Question about Delta B4310LF-SS-SDISP Foundations Core-B Pullout Spray Kitchen Faucet
Water line One line is longer than the other, and the instructions don't indicate which is for hot. Which one is for hot water?
    Scholar:
  • 169 Answers
As a rule of thumb the water line to the right is the cold water line.
Posted on Apr 19, 2014
Is my Bosch water tube supposed to be hot?
I am guessing your question about the "water tube" you mean the water line coming into your refrigerator. If this line is hot it is likely that it is connected to a hot water line instead of a cold water line. This will cause longer freeze times for your ice maker and longer time to cool drinking water, if you have a water dispenser. This is consuming more energy raising your utility expense every month. I recommend you find a cold water line to connect to. If you are comfortable doing this you can purchase everything you need at either of the big box stores, if not then I suggest you call a good plumber.
Jan 21, 2013 | Bosch B20CS51SNI Stainless Steel Side by...
Don't understand the incomprehensible door and general installation instructions for the aqua star. Just uses pictures, anywhere available that uses WORDS?
  • 1 what you'll need
    Electric drill and hole cutting bit
    Screwdrivers
    Pliers
    Adjustable wrench
    Level
    Teflon pipe tape
    Drain pipe for dishwasher
    Dishwasher connection kit - available at your home store (should contain water supply line for dishwasher as well as necessary connectors and compression couplers).
    New dishwasher
  • 2Determine that you have access to the hot water supply line, the drainpipe and an electrical connection under the sink. Installing the dishwasher will require extending the hot water supply line to the dishwasher, connecting the dishwasher drain to the drainpipe under the sink, and plugging the dishwasher in. If your home was not plumbed in anticipation of a dishwasher, you will need to change some fittings under the sink to make these connections possible. (See below)
  • 3Read the instruction manual that comes with your new dishwasher. Installing a dishwasher is straightforward but you want to be sure you understand and are comfortable with the necessary steps.
  • 4
  • Thanks for using fixya.
  • Jul 19, 2011 | Bosch Dishwashers
    No Hot water coming out when single handle on hot water side.Cold water comes out fine. Water in the lines leading to the taps, but no hot water coming out. This is a bathroom faucet Moen single handle.
    Cartridge removal is a simple matter of exposing and pulling out the old cartridge. Before getting started, turn off both water valves underneath the sink and allow the water to run until the line is clear. Using a screwdriver, gently pry off the cap on the lever of the faucet handle to expose the cartridge. Remove the U-shaped retaining clip that holds the cartridge in place and pull the cartridge out. If dirt or residue makes removal difficult, use a Moen cartridge puller to assist you. A cartridge puller fits over the cartridge and gives you greater pulling power.
    Soak the dirty cartridge in vinegar for four hours and replace.
    If cleaning the cartridge does not work, call the Moen Helpline at 1-800-465-6636 or Customer Service at 1-800-465-6130 to order a free replacement. Locate the part number on the cover page of your instruction manual. If you no longer have the manual, look on the underside of the spout.
    Feb 08, 2011 | Moen Monticello Single-Handle Kitchen...
    I have an Asea 1200 Dish Washer and I have a problem with the hot water.i have found the hot water is not entering the machine even though the temp: is set to 70 max:what can be the problem and how can I...
    Make sure the washer water line is hooked to the hot water supply line in the house. If it takes a while to get hot water when you turn on the sink faucet, it will take longer to bring hot water to the washer due to the lower flow volume. If you bring hot water to the faucet first, then start the machine, it should solve this problem. The washer's heater should then raise the temperature to final requirements. Hope this helps!
    Jun 29, 2010 | Dishwashers
    Water not staying hot, i have a Bosh tankless water heater. i noticed that the less water i have comming in the longer the water heater indicator light stays on, resulting in hot water. As i release more...
    I installed a tankless heater in my home, I had the same problem, I discovered that the unit was not adequate for the water flow that I needed, I went up to a bigger unit and solved my problems, check to see what the flow rate is recommened for yours
    Oct 10, 2009 | Water Heaters
    Hot water problem in bathtube
    Make sure your hot and cold water lines arent crossed up. depending on how its plumbed in it could take longer to get to the tub then it does to the sink,
    Sep 13, 2009 | Plumbing
    Water line on intermittent flash after trying to clear the steam
    I was able to fix the problem after reading your post.
    I had lost my manual and found a copy of the instruction manual online. http://www.espressoitalia.com.au/viewStory/Coffee%20Machine%20Manuals
    I read the instructions for de-scaling (page 15) and followed it EXACTLY the way it instructed me to.
    The entire process took roughly 2.5-3 hours. I set an alarm to remind me to re-dispense the solution again (for 15 seconds) every 10 minutes.
    I'm not sure if you skipped a few steps(I did the first time I went through it). If anything, the trick might be to hold the hot water button for 6 seconds to disable the de-scaling alarm.
    Your de-scaling alarm probably hasn't been de-activated. ( To make sure I held the hot water button for about 15 seconds)
    Jan 28, 2009 | Saeco Odea Giro Plus Coffee Maker
    Hot water not really hot
    I have never heard of this before, and have always piped dishwashers off the hot water line. Not to say it could not be done the other way, I would refer to the instructions that came with the dishwasher, and if they say to connect to the hot water line, to have the technician come back and fix it. If it says to connect to cold water line, then manufacturers know best.....Hope this helps
    Dec 29, 2008 | GE WPRB9220D Top Load Washer
    Re dishwasher unit / sgs46m78au. water pipe/hose/ connections
    The water connection is the smaller of the two and generally near the front of the machine, usually a threaded fitting on a electric solenoid will need a pipe to compression 90 fitting if its not already installed, it needs to be hooked to the hot water and that can be found on the left side going up to the sink faucet to be sure run some hot water and the side that gets warm is the correct one, you will need to turn off the water and install a T to connect the dishwasher if an unused shut off is not already there for the dishwasher. The drain line takes a hose and clamp and will hook into your drain iether through a dishwaser t or the disposal if you have one has a connection for it.
    Dec 17, 2008 | Bosch SHU3305 Dishwasher
    F 13 problem indicated on miele g2420 optima dishwasher
    Its on the end of the water intake line - ussually under the sink - connected to the hot water line.
    Dec 06, 2008 | Miele 24 in. Incognito G843SCVi Built-In...
    Delta B4310LF-SS-SDISP Foundations Core-B Pullout Spray Kitchen Faucet Logo
    94 people viewed this question
    Top Delta Plumbing Experts
    Donni Steen
    Ed Mac
    bwbconstruct
    Level 1 Expert
    Are you a Delta Plumbing Expert? Answer questions, earn points and help others
