Brother printer dcp 145c clean unable 35 - Office Equipment & Supplies
Mix-it-up
  • 832 Answers
SOURCE: Brother Model DCP-117C Printer -
you need a new ink absorber box which you can buy from a brother service dealer near your home (see brother homepage of your country). when done so open printer:
http://www.hstt.net/refill-faq/inside.html#Brother_mfc215c
(use google translation german)
you have to rest the eeprom parameter, too
press menu then start bk-copy then fourtimes arrow-up quickly after another. machine will switch to maintenance mode. press by help of arrow up and set : 8 - 0. press start bk-copy til PURGE 64xx appears. press the sequence of 2 -7 -6 -3 (arrow up and set). PURGE will reset to 0000. press 9 - 9 to leave maintenance.
Posted on Apr 23, 2008
Mix-it-up
  • 832 Answers
SOURCE: Brother DCP-115C unable to clean
you need a new waist ink absorber box from a service partner which can be found at brother homepage of you country.
After replacing the box you have to do a reset.
search error 46 or unable to clean here in the forum. it has been written many times.
Posted on May 05, 2008
  • 215 Answers
SOURCE: Brother DCP 330C 'unable to clean 46' printer will not print
responded to this on a error 46 post by joachim.
hth,
razors
Posted on Mar 30, 2009
SOURCE: DCP-165C Compact Colour Inkjet Multifunction Printer: in brother dcp 165 printer the error message clean...
brother dcp-165c printer unable to clean , see troubleshooting and routine maintenance chapter in User's guide
Posted on Jun 06, 2010
SOURCE: dcp 145c brother printer wont print black but
my dcp145 brother printer won't print black , but colour is okay
Posted on Jul 06, 2010
Dcp 145c machine error
ill email you the reset procedure for the m/c and pruge but just doing a reset will not cure this problem you need to replace purge unit and do a counter reset on your purge unit, (used to clean the printhead) thats why it says unable to clean,
In Case You Still Having Problem Then Follow Us For On :
Brother Printer Support
Jun 28, 2012 | Brother Ink for Dcp145c Lc-980
'unable to clean 35' error on mfp brother dcp-j125 printer
Feb 15, 2012 | Office Equipment & Supplies
PROBLEM IS MY PRINTER SHOW ERROR CLEAN UNABLE 46
Hi
This is the counter inside the printer which stops the printer unless it is reset. Follow the below steps to do the reset on your printer.
How to Reset Brother DCP 110C, 115C, 120C, 130C, 135C, 145C, 150C, 165C, 185C, DCP 195C Printer
May 25th, 2011 • Printer
How to Reset Brother DCP 110C, 115C, 120C, 130C, 135C, 145C, 150C, 165C, 185C, DCP 195C Printer:
1. Press the Menu, then Mono Start key then press the UP arrow key 4 times to make the machine enter the maintenance mode and "ERROR 46′ pops-up in the display.
2. Enter maintenance mode 80: Select 8 by pressing the UP/DOWN arrow key and push OK key and select 0 and push OK key
3. Now Press MONO arrow key several times until you see PURGE:XXXXX
4. Select 2 and push OK, Select 7 and push OK, 8 and push OK, select 3 and push OK and the purge counter is now reset to 00000.
5. Press STOP/EXIT key to go to root of maintenance mode
6. Enter code 99 to exit maintenance mode: Select 9 and push OK, Select 9 and push OK.
Jul 24, 2011 | Brother DCP-110C All-In-One InkJet Printer
I need a Brothers DCP-145C installer...A.S.A.P
sir, mam
my brother dcp-145c can create error no 46 how can i remove the error plz reply and gave me a solution how i can remove the error
My e-mail address is manishbhardwaj1993@gmail.com
Jan 17, 2011 | Brother DCP 165C Compact Color Inkjet...
Brother dcp-145c blocked ink jets
http://welcome.solutions.brother.com/bsc/public/eu/gb/en/doc/manual_top.html?reg=eu&c=gb&lang=en&prod=dcp145c_eu_as
from this link u will download the manuals and drivers then i think it will start working................good day sir
Aug 02, 2010 | Brother Office Equipment & Supplies
May 16, 2010 | Brother DCP 165C Compact Color Inkjet...
I cant install my printer...brother DCP-145c
which operating system do you use????
Follow the instructions correctly during the set up process , if failed installation cannot take its form.......
if you are using windows 7 then download the latest drivers form brother website......
Nov 18, 2009 | Office Equipment & Supplies
Trouble shooting clean unable 50
Alright, i have to tell you, this is a really bad post. You gave me nothing for information. But from what information i can gather, it could be error number 50. on a brother DCP-145C. Heres the problem with brother printers. They are cheap to buy initially, but break and can't be fixed easily without being a "Certified brother technician".
Either way. I think you have to replace the logic board on the unit, possibly. Possibly check the connections and use sand paper and undo some connections sand the copper, and put them back in. Logic board will likely run you over a hundred, if you need to replace the fuser, thats over 100 again. Expensive repair. If it had been an HP printer, i could have explained it thoroughly, i'm sorry i can't be of more help.
Sep 20, 2009 | Brother Multi-Function Center MFC-240C...
20 people viewed this question
jasbo
jasbo
