Question about Samsung 3.9 Cu. Ft. VRT Steam and Power Foam Front Load Washer
Vrt washer soap dispenser filling with water after cycle
Soap dispenser is filling with water during cycle and remains after cycle is finished.
SOURCE: Samsung Front Load VRT
I've had that same code, the machine completely stops and you have to start over with the load, the repair man samsung sent out still cannot fix my problem. he says there is a defect on these machines, good luck!
Posted on Apr 22, 2008
  • 574 Answers
SOURCE: not enough water in the drum during the washing cycle
If its a High efficiency washer it doesn't use much water. Usually the front load washers are HE washers
Posted on Aug 30, 2009
  • 1531 Answers
SOURCE: I own a Samsung WF338 Front loader washer. Water
you need to set this up for service
Posted on Sep 19, 2009
SOURCE: samsung vrt washer will begin cycle but get so far
You might have an object jammed in the pump housing. First thing you must do is to unplug the machine from the power outlet.You will then need to remove the back panel of the washer to access the pump. Disconnect the wiring from the pump and remove the two hoses by compressing the two clamps. ( Be ready for water to pour out of the hoses) Remove the three mounting bolts that hold the pump to the frame of the washer and remove the pump assembly. It is easier to work on the pump if you remove it from the mounting plate. Remove the three screws that hold the impeller housing to the pump motor. Seperate the two parts being careful not to damage the rubber o-ring that seals the unit. Inspect the impeller housing for any debris. (I found a nickle blocking the outlet port in mine). Remove anything you may find and reassemble in reverse order. The machine should reset itself and run as normal.
Posted on Jan 23, 2010
  • 6277 Answers
SOURCE: I have a Samsung VRT front load washer, it was
First is to empty the water out. This can be done by following my (complete) general guidance notes below for checking the drain motor lint tray/filter and the motor.
'nf' means NO FEED and what happened afterward indicates that the water feed control valve is malfunctioning, initially not opening for water to be fed but then sticking open.
So follow these notes, particularly those in capital letters, to find how to empty the washer, and to check the state of the filter which is needed on a regular basis anyway ;-0)
Next will be a call to a service engineer to sort out the suspect valve.Sorry ;-0(
I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
John C
Posted on Mar 01, 2011
Soap dispenser not working. The soap remains in the dispenser even after the cycle has finished.
Sounds as if the line is plugged. Old soap may have collected inside the line and dried up, preventing passage of new liquid to pass through. Call the Manufacturer and ask them how to clean out the line.
Jan 11, 2018 | Dishwashers
Why is my Samsung VRT Steam washer holding water in the detergent/softener dispenser?
the soap, bleach and fabric softner get dispensed by opening a water valve to the dispenser to flush out the items. They then flow to the bottom of the tub. Not all of the water comes out for various reasons, but the important information is that it is seldom critical to performance. If you want to pursue it, check dispenser (take it out) and clean it well. I assume the machine is level.
Oct 20, 2014 | Samsung 4.3 cu. ft. VRT Plus , Steam and...
Why does My Samsung VRT front loader leave the soap dispenser full of water at the end of the wash cycle. I have to empty it in order to add detergent for the next wash cycle.
there are 2 components to the soap dispenser, 1 using liquid soap has a little tub that you dispense soap into and 2nd you remove the tub when using powder soap. I assume that you are talking about the little tub is filled with water. How this works is by adding water to the tub the level rises and siphoning empties the little tub. If any water remains it is due to water being added after the little tub has already emptied. That is not a big issue and will happen. Just empty the water or add some water to start the syphon process.
Oct 11, 2014 | Samsung 3.5 cu. ft. High Efficiency VRT...
Why is water sitting in soap dispenser pullout drawer?
Water remaining in soap dispenser. In front loading washers made by LG (some Kenmore too), water may remain filled in the soap dispenser after the wash cycle. This may be caused by the siphon tube being contaminated by detergent residue. To clear it, remove the siphon cover from the tube, and clean them thoroughly, making sure that all residue is removed. Replace the cover and make sure it seats properly all the way down. This will ensure that the siphon starts and continues until the dispenser tray is emptied. A small amount of water, a half inch or less, remaining is normal. There is a video on YouTube that suggests buying a new detergent tray. Try cleaning it first. There are no parts that will break or wear out under normal use.
Jul 27, 2014 | LG WM2688HWM TROMM SteamWasher
Samsung vrt washer
it is probably the water valve for the softener has failed nachines have one valve for the cold rinse water and a second valve for the softener compartment in the soap drawer
Mar 10, 2014 | Washing Machines
Frequent leaks through soap drawer during rinse cycle
Possible that the dispenser drawer is out of alignment or is the suspect. You can remove and check the mountings
click on : Dispenser
Jan 24, 2013 | Tecnik TKL9260 Front Load Washer
I put liquid dish soap (not even dishwasher soap) in my rinse aid compartment of my dishwaser...will this hurt the washer? Do I need to get soap out and how?
yes it will foam up unlike you have never seen before
by disassambling the door and removing the risne agent dispenser and very throughly draining the soap it may get all of it out(rinse it with only cold water since hot water promotes sudsing while cold water kills sudsing) if even a few drops remain it will suds like crazy during the rinse cycle (when the agent is dispensed) to remove all suds from the machine fill a cup of white vinegar placed in the upper rack such as if you would drink from it (not upside down) and run the d/w of a normal cycle
a better but unfortunitly more costly solution would be to replace the rinse agent dispenser
Jul 20, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
GE Harmony top load washer: The soap tray when filled with liquid soap will not properly dispense the soap when the water is filling the machine and the soap tray remains full of water and soap at the end...
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Hope this helps...
Daniel
Feb 11, 2011 | Dishwashers
Where's the soap going?
Clean the dispenser water hose ,stuck by liquid dried soup./ the hose going to washer was open during washing time so all soap loaded was gone /
During water refill if nothing water pass to soap dispenser the soap will remain intact / but in washing time all soap will directly washout dispose to drain hose without to clean clothes.
Jan 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Samsung 3.9 Cu. Ft. VRT Steam and Power Foam Front Load Washer Logo
23 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
