Question about Brakes for Oldsmobile Bravada
1997 checy tahoe brake caliper sticking
Replaced brake hose and caliper
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 189 Answers
While it is on take a flat screw driver and on each side of it try to push it back a little at a time if this dont work crack the bleeder and try again
Posted on Sep 06, 2014
2 Suggested Answers
  • 611 Answers
SOURCE: replaced calipers ball joints pads
need ceck all the lines n bleeder valve 4 leaks
Posted on Jul 17, 2011
Hello, i replaced the brake calipers on my 2002 chevy Tahoe, now i cant get any fluid to the calipers. I even tried the suction tool still nothing.
take the line loose at the hose if you get fluid change both hoses they might have been the reason the calipers needed to be changed also check to make sure you didnt twist the hoses because this can also pinch off fluid hope this helps good luck
Aug 18, 2010 | 2003 Chevrolet Tahoe
1997 Tahoe makes clunk noise whilw accelerating.
check oil level in trasfer case front and rear dif . front calipers could be sticking reardrum brakes could be frozzen dose the truck pull to one side if brakes are aplidded hard with no hands on stering wheel
Feb 01, 2010 | 1997 Chevrolet Tahoe
1997 JEEP GRAND CHEROKEE FRONT BRAKE GETS VERY HOT SMOKES. CHANGED BRAKES AND ROTORS BOTH SIDES NOW OTHER SIDE DID IT. wHAT MAY BE CAUSING THIS/
Were the calipers check for not sticking, as well as lubed well when re-installed? If it's original flex hoses at calipers, that's also a consideration.
Jan 01, 2010 | 1997 Jeep Grand Cherokee
All new brake shoes on 97 jeep front callibers still sticking
The problem lays with the Caliper itself and/or the brake hose connected to the Caliper.
However if you replaced the pads, did you also replace the Rotors or have them Turned? The old pads wear the rotor. New pads on old rotors that have not been replaced or turned may end with rubbing or stuck brakes.
A simple way to test whether it's one and/or the other:
1. Remove the Caliper from the rotor, remove the pads. Keep for now the caliper attached to the brake hose.
2. Very slowly push on the brake, exposing more of the piston out of the bore. Not all the way. Usually until the rubber dust seal/boot is fully extended.
3. Check the seal/boot for cracks and tears, and if clean or not. Bad seals may prevent the piston from re-seating.
4. Using a c-clamp and pushing straight in: Try repushing the Caliper Piston back into the Caliper Bore (the cup back into the hole). It should go back in realitively easy.
5. If it doesn't go back in easy: Again slowly pump the brake and re-push the pistons back out to full extended seal/boot (but not the piston out of the bore).
6. Detached the brake hose from the caliper.
7. Again using a c-clamp and pushing straight in: Try again to repush the caliper piston back into the bore without the hose attached. If it goes back-in relatively easy - the caliper is okay...it is the brake hose.
8. If the caliper piston does not go back in easily - Replace the caliper.
9. When Installing the new (reman) caliper, remember to bleed the brakes.
TRY EITHER OR #10 OR #11 BELOW:
After the new Caliper is reattached to hose and has been bled:
10. Again push on the brake petal to fully extend the caliper piston fully (rubber seal/boot fully extended) Again do not push the piston out of the bore! Try pushing the piston back into the bore. If it does not re-seat relatively easy: Replace the brake hose.
11. Another method: After replacing the new caliper back on the rotor: Assumng the entire front end (2WD front wheel drive) or entire vehicle (2WD rear wheel drive) or (4WD all the time) is jacked up off the ground
a. Put the lug nuts back on the rotor.
b. Have helper Start the vehicle and place in Drive. Don't step on gas!
c. Have then let off the brake and then engage the brake.
d. When they let off the brake watch to see if the Rotor is turning or not, if rubbing or not. Or if still sticking.
e. With a new caliper, turned or new rotors, and still a problem? It is the brake hose!
12. Replace the brake hose and try again.
Another method but more expensive:
OR Replace the calipers, brake hoses; bleed and test!
If this helped or not; or if you need additional help or have addtional questions let me know on fixya.com!
Nov 28, 2009 | 1997 Jeep Grand Cherokee
1999 tahoe.right front brake caliper slow to release.
Besides changing the caliper did you by chance chg. the break hose going to it, there a 2-way hose fluid goes to caliper and returns thru same hose, and they have been known to cause what you have just discribed.
Aug 09, 2009 | 1999 Chevrolet Tahoe
2001 silverado 1500, just put on new pads rotors and 1 new caliper, the brakes are spungy, the wheel with the new caliper is sticking and the front passanger brake too, i cant figure out why.
Replace both front brake hoses.....they collapse on the inside and will not allow fluid to retract...caliper was probobly fine.....this happens a lot....good luck...Lee
Jul 22, 2009 | 2001 Chevrolet Silverado 1500
Caliper is sticking
the ABS valve in the ABS hydraulic control unit is leaking pressure and causing brake to apply is the most likely thing wrong..
May 16, 2009 | 1997 Pontiac Grand Am
Brakes for Oldsmobile Bravada Logo
48 people viewed this question
Top Oldsmobile Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
George Agios
George Agios
Robert Swatek
Robert Swatek
Are you an Oldsmobile Vehicle Part and Accessory Expert? Answer questions, earn points and help others
