Question about Jacuzzi Home
How can i find a cover and handles for Jacuzzi T581805 Water Rainbow Faucet ? I am selling my home and the cover was gold and has discolored?
I am looking for the faucet cover only and knobs
arealplumber
  • 33 Answers
SOURCE: low pressure and flow on hot water side of single handle faucet
It could be one of two problems, one simple, one serious.
  • Easy fix
  1. Turn off hot water angle stop under sink to faucet.
  2. Remove supply line from hot angle stop.
  3. Place end of supply line in a small bucket to catch some water.
  4. Turn on cold water for a couple of seconds and backflush debris from faucet.
  5. Reconnect supply line.
  6. Turn on angle stop and test
  • Complex fix
If you have steel pipes you may be experiencing reduced flow due to corrosion in your pipes. Reduced hot water pressure in the kitchen faucet is usually the first sign since this is the faucet that is most used in the home.
Repiping is a job for a professional. Another symptom you may need a repipe is orange colored or rusty water.
Posted on Dec 05, 2008
  • 68 Answers
SOURCE: Single handle Pioneer shower faucet
its the mixing slide in there its stuck u can take it apart at the handle it pulls out shake it if it doesnt move its bad. what happens is over time sediment gets in there and seazes it up. if you take it apart and its not stuck then its ur mixing valve on your boiler is bad good luck
Posted on Dec 21, 2008
  • 148 Answers
SOURCE: Kohler Forte Single Handle Faucet Leaks
you will have to replace the ball assembly with a repair kit
1 turn the water off under the sink (hot and cold)
remove the handle ( you may need an allen head wrench to remove a hex screw or you may have to take a channel lock pliar and unscrew achrome
nut over the ball mechanism
after the handle comes off there is usually some type of lock nut that you must remove to remove the ball mechanism
remove the ball (usually chrome or brass(ther are usually little springs and rubber washers under ball
take ball and washer to ACe or lowes and match the pieces (usually sold as a kit
follow directions and installl
turn water on and pat yo!ur self on the back !
Posted on Jan 05, 2009
  • 297 Answers
SOURCE: No hot water flow from faucet/shower
change the cartridge it is bad or defective.
Posted on Jul 20, 2009
  • 123 Answers
SOURCE: I have a 1928 home with a speakman mixometer, the
http://www.plumbingspecialties.com/downloads/PPfistertoSpeak.pdf......this website offers several blow up diagrams of the mixometer. More than likely it is the packing and all you have to do is tighten the packing nut. You can do this by removing the handle and tightening the nut below it. You may have to remove the escuteon to gain access but the blow up should help you. If you have any questions just ask.
Thx
Ken
Posted on Sep 08, 2009
Newly installed jacuzzi only has hot water for about 30 seconds, then water is tepid only.
This issue will have nothing to do with the jacuzzi tub. You will find the problem exists in the way your home was plumbed by the plumber.
Somewhere there is a clog in the water line going to the hot water faucet.
Find that and you will solve your problem.
Rod
US Parts Center
Mar 06, 2014 | Jacuzzi Home
Delta T2738 Deck Mount on Jacuzzi Tub. Hot Water side leaking.
With the detailed part number you have, I would just walk into stores like Home Depot or any plumbing store and they will give you the exact parts you need. They are not expensive and a lot of them are standard parts and come in kits.
Good luck.
Apr 08, 2013 | Delta T2738 Lahara Deck-Mount Two-Handle...
My jacuzzi Waterfall faucet drips
Shut water off and remove knobs. Replace valves on side leaking. Go to Home Depo they will help.
Dec 03, 2012 | Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner...
Cold Water Drips from Spout after shutting off
The spout's seal is not sealing off the water properly any longer. You can replace the seal if you are handy. It is a little tricky but comes with replacement instructions. You may be able to find the replacement part at Lowes or Home Depot. Regardless as to where it comes from, it has instructions. I hate to say this but I would rather replace the unit rather than trying to replace the seal. However, this type of unit is pricey and it is more cost effective to replace the seal. NOTE: Doing any plumbing work may require you to cut off the water supply to this unit. If you dont have shut off valves to this direct water supply, it may even require you to shut off the water to the home. Good luck.
Jan 20, 2011 | Jacuzzi Water Rainbow Tub Faucet ...
I have my Mom's 193909WB coffeemaker, It runs like a top! How do I clean it?
Here are the cleaning instructions directly from West Bend's instruction manual. Good luck!
Cleaning Instructions
1. Unplug coffeemaker and allow to cool before cleaning.
2. Clean basket, stem and cover in hot soapy water with a dishcloth, rinse and dry. Coffee stains on underside of cover or stem may be removed by scouring with a damp cloth and a non-abrasive cleanser.
3. Clean inside of coffeemaker by filling with hot water until about one-third full. Add small amount of liquid dishwasher detergent and wash with a dishcloth or sponge. Then clean the heating unit well (where stem fits) with a scouring pad, to remove coffee residue. Twist pad inside heating unit well to clean thoroughly. IMPORTANT: If heating unit well is not kept clean, coffeemaker will not perform properly.
4. After cleaning inside of coffeemaker, drain and rinse inside. Clean faucet by letting clear water run through it into sink, while moving faucet handle up and down. Drain water from inside of coffeemaker and dry.
5. Clean outside of coffeemaker with a damp cloth and dry with a soft cloth. Do not use abrasive metal scouring pads or cleansers on outside of coffeemaker as scratching will occur.
DO NOT WASH COFFEEMAKER PARTS IN AN AUTOMATIC DISHWASHER.
Special Cleaning Instructions
To Remove Mineral Deposits: If coffeemaker is used daily, a special cleaning every 2 weeks OR every week if used for heating water, is necessary. Fill coffeemaker with 1 quart each of water and white distilled vinegar. (If a white mineral buildup has formed on inside of coffeemaker, use an additional 2 cups of vinegar.) Place stem and empty coffee basket in place, secure cover onto coffeemaker and plug in. Allow coffeemaker to complete perking cycle, then let stand for 10 to 15 minutes. Unplug and drain coffeemaker. Allow to cool and follow general cleaning instructions.
To Remove Discoloration: Inside of the coffeemaker can discolor when used for heating water, which is normal. To remove/lighten discoloration, fill coffeemaker with water to the level of discoloration (at least to the 12 cup level, but not past maximum cup level). Place stem and empty basket in place. For every 12 cups of water added to coffeemaker, add 2 teaspoons cream of tartar to basket. Secure cover onto coffeemaker, plug cord into coffemaker and then into outlet and allow coffeemaker to complete perk cycle. Let stand for 15 to 20 minutes or until discoloration is lightened. Unplug cord and drain coffeemaker. Allow to cool and follow general cleaning instructions.
Do not use baking soda to clean coffeemaker, as it will discolor inside metal.
After frequent use, coffee residue may collect inside faucet. To clean, unscrew top half of faucet. Move a small brush up and down through faucet. Insert brush through opening inside coffeemaker to clean faucet connection. Rinse and replace top half of faucet.
Jan 11, 2011 | West Bend (58036) 36-Cup Coffee Maker
How do you remove Jacuzzi Waterfall handles to get to the valve. There are no visible screws??
On the top of each handle you will need a very small flat head screwdriver or something similar to "pop" the top cap off. Under that cap there is a phillips head screw so you can remove the handle.
Jan 10, 2011 | Jacuzzi Water Rainbow Tub Faucet ...
My delta two handle bathroom faucet the cold water handle is hard to operate tried wd40 on it and it worked for a while but it got hard to operate again
They have a lithium faucet grease for stems at hardware stores Home depot or Lowes. It a gease to help free up for movement of handle if they don't have it try a Plumbing supply house they should sell to public.
May 04, 2010 | Delta Faucet DELTA/PEERLESS FAUCET CO....
How do i install an jacuzzi that has no faucet its a bathroom jacuzzi has no place for faucet it just has a hole for drain handle
either mount on wall or need to drill holes through jacuzzi 99 % of tubs dont come with faucets
Apr 24, 2010 | Jacuzzi Home
Water Leak from Jacuzzi Water Rainbow Fill Spout
ok you will need to replace the rubber seat and spring under each valve. You start by removing the plastic insert in the center of the valve. Remove the screw inside of handle and pull handle off. There will be a gasket under that and then you will see a bonnet. MAKE SURE THE MAIN WATER IS OFF before you proceed any further. Remove the bonnet by turning it counterclockwise. Once you have removed the bonnet then pull the stem out make sure you take care to notice exactly how it came out. Underneath the stem is a rubber seat and spring you can use a phillips screwdriver to insert in them and remove both. Replace them with new ones and re-install. If you are not very good at this sort of thing I recommend you call a repairman. Inserting of the stem back in its proper place is extremely important as it has to seat or it will not function properly. If you have any questions just ask.
Thx
Aug 02, 2009 | Jacuzzi WATER RAINBOW FILL SPOUT 6000-917
I have a black enamal cast iron jacuzzi kitchem sink with 4 holes for the faucet predrilled..the holes are 3" in dia. where can I find a faucet for this sink?
If you have a 3" hole I would definately say that is a special order faucet, But if 3" is a typo you can get what are called "cockhole covers" to cover the hole you're not using. What i usually do is, find a faucet that will use the 3 holes and install a soap dispenser, filtered water spigot, or a instant hot water spigot to fill the fourth hole.
If 3" is not a typo you might try to contact a granite countertop co. or call Jacuzzi and install a larger plate that will cover large holes and have new (smaller) holes drilled for a standard faucet
hope this helps
Jun 03, 2009 | Jacuzzi Kitchen Iron Black Finish...
Home Logo
47 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
Donni Steen
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
