
Cd-rom
CD-ROM not working in Windows 9x, 2000, or XP. If after cleaning the CDs that do not read you're still getting errors ... If, however, the CD-ROM does not work, refer to the next and final possibility
CD-ROM recieving power but does not work. CD-ROM receiving power but does not work. Issue:. CD-ROM receiving power but ... CDs are read by a laser within your CD-ROM drive
Good Luck/Please dont for get to Vote, Thank You.
Dec 15, 2007 | Acer Aspire 3610 Notebook
Bad BIOS checksum.... CMOS bad checksum errors
BOOT BLOCK COMPATIBLE VERSION VER .005
BAD BIOS CHECKSUM
CHECKING FOR CD ROM
READING FILE "P5SD2VM.ROM"
NO CD-ROM FOUND
CHECKING FOR FLOPPY DISK
NO FLOPPY DISK FOUND
Does someone already fix this problem??????
Nov 15, 2007 | ASUS M2N-MX Motherboard
RTO Oar Sockets Logo
67 people viewed this question
Top RTO Boating Experts
merc racing
Level 1 Expert
Mike
ffstaffsta
ffstaffsta
Are you a RTO Boating Expert? Answer questions, earn points and help others
