Question about PowerStroke 1700 PSI Electric Pressure Washer PS171433D
Pressure washer shuts off overheating
Pressure washer stops working after 15 minutes or so of continuous use. Let it rest for 20 minutes or so and it works. (GFI is fine. Pressure washer is 3 years old, but only used several times per year.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 76 Answers
If you are using an extension cord this will happen. If using an extension cord make sure it is a 12ga.If you are not using an extension cord then it could be a bad motor or low voltage from the source.
Posted on Jun 11, 2014
My craftsman pressure washer shut off after 15-20 minutes of running.
Go to http://www.searspartsdirect.com/ Enter your model number to download manual. There is also an option to talk to an expert. http://www.searspartsdirect.com/
Sep 06, 2014 | Garden
Why is my powerstroke pressure washer overheating and stopping?
From what i understand ,you might have a bad armature
Armature partly dammed it can work for a while then will
stop when it overheat ,
Check if you have a high spark around armature , red spark
then check brushes , if brushes is good but the spring is damaged
that mean you have an overheating problem and you need to replace your armature , I hope this will help you solve your
problem ,, let me know if you need any further assistance.
May 09, 2014 | PowerStroke 1700 PSI Electric Pressure...
Pressure washer runs for 15 minutes then shut itself off. Overheating? I have to let it cool for 30 minutes before it can be used again, may be for 10 minutes before shutting down again. What can b
Not enough water VOLUME and pressure to supply the pump with a steady flow of water. Water is cavatating (adding air to the water) and the piston is heating up and jambing. Try using a larger size hose diameter and a shorter hose to supply the pump.
Apr 22, 2014 | Black & Decker 1700 PSI Electric Pressure...
Electric fuel pump stops working and after 15 or 20 min. starts working again ?
fuel pump is overheating. it takes the 15 to 20 min. to cool down. Low fuel in tank? in tank fuel pumps use the fuel to keep them cool. what is fuel pressure at the rail? if fuel pressure is too low the pump may be working too hard and overheating. need to test for a bad fuel pump or clogged fuel filter or possibly an obstruction in the fuel delivery system.
Sep 08, 2013 | 2002 Kia Sportage
Onan generator dies after 2-3 hours of running , wiil not restart rigt away wait 10 minutes starts no problem then runs for 15 minutes shuts down and keeps reapeating on 15 off 10
This sounds like overheating. These small generators don't have overheating protection, but if a low oil pressure or low oil level is present it may be the reason for stopping.
Check the oil level in the starting conditions and again when it stops. It may become under the "stop" level and after some time the precipitated oil has reached the "start" level. The same may be with oil viscosity and oil pressure.
Try to add some oil or change the oil with bigger viscosity.
Jul 07, 2010 | Watts Onan Portable Generator - 4000 ,...
Northstar PW shuts off hot if washer is moved. Honda engine
Being petrol driven, it may have a mercury kill switch which puts a ground on the ignition circuit stopping the engine if you move it. Perhaps for safety in case you overturn the unit somehow.
Apr 08, 2010 | Northstar Pressure Washer 3000 PSI
Craftsman pressure washer constantly fluctuates and then stops
sounds like fuel problem. Either water\trash at bottom of tank, or most likely, carb needs to be disassembled and bowl and jets sprayed out w\carb cleaner.my money is on the latter.
Jan 29, 2010 | Briggs & Stratton Pressure Washer...
What does error code 6P mean on an Amana washer model LW9203W2B
SH: Open thermistor. Unplug appliance and let rest for 15-30 minutes, then plug back in. If code continues, unplug appliance and call for service.
bP: Pressure switch error sensed. Washer will not operate when this error is displayed. Check for pinches or kinks in the water inlet hoses and straighten if necessary. Check the water inlet hoses filter screens and clean if needed. Verify that the water supply is turned on. Unplug washer and let rest for 15-30 minutes, then plug back in. If code continues, call for service.
rP: Water supply problem in spin cycle. Check for pinches or kinks in the water inlet hoses and straighten if necessary. Check the water inlet hoses filter screens and clean if needed. Verify that the water supply is turned on. Unplug washer and let rest for 15-30 minutes, then plug back in. If code continues, call for service.
LO: Lock Out mode. To activate, press START and STOP/OFF pads at the same time. To deactivate, repeat the procedure.
AU: Flashes when a factory preset cycle is put on hold. A normal function.
Clean Filter: Flashes when a cycle is selected as a reminder to clean the filter before starting a cycle for optimum drying results. Code clears when the door is closed and the START pad is pressed.
Dec 29, 2009 | Amana Washing Machines
John- power stopped -rest the GFCI STILL POWER WON'T COME ON-KARCHER K2.26M NEW -USED ABOUT 15 MINUTES WHEN THIS HAPPENED
these small power washers are tricky. Keep working with it. It may just be waiting for u to squeeze the trigger to activate. Make sure you have the water connected and turned on.
Apr 27, 2009 | Karcher K2.26 Electric Power Washer
Electric power washer shuts off
Sounds like a coil.Run till it shuts off, then check for spark.If there is no spark you will need a coil.
Mar 17, 2009 | Campbell Hausfeld PW1750 Electric Pressure...
PowerStroke 1700 PSI Electric Pressure Washer PS171433D Logo
220 people viewed this question
Top PowerStroke Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a PowerStroke Garden Expert? Answer questions, earn points and help others
