Question about Samsung Computers & Internet
Dell 650 Occasionally my Dell 650 throws up a message that I am connected to an incorrect connector which is not the case. I used to have a Samsung monitor and changed this to an acer, I think that this problem relates to the old Samsung software. I have uninstalled this but the problem has remerged
  • Samsung Master
  • 3,320 Answers
Hmmm Problem head says Samsung Monitor. You mention your Dell 650. Then you tell us about some Acer monitor.
The error is an incorrect connector.
WHAT CONNECTOR?
Did you check the connector? Are you using an adapter? dvi-svga-hdmi
Posted on Apr 23, 2014
SOURCE: Dell 1703FPs TFT Monitor
Had the same problem. You need only the front plastic frame decrease. Between the front side and the bottom Ramen is a small slit, then you can start and then carefully with the help of a Keils of the front frame. Beware! The rear frame is not resolved, this is at the corners with 4 screws on the side framework screw.
Posted on Dec 10, 2007
SOURCE: Dell 19" Monitor - Dead
go to lcdrepair.us you can buy the board you need there , you can talk to tim he can help you out or email him
Posted on Mar 19, 2008
  • 46 Answers
SOURCE: how to open dell wh 320 monitor for repairs
check out this link for videos on how to open dell LCD monitors.
http://www.lcdrepair.us/Installation.html
Posted on Jun 21, 2008
  • 3940 Answers
SOURCE: Dell monitor attached to Inspiron 1520 runs landscape (sideways)
try CNTL+ALT+Up arrow/Down Arrow
Posted on Apr 14, 2009
frankzjm
  • 191 Answers
SOURCE: How can I use my apple lcd monitor (model m7649) to my dell
here you need to do:
1) you need find a video card with a DVI port and analog output ports, upgrate this card in your destop if you can not find a DVI port at your destop.
2). then you need buy a ADC to DVI adapter because your monitor ADC port is a digital port. you may reference here:
http://store.apple.com/us/product/M8661LL/B
and you can buy the parts at:
http://shop.ebay.ca/items/?_nkw=dvi+to+adc+adapter&_sacat=0&_trksid=m270&_odkw=adc+to+dvi+adapter&_osacat=0
hope help you fix it. please take a rating let me know huw much helped you thanks!
Posted on May 19, 2009
How to connect 520 to a tv
In the Quick Reference Guide ()
ftp://ftp.dell.com/Manuals/all-products/esuprt_laptop/esuprt_latitude_laptop/latitude-d520_setup%20guide_en-us.pdf, at page 12, you can see 2 connectors that can be used to connect your laptop to the TV (4=S-Video TV-out connector and 6=video connector).
Depending of your TV (type and model), you can use one or both of theese connectors. For an analog TV you can use only the S-Video TV-out connector, using a proper cable (S-Video to S-Video or S-Video to SCART). For a digital TV (LCD, LED) you can use also the video connector (D-Sub 15 pin), if your TV is equiped with a similar video connector. If not, you must use a converter, but is more expensive.
In all cases you must use a second cable for the audio signal (see the audio connectors, at page 11).
Aug 09, 2014 | Dell Latitude D520 Notebook
Connecting my Dell Vostro 1400 to a Samsung S24B350H monitor
If the monitor has several video connections then you need to go into the monitor's settings and select the correct video input.
Mar 21, 2013 | Dell Vostro 1400 Notebook
Will a samsung sc 140 in a dell inspiron 531
Hi Grannyking - Sorry, the answer is no. Your PC only has connectors for drives using the current standard SATA connectors. The Samsung SC140 uses the old IDE standard for connections so there is nowhere to connect the Samsung,
Regards, Mikeyaf
Mar 06, 2011 | Samsung SC 140 (SC-140) Internal 40x...
Does not recognize my connection for active sync
Dell made an entry into the market of Personal Digital Assistants (PDA) with Axim X5. The Dell Axim comprises of families of X5, X3, X30, X50 and X51. The Dell Axim PDA can be connected to the computer either by using a cradle or a sync cable. The sync cable connects the device to the computer directly. Here are the steps for connecting a Dell Axim to a computer using a sync cable.
  1. p 1 The Microsoft ActiveSync software must be installed in order to connect the PDA to the computer. This software is found in the Dell Axim Pocket PCmag-glass_10x10.gif Companion CD.
  2. Step 2 The Axim X51 PDA has a 36-pin connector, while the X3 has a 22-pin docking connector.
  3. Step 3 Connect the USB connector found at the end of the sync cable to the computer.
  4. Step 4 Check the PDA. If the PDA is not properly cabled to the computer, you will get the following message: “Connect your device to a computer using a sync cable or cradle before running the system update. Ensure that ActiveSync is installed on the computer and that the ActiveSync connection is successful.”
  5. Step 5 Ensure that the Dell logo faces upward.
  6. Step 6 Use the sync cable to set up a partnership, which can be done multiple times when you sign in as a guest.
Nov 14, 2009 | Dell Axim X3 Pocket PC
I want to connect the audio output of my Dell
The connector on the Dell side is a 1/8" (or 3.5mm) stereo connector, and is a standard mini headphone connector as used on iPods and other devices.
The connector on the Sony side is either another 3.5mm connector, in which case you want something like this cable, or it's dual RCA jacks, in which case you want something like this cable.
Neither of those are great prices -- you can easily find cheaper versions at any Wal-Mart or Radio Shack store, but they're examples of what you'll need.
Oct 20, 2009 | Dell A215 Computer Speakers
Conections
Hi peju90,
If you've gutted out the old dell computer, then your only talking about a empty case. Put all the right chips and cpu's that the Asus board requires, and you should have no problem with the CD rom or any other hardware. Except if you try and put the hard disk from the dell, it will not have the same configurations, and probably be a bit crazy. But, reformat the drive to it's new board, and your home free.
The power connections will be the same as it was on the old Presario, if you have the old power supply then nothing changes on that. You'll need to hook up the front connectors for USB and Hard drive lights, reset etc, but that would be the ugliest senario. Meaning the csse fit a special connector that the board doesn't carry. In that case you to option, either cut the special connectors and replace them with the ones from the old Presario case, or don't connect them, all but the power, you're gonna need that hooked up, one way or the other.
But, that's as tough as it gets my friend. A case is a case is a case.
Good Luck
Mark
Oct 17, 2009 | Computers & Internet
Power edge 1800 bought october 2006. It does have a DELL 650 Watt non-redundant power supply, type nr. PS-5651-1. Can I replace it with a standard ATX power supply, or is the connector not standard wired...
Dell uses proprietary psu's. You will need to contact them for replacement psu or find a supplier that makes psu's that can be used as a Dell replacement. Hope this helps.
Jul 07, 2009 | Dell PowerEdge 1800 Server
Printer Always Indicates Ink is Low or Cartridge is Incorrect
To get rid of the low ink warnings google the specific error message with 'ink refill' and look for 'engineers reset' or similar ..
NB. Dell printers (re-badged Lexmarks) are notorious for ink usage and high costs .. so my best recommendation would be to throw it away and purchase something else ..
Nov 30, 2008 | Dell 922 All-In-One InkJet Printer
Printer error message
To eliminate a software problem, disconnect printer from pc and completely uninstall the printer driver and restart pc. Insert our printer driver cd and install the drivers, but do not connect printer until advised. When advised connect printer and ensure windows recognises it in the little pop up window in tool bar and says 'Your hardware is installed and ready to use' If the same message appears then the printer is faulty.
Dec 30, 2006 | Dell 922 All-In-One InkJet Printer
Computers & Internet Logo
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
