Question about HP Photosmart D7160 InkJet Printer
HPD7160 ink expired. how to bypass
HOw do I bypass ink expiration. I have barely used it. Can I reset my cartridge
faishortcake
  • 12 Answers
SOURCE: Expired ink cartridge
You may be getting this error message due to the printer being able to tell that it is a non-hp cartridge. I don't know how it can tell, but mine says that too. I uninstalled the software and then reinstalled the software. And then I took out the cartridge and put it back in. See if this works for you.
Posted on May 14, 2008
SOURCE: officejet d135 - "Supply Expired" error message
HP, in order to sell more ink, monitors the expiration date of the cartridges installed. Solution is either to buy a new unexpired cartridge from HP or to disable the date monitoring built in to the printer. This latter is done by removing the button cell located inside the D135 printer on the left hand side or by simply slipping a thin piece of plastic between button cell and metal contact. You will no longer have date function on printer, but it won't object to expired cartridges either.
Posted on Oct 18, 2008
SOURCE: 8250 HP INK EXPIRED MESSAGE
I had same problem, and i solved it.
I opened my hp 8250 and removed it`s battery. It is located on left side of the printer, on the main board. You need to remove plastic covers , and then remove 3 screws holding board. You can move board just enough to get damn battery out of there. Now it works perfect!
I can send you some piccs if you need help.
Regards
Sasa
Posted on Nov 02, 2008
  • 106 Answers
SOURCE: Keeps stating ink expired
i guess your printer has reach the printing warranty.. try to search in the web on how to reset your printer, ^^
Posted on Feb 16, 2009
  • 414 Answers
SOURCE: can i still print in only black ink when my color
Yes, right click the printer and in the properties look for "use grayscale" or similar option - this will force the printer to only use black ink.
Good luck! Please don't forget to rate :)
Posted on Nov 03, 2010
How do I bypass the expired cartridge on a HP DesignJet T610?
The dates are on the package for a reason. The ink dries out or changes viscosity over time and will likely clog the printhead.
My advice is not to stock up on cartridges because of this problem.
If you look online, you can find replacement chips or instructions on how to reset the chip on the cartridge.
Jul 06, 2014 | HP DesignJet Office Equipment & Supplies
Bypass expired message cartridge. Cartridge is less than six months old & nearly full.
Every cartridge will have its own ID and Expiry date, please check the Cartridge expiry date, if its really expired then printer will reject it even-though the cartridge is full.
We cannot bypass cartridge errors for single cartridge in INK-JET printer, because they work in TIJ technology (Thermal Ink Jet) which needs all cartridges to be functional unlike Laser-jet printers.
Regards
Riztech
Jan 13, 2011 | HP Officejet Pro L7590 All-in-One InkJet...
I bought a black ink for my hp photosmart c5 180 and the when i turn on the printer it says the ink has expired. Can i still use it or will i damage my printer. Thanks regards Anita
Hello
according to HP
Each ink cartridge has an expiration date. The purpose of expiration is to protect the printing system and to ensure ink quality. When you receive an ink cartridge(s) are expired message, remove and replace the expired ink cartridge, and then close the message. You can also continue printing without replacing the ink cartridge, by following the instructions on the HP All-in-One or the ink cartridge expiration message on your computer screen. HP recommends replacing the expired ink cartridges. HP cannot guarantee the quality or reliability of expired ink cartridges. Device service or repairs required as a result of using expired ink will not be covered under warranty.
You can get more detail from here
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00819032&dlc=en&product=1153481
Hope this helps, if so do rate the solution
Dec 31, 2010 | HP Photosmart C5180 All-In-One InkJet...
The ink cartridges keep expiring and they are nearly all full .my machine is a hp photo smart 3310 all in one.How do i by pass the expiry dates on cartridges
Each ink cartridge has an expiration date to protect the printing system and ensure good ink quality. The cartridge expire date appears on line 53 of the self test report.Printing can continue without replacing the ink cartridge. Follow the instructions that appear on the HP product or on the computer. However, HP recommends replacing the expired ink cartridges. HP cannot guarantee the quality or reliability of expired ink cartridges. Service or repairs required as a result of using expired ink are not covered under warranty
As the printer operates, it moves ink from the ink cartridges into a printhead reservoir. The printer does not deliver a message when an ink cartridge goes empty, because it still has ink in the reservoir. The printer continues printing until the ink level in the reservoir falls to a first trigger point - then a message appears advising the printer owner to Replace Cartridges Soon . At this point, other cartridges that are empty but have not reached the trigger point are also mentioned in the message, to save trips to the retailer. After the first trigger point, the printer can continue printing until ink levels in the reservoir reach a second trigger point. At the second trigger point there is only enough ink left to perform vital servicing tasks, and a new message appears, saying Ink Cartridges Empty . The options offered depend on the usable inks remaining. If no options are offered, the cartridges indicated must be replaced before printing can continue. Reset the product
  1. Without turning off the product, disconnect the USB cable from the rear of the product. NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (c01424575.gif ).
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button .
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 16, 2010 | Office Equipment & Supplies
It say supply expired change color ink i put brand new cartridge still saying the same thing
One possible problem is that the new cartridge has an expired date. According to the manuel, the printer cannot use an expired cartridge. Check the date on the cartridge. Good luck. I am hoping to get a refund from Staples because I bought an expired cartridge.
Oct 15, 2009 | HP Officejet 7130 All-In-One InkJet...
Supply expired
You can't. Cartridges have a date bomb built in, they may be expired.
Jan 20, 2009 | HP OfficeJet d145 InkJet Printer
Scanner failure, black ink expired
As far as the expired cartridge is concerned, Check out the answer at the following link:
http://www.fixyourownprinter.com/forums/inkjet/27744
Cheers,
KAT
Oct 26, 2008 | HP OfficeJet D135 All-In-One InkJet...
"Expired color cartridge" message blocks black printing - nothing works
Hello merelU. I'm afraid you may have to replace the empty color cartridge as there may be problems with the printer while an expired cartridge is installed on the printer (even though some of the cartridges are still under warranty) and also, HP cannot guarantee the quality or reliability of expired ink cartridges.
all the best.
thx
Oct 07, 2008 | HP Photosmart 3310 Printer
Hp printer 7110
hi,
Try to remove the black ink cartridge. From there, you can check the expiry date of the Ink cartridge. If its already expired, then you need to use another black ink cartridge that is not yet expired.
Thank you so much.
adonscott
Jun 18, 2008 | HP OfficeJet 7110 All-In-One Thermal...
HP Photosmart D7160 InkJet Printer Logo
51 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
