Question about Wharfedale Pro TITAN Sub-A12 Active Subwoofer
Wants to keep tripping out when turned on.
When I turn the power on it wants to trip out . If left for a minuet it will attempt to fire up but trips instantly. Can someone let me know if i have it set wrongly or if there is anything I can fix myself ?
  • 66 Answers
Maybe heat built up make sure it's not too close to anything clean the heat sinks from dust too. do you hear a fan blowing at all
Posted on Apr 20, 2014
Reset button on water heater keeps tripping
Need a new thermostat to keep the unit from tripping
Feb 13, 2013 | Bradford White CF-50-6 50 Gallon - 119,000...
Whirlpool fridge freiezer keeps tripping power
Does it run for a while than trip the power or does it trip it as soon as it is turned on?
Jan 30, 2013 | Refrigerators
Furnace keeps tripping the breaker changed breaker and wires all good up to the furnace still keeps tripping when i try to turn power on. nothing happened to the furnace and the wires were tested up to the...
Disconnect the black power wire where it is connected to the furnace with breaker off. Put a wire nut on it and then turn the breaker on. If it continues to trip, the problem is not the furnace and you will have to trace the power wire back to the breaker box to find problem. Next, disconnect the black wire from the breaker (with breaker off) and then snap breaker on. If it trips, bad breaker. If the furnace was disconnected and breaker did not trip, you have a short either on the P C Board or the transformer.
Mar 31, 2011 | Heating & Cooling
Hi can you help me my when i turn it on it reached temperature then triped. Reset the trip switch turned the oven on again and within couple of minuets it happened again. We turned it off and have not used...
Prob your cooling fan...it comes on to keep the appliance at a constant temp and if it doesnt it will trip out. Try turning on ur grill and you should hear the fan come on straight away, if not then you will need to replace it.
Hope that helps.
May 25, 2010 | Baumatic B180 Electric Single Oven
Spa keeps tripping breaker shows pr
two main reasons breaker trips is the pump motor jammed [not turning]or the heater shorted out --disconnect power open access panel disconnect the lines to the heater turn on power if breaker trips than motor /pump problem if doesnt trip than heater problem can order heater replacement online or pool spa store--if motor pump check pump for debris and motor for lube if u can turn shaft or impeller oil motor and work it into bearings if still not turning possible need to replace motor unit
Apr 26, 2010 | Heritage Pool & Spa
My machine flicks the mains switch as soon as i turn it on, both washing and drying. it first flicked the safety switch about halfway through a dry load...what could it be?
Hiya,
there is a few things that will do this to your electics 1st & formost if your trip switch is tripping off remember this is a safty device to prevent fire so ignoring the problem & switching the power back on to try again could run the risk of fire!!
This sounds like a heater issue since it's tripping the power on both the wash & dryer, in events of overheating the machine will trip your power for safty & to prevent the risk of fire however since you mention that it trips the power as soon as you switch it on you could have a blocked pump or burnt out motor too if your finding that the machine is tripping the power earlyer & earlyer each time you retry i would focas on the motor or the pump 1st
on rare ocasions you can spring a leak & if water gets on the electrics this will also trip the power but this is 1 of the least likely posabilatys..
remember always get a qualified electrician to work on your electrics to ensure the job is carried out correctly
Hope this helps
Apr 22, 2010 | Hotpoint Ultima WD72 Front Load...
How do you clear the service light on a S60 T5 2003. Please can you help.
Ensure all doors are closed.Turn ignition key to position 1.Press and hold reset button on a dashboard left hand side down/instrument panel/.Immediately turn ign.key to position 2.Keep reset button depresed until trip meter is reset to 0. NOTE:IF trip meter has already been reset.Hold reset button for 10-14 secondsuntil previous trip meter reading is shown.Press and hold reset button until trip meter is reset to 0 ;;;; Release a button within 4 secondsThere will be an audible signal When reset complete.
Nov 28, 2009 | Volvo S60 Cars & Trucks
How can i reset the service warning on a 2000 tdi golf?
  • Turn on ignition.
  • Hold down Right trip button and continue to do so whilst turning off ignition.
  • Still with Right trip button held down turn ignition back on.
  • Release Right trip button.
  • With ignition still on turn Left trip button to the Right and release.
  • Turn off ignition.
Nov 27, 2009 | 2001 Volkswagen Golf
Washing machine keeps tripping electric switch
Hiya,
when the power trips you will need to know at what point in the wash this happens if its when the machine is emptying then it would be a pump issue if the machine is emptying no problem then the issue is more likely to be the motor either of which would need to be replaced if you are having these problems.
on rare ocasions you can spring a leak & if water gets on the electrics this will also trip the power but this is 1 of the least likely posabilatys.. rest assured if the power is tripping off then your home electrics are working fine & to confirm all sockets run from 1 main fuse all lights run from a second main fuse then there is a few other bits that run on there on fuses too i.e. cooker, power shower etc.. remember always get a qualified electrician to work on your electrics to ensure the job is carried out correctly
Hope this helps
Jan 16, 2008 | Washing Machines
Wharfedale Pro TITAN Sub-A12 Active Subwoofer Logo
Top Wharfedale Pro Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Wharfedale Pro Audio Player and Recorder Expert? Answer questions, earn points and help others
