Question about HP Compaq WF1907 Monitor
My monitor is making a humming noise from the speakers , because i use other speakers (not the ones on the monitor) this is a problem what could cause this
    Sergeant:
  • 220 Answers
It is probably a problem with the audio jack, try using other speakers or connect another audio source to your monitor. If the problem persists, you better contact your vendor for a faulty product
Posted on Jun 20, 2009
Humming noise
Possibly a bad cable or bad ground or bad outlet?. Easy solution, try a different outlet and see if the hum still exists. Also, make sure your speaker cables are NOT run parallel along with, or close to any power cables, Speaker wires can and will pick up AC "Humm" noise.
Apr 23, 2014 | Edifier Audio Players & Recorders
Monitiors are not turning on
Have you tried to use these on other devices, like a DVD Player, etc.? If you get a HUMMING noise with other devices then the internal amplifier is defective and you are not getting sound production to the speakers. If you have separate power AMP and the speakers hum when connected, they may have been damaged. If you have a speaker mismatch; they tend to buzz, thus too many conditions could represent the humming. Check that the Positive and Negative polarization of the speaker wires are correct.
Jan 14, 2014 | Numark NPM5 NPM-5 - Active Studio Monitors
I have a pair of jbl 512m speakers one is louder than the other one but it works
Make sure your audio interconnecting cables are XLR or TRS balanced lines. Use of TS cables similar to guitar cables with only two conductors (only the tip and the sleeve) reduce the gain 6 DB and contribute to hum and noise.
Sep 03, 2011 | JBL New Jbl Prx512m 12 Powered Monitor...
I have a pair of JM lab Electra 905 speakers, running through a DNM amp and power amps. When powered up, the left speaker makes a very loud humming noise. This has happened recently. I haven't changed...
Hello
Switch on your amp, keep its volue down to extreme low, and listen if there is still hum through the left channel or not. If still there is hum, the left side power amplifier section inside the amp;ifier is faulty. If htere is no hum at this state, hum enters thorugh the audio input terminal, and the input wires must be checked for open sheild connection. OK.
Apr 10, 2011 | Jmlab Electra 905 Speaker
Speakers are making a humming noise
If the noise is accross all channels then it's most likely the large electroltic capacitors in the power supply. These filter out the mains hum 50/60hz. There might be two or more they will be the biggest! Even if you can determine only one has gone, it's best to replace them all.
Jul 12, 2010 | Kenwood VR-407 Receiver
Speaker makes a rather loud humming noise.
You can go buy a audioquest SUB-X subwoofer cable with a additional ground wire on it an connect the ground cable to the ground slot of the receiver an the other end to a screw on the sub or into one of the high output terminals on the woofer if it has them an this will take that humming sound right away but the cable is around $90
Mar 28, 2010 | Velodyne HGS-10 Subwoofer
I stopped having sound coming from the speakers. I checked and we are not on mute, and the volume is turned up high.
Make sure all your connections are tight and you have power to your speakers...Then go Start>Control Panel>Sound and Hardware>Sound, after you are in here make sure that your speakers are selected as default device.
Hope this helps, pls rate
Mar 19, 2010 | Proview Computers & Internet
Monitor making humming noise
First try moving speakers away from monitor a bit. Some speakers magnets actually reduce the life span off monitor. I hope I am wrong but usually a high pitch whine is the High voltage Transformer. Costs more than the monitor. All you can do is continue use till it goes. Speakers usually deteriorate the tube itself. HVT are just one of those parts that go due to use. Hope it gives you more enjoyment before it goes. Good luck and try to have a good day.
Jan 31, 2009 | KDS Visual Sensations 190i 19" CRT Monitor
Iball speakers making irritating noise
please try better speakers better ohms orhigher wattage. improper speakers not for pc's or laptop will cause the hum..
Nov 29, 2008 | Audio Players & Recorders
Syncmaster710N
There are no speakers attached but if for any reason humming is comming its the transformer inside the casing. Very comming in transformers that after some time they start humming noise.Its not for all of them but its some coiling fault but it doesn't effect anything.
Jul 24, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
HP Compaq WF1907 Monitor Logo
187 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
