Question about Kenmore Refrigerators
SERVICE MANUAL 7957953904
ICE DISPENCER SHUTE NOT CLOSING
4 Suggested Answers
peyton32034
  • 410 Answers
SOURCE: refrigerator
it has a bad main control board call maytag they will most likely repair it in warranty for you
Posted on Dec 11, 2007
abhishek33
  • 1239 Answers
SOURCE: REFRIGERATOR GSH25KGMCWW ICE DOOR WILL NOT CLOSE
hi Step 1: If the door won't shut tightly, tip the refrigerator slightly backward by propping up the front of the unit or unscrewing the front leveling legs two complete turns. Experiment with this adjustment until the door stays closed, but don't tip the unit very far out of front-to-back level.
Step 2: If leveling doesn't work, tighten the hinge screws. You may have to open the door (especially the freezer door) to turn these screws. On some units, you may have to remove a hinge cap or trim to reach the screws; pry off the cap or trim with a screwdriver. Sagging and looseness can be corrected by shimming the door hinges. Loosen the hinge and place a hinge-shaped cardboard shim between the hinge and the door. Then tighten the hinge again. Sagging may also be caused by a wrongly placed shim. In this case, you can correct the problem by removing the shim. Experiment with the shims; you may be able to eliminate the sagging.
Step 3: If the door is warped, tighten the screws that hold the inner door shell to the outer door shell. You may have to change or adjust the door gasket after making this adjustment.
Step 4: Check the catch. Newer units have a magnetic catch on the door. If the door doesn't latch properly, remove the magnetic strike from the inner door shell and shim it slightly with a piece of thin cardboard. You may have to adjust the gasket to conform with the new shim.
Posted on Oct 17, 2008
aquatom
  • 108 Answers
SOURCE: Rs21fcns ice shute door not closing
That's normally the solinoid that is defective when the chute won't close which is above that door and is a pain in the a_ _ to repair so I would call a tech to handle that problem.
Posted on Sep 26, 2011
Samsung ice dispencer shute is iced up what can be doneto free it
Sounds like door that opens to let Ice out is not sealing shut allowing air in to create condensation which then freezes
Sep 12, 2017 | Samsung Refrigerators
My ice dispenser keep shooting out ice after I moved glass away. The ice comes out in handfuls.
Sounds like there is still ice in the Shute, the unit is design to clear the shute so ice want freeze in the shute. Just touch and allow the shute to clear. The shute doesn't get as cold as the rest is why this happens. There is a micro switch near the handle that might be sticking, but seldom does.
Jan 03, 2015 | LG LFX25960 Bottom Freezer French Door...
Rubber flap in ice shute on PSC23NG does not close causing ice build up
you might what to contact the fridge manufacturer,,make sure to write the model # and serial # and there should be an 800' # to call, as all fridges are different
Feb 20, 2013 | Refrigerators
Kenmore fridge106.56546400, icemaker shute leaks
Most likely the chute is not closing all the way. Warm air enters and melts some ice and drips. You'll eventually get a frost buildup there if not already. Order a ice door kit. Get a flashlight and look at the chute door real good for a partial closure for verification.
Oct 12, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Icing up where ice cubes drop from door
door to ice shute not closing tight replace with door kit . for your model the newer model uses a better seal and a stronger spring . .. mm
Aug 11, 2010 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
Ice cube maker not working. I saw water frozen in the plastic shute leading to the ice trays.I used a hair dryer to melt the ice in the shute. The white gear IS turning. Still no filling of water. Door...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
Jan 02, 2010 | Whirlpool ED2FHEXN Side by Side...
GE monorgram frost in the ice shute
Sounds like the ice door in the dispenser isn't closing properly or all the way which lets warm air in condensates then freezes.
Oct 22, 2007 | GE Monogram ZISS480DRSS Stainless Steel
Frost buildup on ice/water dispenser
Is the trap door flap closing properly where the ice comes through the door? If open, warm air would be coming in frosting and maybe iceing things up
Aug 27, 2007 | GE GSS25QGPBB / GSS25QGPCC / GSS25QGPWW...
Refrigerators Logo
13 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
