Question about Hitachi RD7232 23-Cup Rice Cooker
Water to rice ratio - Hitachi RD7232 23-Cup Rice Cooker
2 Suggested Answers
  • 7 Answers
SOURCE: What is the rice to water ratio for cooking rice
Here's a simple one page guide for cooking rice in a rice cooker. It will tell you how much water to add depending on the type of rice you're cooking - How to cook rice in a rice cooker
Posted on Oct 02, 2011
Lost my instructions for my Black & Decker rc410 rice cooker. What is the water to rice ratio
Normally same amount of each. e.g. 2 cups rice to 2 cups of water. It does depend on quality of rice so be prepared to experiment.
Sep 18, 2014 | Kitchen Appliances - Others
How do I measure the water /rice ratio?
The ratio is not critical... just make sure that the water is covering the rice a bit...
Here is a tip that will help you figure out about using a rice cooker...
How much Rice and Water go in the Cooker
heatman101
Sep 02, 2011 | Aroma ARC-7315G 30-Cup Rice Cooker
Sorry.I lost the measuring cup that came with the cooker. what is the dry ratio of rice to water (lines on the side of the cooker)?
Hi the best ratio is 1:1.25.Means that one level of rice equivalent to one and one-forth level of water.This ratio is sufficient to cook rice not overdone.
Jun 23, 2011 | Hitachi RD6106 10-Cup Rice Cooker
Recieved one as a gift lost instructions how much rice to water
Check this procedure:
* Before cooking, rinse rice in warm water until water becomes clear. Then place the rice in the inner pot with fresh water.
* Take care to use proper water to rice ratios.
* Use a 1:1 ratio of rice to water plus ½ cup of water for white rice and a 1:1 ratio plus ¾ cup of water for brown rice.
TIPS:
# You may wish to tweak the "rice to water ratio" with experience - for example: for larger quantities of rice, you may find a little less or more than one and a half the amount of water results in better rice.
# One cup of dry rice grains cooked in this way is about sufficient to accompany a meal for 2 adults.
# If the rice is a major component of the dish, you might need up to 1 cup of rice per adult.
# Your base measurement doesn't need to be a cup necessarily - the key is to add 1.5x as much water as rice, whatever the quantity.
# It works best to use the original lid of the pot you use, since it will seal best.
# When the rice first boils, it might weep a bit or even lift the lid. Keep watch and an ear out for the start of the boil.
# These times and ratios are for white rice (e.g. Jasmine, Basmati, etc). If you are cooking brown rice you will need around 2C water to 1C rice and double the time.
# Salt is not necessary when cooking rice, but can be added. Unless you add a ridiculous amount of salt it will not significantly change the boiling temperature or time.
# Water boils at a lower temperature at altitude. If you live at a high altitude it will take longer to cook rice using this method.
I hope help with this (remember to rate this answer).
Sep 30, 2010 | Black & Decker RC400 7-Cup Rice Cooker
Water to rice ratio in an Aroma ARC 1000
Water to rice ratio is usually the same regardless if you have a rice maker, or are cooking it in a pot on the stove. 2 parts water to 1 part rice works everytime.
Jun 08, 2010 | Aroma ARC-930 20-Cup Rice Cooker
How do i cook rice in my rice cooker? what are th...
Just read these ratio's in "The Asian diet". 3 cups water to 1 cup rice. PERFECT!!
May 21, 2010 | Tiger JNP-1000 5.5-Cup Rice Cooker
Lost direction on how to use my rice cooker and havn't used it in a while
To cook rice, fill center basin of base with water. Place the rice bowl on basin. Add rice and water as follows. For white rice add water in a 1:1 ratio to rice plus 1/2 cup. For brown rice add water in a 1:1 ratio to rice plus 3/4 cup. Examples: 1 cup white rice, 1-1/2 cup water; 2 cups brown rice, 2-3/4 cups water. Put lid on and plug in and in about 50 minutes you should have delicious rice.
Please rate this answer. Thank you.
Mar 27, 2010 | West Bend 86712 12-Cup Rice Cooker
I lost the cup that came with the rice cooker, and was wondering what the rice/water ratio is.
For Jasmine rice, we use 1.5 C dry unwashed rice to 2.5C cold water.
For Japanese short grain sushi rice which needs washing, we use 2C dry rice, wash and drain it, than add 2.5 C cold water and let soak for 10 minutes, than cook.
For brown rice, we use a 2:1 ratio, water to rice, with 20 minutes soak time.
Hope this helps.
www.areyouagoodperson.com
Oct 05, 2009 | Black & Decker RC4 6-Cup Rice Cooker
I lost my manual
hello there
here it is pretty simple ok
Use a 1:1 ratio of rice to water plus ½ cup of water for white rice and a 1:1 ratio plus ¾ cup of water for brown rice. hope that is verry helpfull
best regards michael
Sep 20, 2009 | Rival RC61 6-Cup Rice Cooker
Rival RCS200 problem
Try this:
  • Before cooking, rinse rice in warm water until water becomes clear. Then place the rice in the inner pot with fresh water.
  • Take care to use proper water to rice ratios.
  • Use a 1:1 ratio of rice to water plus ½ cup of water for white rice and a 1:1 ratio plus ¾ cup of water for brown rice.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
Apr 07, 2008 | Rival RCS200 20-Cup Rice Cooker
Hitachi RD7232 23-Cup Rice Cooker Logo
32 people viewed this question
Top Hitachi Kitchen Appliances - Others Experts
Irene Tulloch
Are you a Hitachi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
