Question about Boating
Champion boat wireing diagram
No tack or RPM gauge working, no heat prob working and gas gauge not working and lights on instrument panel not working... can u please send me link to wiring diagram. thanks
SOURCE: 1966 Ford Mustang Gas Guage not working
I had a similar problem. In my 1966 Mustang gas tank, the fuel pick-up was on a "float." My float developed a hole, filled with gasoline, and sank to the bottom of the tank, therefore, the gauge always read empty, but the car ran well. All the other gauges of course worked correctly. The repair was a relatively simple soldering job (after removing the float from the tank), but if that is indeed the problem, ensure all the gasoline is drained from the float before beginning the soldering job.
Posted on Dec 05, 2008
MrScary66613
  • 1990 Answers
SOURCE: instrument panel not working
Look in the Fuse Relay box under the Hood and Replace the Guage Relay. Should get it Fixed.
Posted on Jan 22, 2009
captainjeffq
  • 52 Answers
SOURCE: need Wiring Schematic/Diagram for 89 Astro GT16 boat
In all honesty, its probably impossible to get the original wiring diagram. Also, I would be willing to bet that there has been alot of re-wiring and changes made to the wiring and electrical system of the boat. If you describe exactly what your trying to do, install fix or re-wire I may be able to better assist
Posted on Apr 14, 2009
  • 48 Answers
SOURCE: 2000 Chrysler Voyager Instrument Cluster is dead
have you got a dimmer switch on your model to dim the dash lights. if you have it may be faulty. link the cables together if the lights work the switch is faulty. if you have not got a dimmer switch
your printed circuit on the back of the dash may be faulty or the plug in the back of the dash is not pushed all the way in. hope this helps
Posted on Apr 16, 2009
  • 187 Answers
SOURCE: I have a 1998 Champion 181 bass boat. The
Check the switch. It sounds like it has seen better days. Also check the wires on the back of the switch to see if they are shorting out. The problem is at the switch area. Good luck.
Posted on May 12, 2009
How do i get the wiring for gauges in 97 plymouth
with the ignition key off, press the "trip" button on the instrument panel, and while holding the button, turn on the ignition. the panel will do a self test of all lights and indicators. if the ones in question don't work, then it is a problem with the instrument panel itself. if they work, then you can look for shorted wires. I have technical info for most chrysler products so if it turns out that you need wiring diagrams or pinouts etc, I'm your man. good luck
Feb 27, 2013 | 1997 Plymouth Voyager
Instrument panel guages work one day the not the next, whats the problem?
It's tach, not tack, short for tachometer. Were these gauges installed by unionized people? It could have been the gauges' day off, as per their collective agreement.
Most instrument panel woes are caused by bad grounds. Most panels are below the front glass, and if this leaks, guess where the water goes? Dashboard problems are a bear to fix sometimes, and costly in terms of labor. Have someone steal the car.
Jun 21, 2012 | 2005 Chevrolet Monte Carlo
Instrument panel not working on a 1991 ls400
Try disconnected the battery for 10 minutes then reconnect that will reset computer, if that does not work then a short is likely in the instrument panel connections
Apr 05, 2010 | 1991 Lexus LS 400
2001 grand caravan no gas gauge heat gauge no odometer rpm lights
check for an instrument cluster fuse in the fuse panel if it's good you will have to pull the cluster out and change the lights behind the gauges
Oct 19, 2009 | 2001 Dodge Grand Caravan
I need a wiring diagram for dash spedo,tack,gas,heat,ect... all is not working grand am 1997
A good place to get wiring schematics for your vehicle is at the Auto Zone web site. It is free to use, the only thing you have to do is register.
Good luck.
regards,
Oct 05, 2009 | 1997 Pontiac Grand Am
Speedometer, gas gauge, odometer, rpm gauge not working
My gas guage, speed odometer and tempiture does not work
The speed odometre is reading 9999999 what should i do
Jul 29, 2009 | 1998 Nissan Frontier
Gas gauge no longer works
The light behind myRemove the cluster bezel from the instrument panel. See Cluster Bezel in this group for the procedures.
Remove the four screws that secure the instrument cluster to the instrument panel Instrument Cluster Remove/Install
Pull the instrument cluster rearward to disengage the two self-docking wire harness connectors
NOTE: The instrument cluster has two self-docking wire harness connectors that will be automatically aligned with, and connected to the instrument panel wire harness when the cluster is installed in the instrument panel.
Remove the instrument cluster from the vehicle.
Reverse the removal procedures to install. Tighten the mounting screws to 2.2 N·m (20 in. lbs.)
when I turn my headlights on. All the other gauges are lit, but not the gas gauge. How do I get in there to replace the bulb and fix this? Or is it a fuse problem? I have a 1998 jeep scout Thanks
May 14, 2008 | 2007 Jeep Scout
Boating Logo
74 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
