Question about Mitsubishi WD-65733 65" HDTV
Error code 34 on mitsubishi tv - Mitsubishi WD-65733 65" HDTV
4 Suggested Answers
SOURCE:
Slinteriors
  • 8617 Answers
SOURCE: red lamp light with newbulb, won't come on error code 34
There are two 1000uf 16V capacitors on the PWB that cause that problem code 34 lamp abnormality. If you need more info let me know.
Posted on May 04, 2008
carwhiz
  • 9 Answers
SOURCE: im getting error code 34 on my mitsubishi tv wd
If the caps are not pregnated looking they are good. I had the same code and I changed the caps anyways and still did not work. I found out that it was the colorwheel. Or it could be the cap that is on the light ballast(if the cap is not pregnated its the color wheel and you can find that on ebay for about a 100 bucks).
Posted on Jul 10, 2009
rulds2008
  • 3866 Answers
SOURCE: Mitsubishi 52525...I got advice from a lady guru
Sounds like what you got here is a lmap ballast issue, The ballast transformer is not lighting the lamp thus causing this to code on you.
Part can be found HERE
Kinda expensive to replace and would explain why the other bulb was new or looked new. People assume its the bulb in fact the most common issues with this tv was the ballast.
Good luck
please do click the accept button for my efforts.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Sep 03, 2010
Mitsubishi 65733
CONTACT MITSUBISHI TECH SUPPORT, THEY SHOULD BE ABLE TO GIVE YOU AN IDEA OF WHERE THE PROBLEM IS WHEN YOU TELL THEM THE ERROR CODE, THEN LOCATE A HONEST TV TECH FOR A ESTIMATE.
Feb 02, 2014 | Mitsubishi Televison & Video
Wd-60737 mitsubishi blinking yellow status light ?
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Oct 25, 2012 | Mitsubishi WD-60737 TV
I have a error code 33, what error code is 33
Hi, These are some codes to your DLP HDTV.
Error Code Probable Cause
12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disc
Jul 20, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
I have a 57" mitsubishi
You probably have a bad lamp again I hate to say. These lamp are so critical when being moved. If after you atttempt to power on TV then red light shows, press menu+input on the front panel and hold for 5 seconds. Front timer LED will blink a 2 digit error code five times then stop. Code 34 and 66 are lamp errors, and if you read code 66 the lamp is broken. Good luck
Bill W
integrityhomeworx.com
Mar 09, 2011 | Mitsubishi WD-57733 57" HDTV
Mitsubishi tv error code 21
The service manual does not list an error code for "21".
Here are the error codes:
32 Lamp Cover open
34 Lamp abnormality
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
Sep 13, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-52525 error code 34
replaced 2 capacitors 3300u/35v. At the power board.
do not tuch the rest of the chassis...............
Nov 23, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Red lamp light with newbulb, won't come on error code 34
May 04, 2008 | Mitsubishi WD-52525 52" Rear Projection...
ERROR CODE 34 on Mitsubishi TV
I just had the same issue with my TV (dont know code), but the issue was with the power supply.
Feb 16, 2008 | Televison & Video
Error code 1 2
I found this list of codes
32 Lamp Cover open
34 Lamp abnormality
41 Short Detected
Feb 12, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-65733 65" HDTV Logo
155 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
