Question about Tommy Bahama (61092-45696) Ceiling Fan
I cannot remove light globe to change bulb
Model # TB135DBZ
    Genius:
  • Tommy Bahama Master
  • 1,617 Answers
You must have bought this at Costo! You have to turn counterclockwise. Tap gently around ring of glass to loosen.
Posted on Apr 20, 2014
How to change light bulb in a 1997 Subaru impreza
Remove cover at back of light ,remove wire clip that hold the globe in then remove globe and replace .
Nov 01, 2014 | 1997 Subaru Impreza
How to change stop light globe on 2008 hyundai getz
Remove the two 10 mm (head) bolts that hold the stop light. This bolts are between the tail light assembly and the tail gate weatherstrip. You can see them without having to remove anything.
By using a masking tape wrapped flat screwdriver, pry "back" the whole tail light assembly. Once out, you can twist the brake light (or reverse, or turn signal) bulb plug, remove and replace the bulb.
The Getz uses standard two filament brake globes (1/4 turn to install).
May 12, 2014 | 2008 Hyundai Getz 1.6
I want to know how to remove the globe so I can replace the halogen bulb on my ceiling fan light. It is model Model # acsy0205-1cc .
There are usually 3 hand tighten screws surrounding the opening where it meets the socket portion. With one hand on the bottom of the globe, loosen the screws with the other hand (carefully remove globe)
Sep 20, 2013 | Hampton Bay Heating & Cooling
How do I remove the light from the ceiling?
Sent you a question on this but did not receive a reply.
If you are talking about removing the grill/globe to change bulbs, it just pulls down from the ceiling. There is a heavy "V" spring on each side that needs to be compressed to pull the grill/globe down. Once it is down as far as it will go, the springs need to be squeezed together and the ends removed from the metal box in order to take the grill/globe off. It is not necessary to remove the grill/screen completely to change bulbs.
Please see my other message.
Paul
Sep 18, 2010 | Broan-NuTone N-8663RP Combination Light...
How do change the light bulb
Turn off the circuit breaker to the Range.
You slide the metal clip to one side. Both ends of the clip stays attached to the lamp holder.
Keep your fingers on the light globe as you move the clip. It is the only thing holding the globe on.
Jan 17, 2010 | Whirlpool Kitchen Ranges
Need to change rear brake bulb on daewoo TACUMA CDX 2004 model but can not get to bulb any ideas please on how to change it
open rear hatch and remove 3 screws down edge of lamp assembly gently pull assembly out and then you can remove globe sockets from lamp assembly to change globe
Jun 24, 2009 | Daewoo Korando Cars & Trucks
Changing light bulb in ceiling fan
At the top of the pull chain there is a metal piece; this is threaded on a bolt. Unscrew the metal piece and lower the globe to expose the bulbs then remove and replace the bulb(s). I recommend flourescents as they are more economical, run cooler and last linger than incandescents (regular bulbs).
May 17, 2009 | Hampton Bay 24002 Ceiling Fan
Replacement light bulb for Panasonic NN-9853 Microwave
Hello, I also have a Panasonic Microwave ( model NN-S 564 or 574 ?) They are very similar.
I have just removed the outer cover 5 screws ( unplug of course ) and have located the bulb holder which is a white plastic component with two clips holding the globe, pull it out and remove the two spade clips connected to the globe. The globe will come away attached to a black plastic mount. Next........do the run around to find someone who sells it.
Perth has an authorized distributer/repairer in Myaree whose details I got from Panasonic. He may sell them. otherwise I will try a couple of specialist light globe suppliers I know....PROLAMPS in Belmont and one in BALCATTA whose name escapes me but I have been there before...Hope this helps others.
Martin
May 10, 2009 | Panasonic NN-S540 Microwave Oven
How do I change my headlight bulb
go to your parts suppler and ask for a H4 globe pop your bonnet and remove the plug on the back of your head light then remove the rubber boot paying attention to which way it cam off then you will find a spring clip unclip it but be careful not to damage its anchor point. remove old globe an throw away take new globe out of box DO NOT TOTCH THE GLASS OF THE GLOB AS IT WILL CAUSE THE GLOBE TO BLOW STAAIGHT AWAY AFTER FITTING IT handle the globe by the metle bass and fit it, refit spring clip and rubber boot fit the plugf and check the operation of the light
bingo you are done have a nice day
Dec 21, 2008 | 1999 Mitsubishi Mirage
Tommy Bahama (61092-45696) Ceiling Fan Logo
Top Tommy Bahama Dryers Experts
Are you a Tommy Bahama Dryer Expert? Answer questions, earn points and help others
