Question about Garden
Will not drive
When put in drive mode the mower will not move.
  • richard sanders May 01, 2014
    on mine if it's been sitting for a couple weeks i need to "bump" it to get it to move. try scooting your body forward whi;e sitting in seat to move tractor. keep it in low speed incase it takes off. also check shifter arm , move it through each gear slowly
    Genius:
  • 1,114 Answers
You haven't indicated what mower you have, but in general terms , check to make sure the drive belt is not broken. There is a tension wheel on most mowers which puts tension on the drive belt when the clutch is out.There is usually an idler pulley that puts tension on the drive belt.Sometimes a tensioning spring breaks or comes off a pulley. So confirm that the drive belt is intact and that there is tension on the belt. If this did not help, please forward info on the mower; brand, model #, serial #, and I will try to help you further.
Posted on Apr 22, 2014
1028 rear engine riding lawn mower model # 927046 is not moving when in gear. Was told I needed a drive box unit for it
check to see if the key in the axle is in place or if you put it in gear the axle turns in the wheel . is the pulley in place and not loose. the belt is good you said. but the pulley may be stripped. (axle key, belt, pulleys, or belt off of pulley)
Nov 19, 2016 | Garden
Will run but doesn't move
If it doesn't move at all; I would check the drive belt first, then the belt idler pulleys. Just make sure that no one has put the hydro units in bypass mode so they could move the mower without the engine running without your knowledge..
Feb 28, 2014 | Toro Zero Turn Rider 74366 Lawn Mower...
I have a j d 430 lawn & gargen tractor. can't get it to move is there any levers other than the one on the dash that i need to engage to get in to move? it runs fine the pto works the lawn deck...
I have a Craftsman and there is a pull out rod in back that disengages the drive so you can push the mower, if necessary. If you can push it this rod must be out of the drive mode. If you can't push it, it is in the drive mode.
Gary
Jun 22, 2011 | Garden
The mower with not move! I put it in forward push the gas paddle and it will not move. It just wont move, it has a brake paddle and a gas paddle and brake. All yard machines basicly have the same setup in...
Inspect the drive belt,if it is broken.Under the hood is a list of parts and part numbers.Find the drive belt on there and get a replacement.The package the belt comes in has the diagram for installation on the back.Would not be a bad idea to go a head and change the deck belt if it is ore than 2 years old,while you are under there.
May 12, 2011 | Yard Machines 155 Torque Briggs Stratton...
We have a riding lawnmower that is a husqvarna. My husband cut the lawn, edged the lawn and then started up the mower to put away. It started up great but we can't get it to move...any suggestions?
Could be the drive belt either came off or broke. Check the belt that goes from the motor to the rear transaxle. (Not the one going to the deck) If belt looks look at the clutch pullys that they are working ok
Oct 02, 2010 | Husqvarna Garden
1180 cub cadet replaced both drive belts length of belts is correct,mower still moves if foot peddle is not engaged.per manual set the adjustment of the drive pullys and the problem is still there.I have...
If you did not use the original manufacturer belts it will cause this as lawn mower belts are designed to slip when not under tension (so called graphite Belts) where other belts are designed not to slip even when some tension is lost.
Nov 07, 2017 | Cub Cadet Street Sign- tractor lawn riding...
I have just bought a ride on Electrolux mower and can start it but it want go forward. What havent I done to make it go?
I presume this is a unit with the hydrostatic drive (automatic, just step on a pedal). There should be a rod or lever, usually on the back of the mower, that will release the hydrostatic and let you push the mower by hand. This basically bypasses the system, and the mower will not move if this lever/rod is pulled. If someone had to push this mower to load or move it, chances are it's not been pushed back into operating mode.
Dec 23, 2009 | Garden
When deck is lowered blades do not engage
Is the belt in place that drives the blades?
Is the belt at the correct tension?
With the mower engine off.....try to turn each pulley the belt drives and on the mower deck with the mower in up position and or down....do they turn a little......this is to check for a seized bearing on one of the pulleys also look under the deck for something stuck........ jamming a blade.
Also check for the mower belt safety system (which stops the blades quickly when disengaging them) that may be stuck in stop mode.
With the mower engine running.....have some one engage the blades while you look under at the belt system....is the engine driving the belt.....is the belt driving the blades.
DO NOT TOUCH ANYTHING......MOVING OR STOPPED while the engine is trying to drive the blades.
Sep 06, 2009 | Mtd Garden
Garden Logo
115 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
