Question about Canon ImageRUNNER 1670F Copier
COPIER CANON PC920 ERROR 03
I CLEAN DE MACHINE AND DESCONECTED THE FUSER AND FORGOT PLUING, AND TURN ON THE MACHINE
THANK ANGEL
    Guru:
  • 389 Answers
V\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Обычная таблица"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} E000
1 To Remove the lid variable resistor (with lion for lid "stoves"
2 Include the power supply
3 Press the breaker SW301 circuital charge of the controller of the direct current
4 Switch off the power supply, but then once again its switch ON the power..
Posted on Sep 21, 2009
Why my canon ir 2318 display error code 03
Hi Daban this is Alex Walker expert to help you for Canon Printer Call +1(404)981-1535 I will be glad to assist you
Dec 29, 2015 | Canon Office Equipment & Supplies
My canon pc940 suddenly prints copies with a dark stripe running down the middle of each page.
On your computer open the menu for your printer. Somewhere there you will find an icon that initiates a cleaning procedure. It usually takes just a few minutes and the printer wil go through the cleaning procedure on its own.
Jan 04, 2013 | Canon PC980 PC920 PC940 PC950 PC960...
Machine error E04-03
E4-03 is an error in the fuser (HOT ROLLERS) section of the machine. Could be a bad fuser motor, loose connector, an open fuse or dirty thermistor. Does the machine have a bad paper jam right now? That will cause the motor not to turn. Hope this helps
Jul 11, 2011 | Panasonic DP-C322 Copier
Canon Copiadora mi ir400 memanda E005 El error de no se quer signifique Como desbloquearla o de soja Por favor ayudenme nuevo en ESTO
The error code means that the cleaning web for the fuser unit needs to be replaced and you must rest the web counter as well
Sep 15, 2010 | Canon imageRUNNER 400S Copier
The hot roller where the paper comes out needs to
http://www.precisionroller.com/search.php?q=pc920+fuser
About $240 for the fusing unit.
Installation is a whole other problem. It is not the easiest swap to do. Seeing the cost of the new fusing unit you may want to consider a new machine. Not much more for a new copier.
Oct 26, 2009 | Canon PC-920 Black and White Copier
I just received an E003 error when running my Image Class 860 copier. Any suggestions? Thank you so much!!!
Please clean the fuser unit thermistors and thermofuses and verify the continuity the fuser heater lamp.
Sep 28, 2009 | Canon ImageClass D880 Copier
My canon copier pc920 is displaying a EO message in the LCD screen. What does this mean?
E0 for PC 920 - Fuser problem?or temperature too low. Heat lamp, thermal fuse or thermoswitch, thermistor, triac etc ((( its work for a sevice...
Jul 26, 2009 | Canon PC-920 Black and White Copier
Canon imagerunner 210s
EOOO is a thermistor-fuser error. Your machine will need a fuser, but on occasion a power surge can trip the error, E000 needs a code to reset it, I dont know if same but this is the code on a IR 330s
Press the userbutton then press "2" & "8" at the same time and then press userbutton again.
You will now enter servicemode
press " Copier "
press "function"
press "Clear"
press "Error"
leave servicemode by pressing resetbutton twice.
restart machine.
Mind you it is only a reset, if fault still exist it will go eooo again confirming that it needs a new fuser unit.
Dec 30, 2007 | Canon imageRUNNER 210S Copier
Canon ImageRUNNER 1670F Copier Logo
95 people viewed this question
old marine
old marine
