Question about Fein FMM250Q Select Multimaster Oscillating Tool Kit
Fein multimaster blue smoke broken
  • Fein Master
  • 1,815 Answers
Interference suppression capacitor or electric field .
Posted on Jan 13, 2016
3 Suggested Answers
  • 52 Answers
SOURCE: fein multimaster looses rpm after startup
Sounds like one of hte brushes is hanging up in the brush holder allowing macine to slow up. Check this 1st and make sure brushes are about 1/4" long.
Posted on Jan 11, 2009
  • 108 Answers
SOURCE: Fein multimaster sanding attachment broken
Pretty sure things like that are considered expendable. Pat yourself on the back for getting so much sanding done and buy a new one.
Posted on Oct 11, 2009
Fein
A defect armature that happends oft by this tool multimaster there was a little serie of this 250 watt budget machines that have hiddens defects in the armature if you look at that part then you see not a burned field or armature but the tool becomes very hot to hold in your hands. if you are by a service dealer he can confirm the problem that in most cases not was your fault because if its not burned , but when its burned then replace BOTH the electric field and the armature if you can become that cheap , most times this budget tool is not to expensive to get new. but in that case the 350Watt tool little difference but more to do with.
Apr 19, 2014 | Fein FMM250Q Select Multimaster...
FEIN FMM250 STOPPED WORKING
an broken connector wire , or powercable, an autostop activated carbonbrush? a broken field connector 1 of the 4 or an armature with a broken collector in the commutator circle. the electronic moduul to see in the last possibillity.
Sep 11, 2013 | Fein FMM250Q Select Multimaster...
Multimaster stopped working
First control the brushes for the length or a spontaneous broken cable . or elecric modul has MEASURE is neccesary of the 4 electric field contacts also.
Dec 22, 2011 | Fein Multimaster Rs - Msxe 636 - 2 Rs
Fein multimaster repair shops/centers????
Wow, I don't have a multimaster but I want one. I know they make two kinds. One that's 700.00 dollars and one that you can get at the hardware store. I'm beginning to think there might be a problem with the switches in this thing. Go to eReplacementParts.com and view the schematics to order a new switch.
Dec 19, 2011 | Fein FMM250Q Select Multimaster...
Where can I purchase a switch for the MSxe 636 II Fein Multimaster?
http://www.ereplacementparts.com is one of the online shops in you Country or a dealer for FEIN in your immediate environment.
Jul 29, 2010 | Fein Multimaster Rs - Msxe 636 - 2 Rs
Sep 26, 2009 | Fein Tools & Hardware - Others
Blades wear out quickly for the high price of the blades
Joa-liff@hotmail.com supply a range of adaptors to fit the fein Multimaster and Supercut machines that allow you to use both Bosch and Multimaster blades. hope this helps.
Mar 28, 2009 | Fein Supercut with Carpenter Kit - FSC -...
Fein Multimaster not oscillating
hi yes if you remove the gearbox from the armature housing then strip the cutter shaft from the gearbox by the circlip and bearing then the fork will fall out.
Have a look at this web www.fein.de/fein-multimaster/au/en/download/index.html
and follow link to the diagram of your machine may be helpfull.
Thanks. Sean.
Sep 22, 2008 | Tools & Hardware - Others
Fein FMM250Q Select Multimaster Oscillating Tool Kit Logo
62 people viewed this question
Top Fein Tools & Hardware - Others Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Fein Tool and Hardware - Other Expert? Answer questions, earn points and help others
