Question about Rheem Paloma PTG-74PVN / RTG-74PVN Natural Gas Indoor
Rheem paloma c8 13 error - Rheem Paloma PTG-74PVN / RTG-74PVN Natural Gas Indoor
5 Suggested Answers
mrhotandcold
  • 248 Answers
SOURCE: Gas comes on for only about 30 sec, then shuts off
faulty fan
Posted on Oct 12, 2009
peterrance19
  • 399 Answers
SOURCE: Problem for Rheem Paloma PTG-74PVN / RTG-74PVN
hi pete here ill try and help this could be 2 things check the sensor on the unit the outher one is a qustion has the gas company changed your meter latley and turned off you gas and not come back to light your poilet because this code also means not enough gas or wrong type of gas
Posted on Nov 18, 2009
  • 48 Answers
SOURCE: I am getting error code AO and the temperature
its most likely diplaying a code... is it code 21? that usually will follow ao. first make sure the door is securely on, if not make sure it contacts the switch
Posted on Jan 16, 2010
SOURCE: Rheem Paloma PTG-42PVN, No hot water. error C4
get ready to pull that one out and get a different brand
worked on mine for a year and a half and replaced everything and the unit would still not run.
Posted on Jan 21, 2011
I have a paloma tankles water heater model #ptg-42pvn i am getting an intermitent error code C4,12. what is the problem?
Copy following link for Rheem-Paloma tankless troubleshoot and error codes:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
http://waterheatertimer.org/How-to-install-gas-water-heater.html#install
If unit worked before: Maybe bad PC board. Maybe lack of required yearly maintenance.
Common error codes can be caused by not following maintenance protocol such as cleaning combustion parts, checking gas pressure, checking venting, and air intake, bleeding gas line etc.
Too bad Rheem-Paloma manuals do not show HOW to conduct this maintenance, leaving customer with many unknowns, and no way to oversee that maintenance performed by hired technician is complete, and matches recommended maintenance.
Sell unit on ebay, and install tank-type gas water heater.
Mar 20, 2013 | Rheem Paloma PTG-42PVN / RTG2-42PVN...
Error Im getting is C8 82
Before calling service tech, copy following link for Rheem-Paloma troubleshoot resources:
C8 is usually the PC board, or could be failed gas solenoid valve.
82 is gas-type-data-failure = program PCB for proper gas type, or proper altitude above sea level.
If this is new installation, Rheem-paloma might tell you to contact the installer.
If this is older tankless that worked before, then things point to failed PC board. Rheem-paloma may send you new PCB for free if unit still under warranty period for defect parts.
Rheem does not post service manuals, but will send instructions.
Hopefully the success rate for replacing your main PC control board will have better outcome than expected when replacing motherboard on your computer.
Perform regular maintenance to avoid some common error codes.
Aug 16, 2012 | Rheem Paloma PTG-74PVN / RTG-74PVN...
No hot water
Water heater is not identified, and steps taken so far have not been described.
Before calling service technician, open following links for Rheem/Paloma troubleshoot resources:
http://waterheatertimer.org/pdf/No-Error-Code.pdf
Oct 07, 2011 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Error 13 paloma tankless hot water system. no hot water
Before calling service technician, open following links for error codes, Rheem/Paloma chat and tech support, and possible manual:
http://www.fixya.com/support/t3444443-paloma_tank_less_water_heater_flashes
Error codes are considered start-point for troubleshooting.
Tankless manuals recommend yearly service including burner cleaning, gas pressure and plumbing check, de-liming etc to prevent problems and so technician is familiar with that specific unit.
Aug 05, 2011 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Getting a 76 flashing on my Paloma PTG-74XP tankless water heater
Error code 76
http://waterheatertimer.org/pdf/Rheem-error-code-C7-76.pdf
http://waterheatertimer.org/pdf/Rheem-Tankless-Fault-codes.pdf
Open following link for Rheem/Paloma/Richmond/Ruud tankless troubleshoot resources including error codes, self help, manuals, parts links, tips, and contact information.
Read manual cover to cover, make sure tankless receives yearly maintenance as outline in manual.
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 30, 2011 | Rheem Paloma PTG-74XP / RTG-74XP Liquid...
My tankless indoor water heater has an error code C4 76
Error code 76 indicates a communication error with the electronic board and the unit. Call Paloma/Rheem with the serial number and model number of your unit and they will, in most cases, send you a new board with instructions on how to easily replace the board.
Tech Support: 800-432-8373.
Nov 21, 2010 | Rheem Paloma Tankless Water Heaters...
Problem for Rheem Paloma PTG-74PVN / RTG-74PVN Natural Gas Indoor... What does C2 11 error code mean on my Paloma
Nov 18, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Rheem Paloma PTG-74PVN /  RTG-74PVN Natural Gas Indoor Logo
67 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
