Question about Mongoose Cycling
Mongoose blackcomb manual - Mongoose Cycling
4 Suggested Answers
HondaCRX
  • 252 Answers
SOURCE: Greeting I just purchased a Mongoose Blackcomb All
Unhinge the Vbrake at the front, by ushing the arms together and sliding the silver metal pipe out of it's holder. The brkes should release their tension. Undo the front bolt going through the center of the wheel with two spanners.
Don't use one spanner as it turns the opposite side and you'll be there all day.
Lift the bike up and pull the front wheel out away from the forks.
Vote for me if you think this helps you. Thanks :)
Posted on Jun 24, 2010
dunnbiker
  • 8546 Answers
SOURCE: What is the diameter on the mongoose blackcomb
It would be stamped right on the clamp area. Loosen the stem's front face and look. That would only tell you the size of the 'bulge'. Otherwise, measure the dimension you need with a caliper.
Click on the pic of the bars.
http://www.bikeman.com/content/view/1637/115/
Posted on May 27, 2011
SOURCE: I have a Mongoose Blackcomb.
First if can you release the actuator arm by pushing on it. If you can than theres 2 possable things you can do. First take the arm off there is a spring inside of it. Pay attion to how it is set up you need to put it back together the same way. after you have that apart the spring might need to be pulled apart from use. but not to much. The Spring may have been compressed so much that it needs to be streched out. the second make sure that your break cables are moving smothly through the casings if not eather replac the cassings or take some sort of grease and lube the cable up one or both of these should work
Posted on Dec 14, 2013
Need an assemble manual and or guide for mongoose mischief 2004 Serial num HBING
http://knowyourbike.com/mongoose/mischief/2004
http://www.bikepedia.com/QuickBike/BikeSpecs.aspx?year=2004&brand=Mongoose&model=Mischief
And finally the manual
http://www.mongoose.com/usa/manuals-instructions/
Jan 17, 2016 | Mongoose Cycling
Trying to assemble mongoose back tire and chain
I am sorry I could not find a manual for your Mongoose.
I will suggest you go to the following website
http://www.youtube.com/watch?v=2j1gSwhsVN8
You can find numerous videos for your bike repair.
in Youtube
Bud
Sep 24, 2012 | Mongoose 26" Mens XR-75 Mountain Bike
I need to know what kind of crankshaft does a mongoose men's melee have?
Ya mean BOTTOM BRACKET? Probably something at the low end of Shimano. They don't publish the minutae for their department store bikes.
You could ask Mongoose directly or take it your Local Bike Shop and have them determine the answer (which is recommended in Mongoose's manual if you want service on a 3-piece crankset anyway).
http://www.mongoose.com/usa/usaeng/mtn/man_inst
http://www.mongoose.com/mtn/ask-mongoose
Sep 21, 2011 | Cycling
What is the diameter on the mongoose blackcomb handlebars?
May 27, 2011 | Mongoose Sector 26 Men's Full Suspension...
I have a Mongoose Blackcomb. When I apply the front disc brake the cable and actuator arm do not retract back to open position. Does the entire front brake need replacing are can this be repaired?
Impossible to tell you with out seeing the brake.
However, the brake can be repaired. I would suggest taking into your local bike shop so they can assess what is causing the sticking brake, it could be a very simple fix, such as adjusting the spring tension, to a more complicated fix that involves replacing broken parts. Some brake systems do not have available replacement parts and in those cases you would have to replace, but that is less common.
If you can, take off your front wheel and prop the bike up so you can see the brake working while you squeeze the lever, see if the pads move in and out. that is the first step to diagnosis. If they don't return, then look for a round adjustment knob on the side of the brake and see if that moves the pads in or out, if that knob does nothing that is most likely your problem.
Dec 30, 2010 | Mongoose Cycling
Greeting I just purchased a Mongoose Blackcomb All Terrain Bike and I'm having problems installing the front wheel.
Jun 24, 2010 | Cycling
Manual for Schwinn Mongoose z350 electric scooter
My Mongoose z350 electric scooter goes from full charge to empty in about 20 seconds. I can turn it off and back on and it shows a full charge every time. What is going on with it?
Mar 24, 2010 | Mongoose Currie Schwinn Gt Izip Scooters
2001 klf300 rear brake drum is ineffective. I
that looks like a mongoose black comb. I dont know y the brakes would not be working i have a blackcomb my self and i can ride it up or down a creek and still have breaks im not really sure what would cause the brakes to not work google it. id suggest or call the manufacture
Oct 20, 2009 | kawasaki Full Suspension Mountain Bike Men
Cycling Logo
Top Mongoose Cycling Experts
Michial Gueffroy
Jim Goldsmith
Jim Goldsmith
Rommel Balcita
Are you a Mongoose Cycling Expert? Answer questions, earn points and help others
