Question about John Deere Garden
Mower only moves in high speed
The mower only moves in high (5) speed when engaged. is there a way to adjust the cable or linkage to get all five walking speeds? I have the technical manual for this mower and it doesn't show a way to adjust for all speeds. It does show how to replace the transaxle, however that is only if there is no movement.
  • John Deere Master
  • 2,478 Answers
What model?
Posted on Apr 19, 2014
  • M Brodsky Apr 19, 2014
    John Deere JX75
  • Dennis Key
    Dennis Key Apr 20, 2014
    Sorry, jx75 is a walk behind. Are you sure.
Its a rear drive does not self propel very good
I'm assuming your mower has a typical rear-drive setup with a belt that runs from a pulley on the motor shaft above the blade to a transmission pulley that drives the wheels.
The first thing to check is the cable adjustment: With the mower on a flat, hard surface like a concrete driveway, start the motor then slowly squeeze the bail to engage the drive. The mower should want to start rolling by the time the bail is about 1/3rd of the way engaged and should be up to full speed by the time it's 2/3rds of the way engaged. The final 1/3rd of its travel until it's up against the mower handle puts tension on a spring that keeps proper tension on the belt. If you have to squeeze the bail more than that for the mower to start moving or reach full speed, the cable needs adjusting:
The top end of the cable goes through a clamp attached to the side of the mower handle into an adjustment *****; basically a hollow ***** about an inch long with a knurled locking ring or nut that keeps the ***** from turning. Loosen the locking ring, then unscrew the adjustment ***** about a quarter-inch, then tighten the locking ring. Test-drive the mower again. Depending on how far out of adjustment it was, you may need to repeat the process. If the cable has been adjusted before or is way out of adjustment, you might find that you'd have to unscrew the adjustment ***** more than all the way out to get it properly adjusted. Of course that won't work. In that case, loosen the locking ring all the way and turn the adjustment ***** almost all the way in. Then put a piece of tape or a mark with a marker on the cable about a half-inch above where it comes out of the clamp. Loosen the clamp bolts (there may be one or two) just enough to slide the cable down to the tape or mark. Hold the cable there and re-tighten the clamp. Test drive again and readjust the adjustment ***** until the cable is properly adjusted. Be sure to tighten the locking ring.
If the cable is properly adjusted but the mower still doesn't self-propel through grass very well, then the belt is getting worn. After several years, the surfaces of the belt that contact the pulleys have become smooth and glazed and don't get good traction on the pulleys anymore. Although I've used a spray-on product called belt dressing a few times to temporarily kinda somewhat restore belts on my own machines until I had time to replace the belts, getting access to properly apply the belt dressing can be tricky. Since replacing the belt on a rear-drive mower can be a pain even for someone with tools and skills, I'd recommend taking the mower to a repair shop in the off season to have that done.
Apr 06, 2016 | Garden
How to raise the deck of a Toro SS 5000 mower above the highest factroy setting
Hi Robert:
I'd start by looking at the mechanism with the engine off while someone else moved the height adjust lever from hi to lo several times.
There will be 2 or 3 linkages that connect the deck vertically to the height adjust mechanism. Shortening these linkages should raise the cut height. If you're lucky, there should be enough clearance to allow the linkages to be drilled so that you can simply move the mounting pins into the new holes.
Or, you could make shorter linkages.
Best of luck.
Sep 30, 2015 | Toro TimeCutter SS5000 50 in. 22HP Smart...
Drive pedal will not move mower
If this is a riding mower you are talking about then I would check the linkage from the pedal back to the motor. I bet there is an adjustment along the line that can tighten this up to the point it will engage properly
Jan 13, 2015 | Garden
Ignition/no spark on ford GT85 riding mower with a kohler M18QS gas engine. I need the electrical schematics for diagnostics.
follow this steps and fix it. GOD BLESS YOU
If grass is poorly or unevenly cut, try mowing at a slower speed and adjusting the engine speed with instructions in your owner's manual. Scrape away any dried grass and other debris caked under the mower deck. Sharpen or replace dull or bent blades 0fbc95da-10ce-4268-a804-bcc52ffe7dcf.jpg. Check and replace a worn belt.
If the V-belt slips or comes off during use, clear any debris in the belt area, adjust the drive-belt tension (see below), or have the belt replaced. Adjust and tighten pulley fasteners or have a service center replace worn parts.
If the belt squeals or wears excessively, adjust the drive-belt tension (see below) and look for obstructions around the belt. If that doesn't work, take the mower in for professional service.
If the mower vibrates excessively when the clutch is engaged, scrape away any debris accumulated under the deck. Balance the blade and replace the blade if needed. If that fails, adjust drive-belt tension (see below). If you find that the drive belt, pulley, or other belt-drive part is damaged, consider having it replaced by a professional.
If the mower is hard to shift or doesn't move when the clutch is engaged, adjust the drive-belt tension (see below). Also make sure the mower is lubricated according to the owner's manual specifications. As needed, have the mower serviced for damaged or maladjusted clutch/brake pedal linkage.
If the engine doesn't start, loses power, or dies during use.
Replace a recoil starter rope:
  1. Disconnect the spark plug cable for safety.
  2. Disengage the throttle cable from the housing and remove the housing as needed to access the starter.
  3. Remove the handle from the rope, which is often held in place by a knot or retainer pin.
  4. Unfasten the other end of the rope from the starter using pliers or a cutter as needed.
  5. Knot the end of the replacement rope.
  6. Tighten the pulley counterclockwise all the way, then back it off two turns and hold it firmly.
  7. Thread the unknotted rope end through the pulley hole.
  8. Thread the rope through the housing hole and pull it taut.
  9. Slowly release the pulley, allowing the rope to wind around the pulley.
  10. Attach the handle and reassemble as needed.
  11. Reconnect the spark plug cable.
Replace a recoil starter spring:
  2. Remove the housing and the spring cover.
  3. Carefully remove the rope from the pulley to release spring tension.
  4. Remove and replace the spring as recommended by the manufacturer.
  5. Reinstall the pulley, rope, and housing following the instructions above.
  6. Reconnect the spark plug cable.
Nov 12, 2013 | Garden
Engage drive
Check the adjustment on the accelerator linkage. Make sure it is fully engaging.
Jun 09, 2013 | Swisher Zt2560 Zero Turn Radius 60" Riding...
Engine dies when when you engage mower or gear
First I would check that the air filter is not stopped up. Second I would clean the carb very well as I believe the high speed circuit in your carb is obstructed. The mower will idle on the low speed circuit but I think it is getting insufficient fuel when you load it. This is where the high speed circuit comes in to allow the additional fuel for higher demand operations like moving in gear and especially the blades.
I hope that this helps.
Jul 15, 2011 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
How do I adjust the carbator to get the mover to
it tells me its a generator on the top and your talking about a mower, first a generator will not be adjustable for voltage control these carbs are fixed(no adj), if its a lawn mower there are 2 screws adjust the high speed needle screw thats on the throttle linkage
Nov 09, 2009 | Briggs & Stratton Power Products 5,550...
10685 engine dies after starting.carb linkage is not moving
See if you can move the parts on the carburater that are supposed to be controlled by the wire. Most likely they can turn, but it is the wire that is not working. The cable is 2 parts; an inner wire and and outer sleeve. Most likely there is rust on the inside. Sometimes you can soak the wire with a peneterant and work it loose. Best bet would be a new cable.
Sep 26, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Front ppropelled mower
You dont adjust the belt,you adjust the cable that moves the pulley into the belt. There will be a small single bracket close to the engine side of the mower that holds the cable in place. Simply loosen bracket and move cable until pulley contacts belt enough to engage self propel.
Aug 08, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
48 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
