Question about Utilitech Pro 180-Degree 2-Head LED Motion-Activated Flood Light MST18
Where can you buy replacement bulbs for Utilitech Pro 180-Degree
    Champion:
  • 203 Answers
B and Q
Posted on Apr 19, 2014
Looking for a new motor for a utilitech pro 0313836 submersible pump
Most submersible pump motors are interchangeable.
A 230 V motor will run cheaper. Be sure to get the correct HP motor.
Oct 05, 2014 | Utilitech 1-1/2-HP 18-GPM 3-Wire 230-Volt...
Last night I installed the Utilitech Pro 180 degree Motion activated light. I have the motion sensor sensitivity set as high as it will go but it still doesn't pick up activity beyond 10 feet in front of...
The 48-hour period allows the light to "learn" the operating parameters. The 10-foot range limitation may be due to other environmental factors (such as adjacent bright lights) that affect sensitivity.
Jun 09, 2014 | Home Security
Why won't my Utilitech dusk to dawn light work
If you know the bulb is good, try changing the photocell. Why is it half of the problems on this site are Utilitech? I think I see a pattern.
May 28, 2014 | Utilitech 0.33-HP Thermoplastic...
I HAVE A UTILITECH PRO 180 #0205881 AND IT BLINKS WHEN ITS ON
Usually when a motion sensor light blinks LED or otherwise it means that the motion sensor is shot. The light itself is most likely good and for whatever reason you got a bad sensor upon purchase.
Feb 21, 2014 | Utilitech Pro 180-Degree 2-Head LED...
Utilitech pro submersible pump has good electrical connection but pump won't start
There is a starting capacitor on the motor pump, check this out if faulty then replace it.
Dec 28, 2013 | Utilitech Plumbing
My Utilitech Pro will come on, after a few seconds it will blink twice and then will not come on again for several days.
Sounds like the sensor has failed. The controls are supposed to be on the underside, and kept dry.
Nov 24, 2013 | Utilitech Pro 180-Degree 2-Head LED...
My utilitech pro led flood light is now constantly flashing. I turned off the breaker for 10 minutes and it still flashes. There is no reset button only a test switch. Any ideas?
I know this is an old post but in case it helps someone else:
I had the same problem. On the sensor head (the bottom part of the light), you will see a plastic dome that can swivel about 360 degrees. Just behind that is a tiny dot maybe 1/8 inch in diameter. If you cover that dot with several layers of white tape the flashing stops and the light stays on. This defeats the dawn to dusk functionality because the light will always think its nightime, but I can always turn it off using the switch in the morning. The light is extremely bright when it is on, but many people struggle with the sensors never working right. If I hadnt already siliconed the light to my siding block, I would try to bypass the sensor altogether. For now the tape at least stops the flashing and I have light.
Oct 05, 2013 | Utilitech Pro 180-Degree 2-Head LED...
Where is it located and are there two different types (180 dergree and 195 degree)
Normally the thermostat is located in a housing that the upper radiator hose connects to. Yes, there is 180 and 195 degree thermostat. One will make the motor not run quite as hot, 180 degree, for summer, the other to allow the motor to get a little warmer, for winter.
Jun 10, 2010 | Cars & Trucks
Utilitech Pro 180-Degree 2-Head LED Motion-Activated Flood Light MST18 Logo
433 people viewed this question
Top Utilitech Pro Home Security Experts
Lawrence Oravetz
Are you an Utilitech Pro Home Security Expert? Answer questions, earn points and help others
